Reading: Types of Industrial Control Systems
Inst Tools > Blog > Control Systems > Types of Industrial Control Systems
Last updated: March 4, 2021 3:31 pm
Control Systems PLC Tutorials
Different Types of Industrial Control Systems are Distributed Control System (DCS), Remote terminal unit (RTU) and Programmable logic controller (PLC).
Industrial Control SystemsDistributed Control System (DCS)Direct digital control (DDC)Remote terminal unit (RTU)Programmable logic controller (PLC)
Plant distributed control system (DCS) – While the term DCS applies in general to any system in which controllers are distributed rather than centralized, in the power generation and petrochemical process industries it has come to refer to a specific type of control system able to execute complex analog process control algorithms at high speed, as well as provide routine monitoring, reporting and data logging functions.
What is DCS (Distributed Control System)
Figure : Simple example of distributed control systems
In most applications, the input and output modules of the system are distributed throughout the facility, but the control processors themselves are centrally located in proximity to the control room.
These systems typically use proprietary hardware, software and communication protocols, requiring that both replacement parts and technical support be obtained from the original vendor.
The DDC directly interfaces to the process for data acquisition and control purpose.
  • That is, it has necessary hardware for directly interfacing (optoisolator, signal conditioner, ADC, etc.) and reading data from process.
  • It should also have memory and arithmetic capability to execute required P, P+I, P+I+D control strategy.
  • At the same time, the interface to control vale should also be part of DDC.
The below Figure shows the various functional blocks of a DDC system
What si DDC (Direct Digital Control)
The microprocessor performs the following tasks.
  1. It reads the various process variables from different transmitters through multiplexer and ADC.
  2. It determines the error for each control loop and executes control strategy for each loop.
  3. It outputs the correction value to control vale through DAC.
Direct digital control (DDC) systems are used in the commercial building heating, ventilation and air conditioning (HVAC) industry to monitor and maintain environmental conditions.
They consist of local controllers connected to a network with a personal computer (PC) based central station which provides monitoring, reporting, data storage and programming capabilities.
The controllers are optimized for economical HVAC system control, which generally does not require fast execution speeds. Their hardware and control software are proprietary, with either proprietary or open protocols used for network communication.
Remote terminal unit (RTU) based SCADA : RTU-based systems are common in the electric, gas and water distribution industries where monitoring and control must take place across large geographical distances.
RTU
The RTUs were developed primarily to provide monitoring and control capability at unattended sites such as substations, metering stations, pump stations, and water towers. They communicate with a central station over telephone lines, fiber-optics, radio or microwave transmission.
Monitored sites tend to be relatively small, with the RTU typically used mainly for monitoring and only limited control. Hardware and software are proprietary, with either proprietary or open protocols used for data transmission to the central station.
Programmable logic controller (PLC) based systems: PLCs, which are described in greater detail in the next section, can be networked together to share data as well as provide centralized monitoring and control capability.
PLC Training Course
Control systems consisting of networked PLCs are supplanting both the plant DCS and the RTU-based systems in many industries. They were developed for factory automation and have traditionally excelled at high speed discrete control, but have now been provided with analog control capability as well.
Hardware for these systems is proprietary, but both control software and network communication protocols are open, allowing system configuration, programming and technical support for a particular manufacturer’s equipment to be obtained from many sources.
Reference : This material adapted from the “Department of the Army, TM 5-601, Supervisory Control and Data Acquisition (SCADA) Systems for Command, Control, Communications, Computer, Intelligence, Surveillance, and Reconnaissance (C4ISR) Facilities, 21 January 2006.”
What is DIN rail ?
PLC Multiple Choice Questions
Relation Control System
PID Controllers with Selection Logic
How to Avoid Bad Grounds ?
1 to 8 Demultiplexer PLC ladder diagram
How to use JUMP Instruction in PLC Ladder Logic?
Feedback Monitoring in Safety PLC
Implement UDT in PLC Programming: User-Defined Data Type
How to Automatically Close Pop-up in FactoryTalk View Studio?
Boolean Logic to PLC Programming
RSLogix5000 PLC Program Backup procedure
Surface Grinding Process using PLC Program
DCS Troubleshooting Control Valve Loop
Lamp Control using PLC Logic Condition
Elevator PLC Ladder Logic
PLC Program for Star Delta Motor Starter
Feedforward with Dynamic Compensation - 3
Feedforward Control with Dynamic Compensation
Fish Farm Automation
Omron PLC Project: Fish Farm Automation Tutorial
PLC-based mail box automation
PLC Program for Mailbox with Letter Counting & Light Indicators
Open User Communication in Siemens Tia Portal - PLC to PLC
Open User Communication in Siemens Tia Portal – PLC to PLC
Fixed PLC
Siemens CP Module
Communication Processor Module in Siemens PLC
how-to-avoid-bad-grounds
Move function block
Move Instruction in Tia Portal
Surge Protection Device
Thyristor Chopper Circuit Quiz
Advantages of Star and Delta Systems
Electrical Systems vs. Pneumatic Systems
pressure switches relay circuit
Determine the functions of Pressure Switches ?
PLC Programming Example on Bottle Line Control
