Reading: How to do Simulation in Schneider PLC?
Inst Tools > Blog > PLC Tutorials > How to do Simulation in Schneider PLC?
In this article, we will understand how to do a simulation in various Schneider PLC software like Unity Pro, Machine Expert Basic, and HVAC.
Last updated: October 17, 2023 1:53 pm
In this post, we will understand how to do a simulation in Schneider PLCs.
Simulation in Unity Pro Schneider PLCSimulation in Machine Expert BasicSimulation in Machine ExpertSimulation in Machine Expert HVAC
For any programmer, it is necessary to test PLC programs on simulation. This helps them in checking the logic without any hardware required.
In this software, there are two modes of operation –
  1. Standard mode and
  2. Simulation mode.
In standard mode, you can check the logic by connecting it to the PLC.
But, in simulation mode, you can check the logic by connecting it in simulation. That means, no hardware is required and the programmer can do all the same things that he does when he goes online in PLC.
Refer to the below images for steps to follow in simulation.
Step 1:
Click the Simulation option in the PLC menu as shown below image.
Step 2:
Click Set Address in the PLC menu.
Set Address in PLC
Step 3:
Check whether the IP address of 127.0.0.1 is entered correctly in the address bar of the simulator as shown below image.
IP Address in Schneider PLC
Step 4:
Click Connect in the PLC menu option.
Step 5:
Click Transfer Project to PLC option as shown below image.
Step 6:
After download, a popup window will appear to put the PLC in run mode.
Click OK then you can do the PLC simulation.
Run Simulation in Unity Pro Schneider PLC
With these steps, you can check the logic in simulation mode. Note that the IP address must be 127.0.0.1 for simulation mode. You cannot put any other address for simulation.
Refer to the below image. You just have to click Launch Simulator as shown below.
Simulation in Machine Expert Basic PLC
It too takes the IP address of 127.0.0.1. After the program has been downloaded, just put the PLC in run mode and you can check it in simulation.
Refer to the image below. You just have to click Simulation as shown.
PLC Simulation Machine Expert
But, in this software, there is no IP address assigned for simulation mode.
Refer to the image below. You just have to click Simulation mode as shown.
In this way, we have seen how to simulate Schneider PLCs.
  • Industrial Automation Questions
  • Tank uses 3 Pressure Transmitters
  • Chemical Mixing Process using PLC
  • CNC Programming Definition, Types
  • Measure Speed of Conveyor in PLC
How to Retrieve PLC Project From Memory Card?
Car Wash Program using Functional Block Diagram (PLC)
Ladder Logic Example of Two Motors Interlinked with another Motor
What is a Dry Contact? – Basics of PLC Wiring
What is Distributed IO? – Decentralized Peripherals in PLC
Doll Claw Machine using Omron PLC Programming
What is Alarm Prioritization? – Types of Alarms
PLC Functional Block Diagram for Logic Gates
PLC vs PAC – Understanding the Key Differences and Similarities
PLC Program for Continuous Filling Operation
What is Siemens TDC? – Siemens Control System
Simatic Hardware Configuration
Configuration of Profibus Network in Siemens PLC
PLC Programming Software
FIFO in STL Language in Siemens PLC
How to Code a FIFO Queue in STL Language in Siemens PLC?
SCADA and HMI Systems - Differences, Similarities, Purpose
SCADA and HMI Systems – Differences, Similarities, Purpose
intouch Basics
How to Create Project in Wonderware Intouch?
Communicate with Excel from Intouch SCADA
How to Communicate with Excel from Intouch SCADA?
Traffic Barrier Control
PLC Programming for Traffic Barrier Control
Delta WPL Soft Counter
Delta PLC Counter with Comparison
Thermal Conductivity Detector (TCD)
Thermal Conductivity Detector (TCD) Principle
PLC Program for Positive edge pulse output for one scan cycle
PLC Program for Positive Edge Pulse Output for One Scan Cycle
Switched Mode Power Supply (SMPS)
Hydrocarbons Questions & Answers
30% Feed Control Valve
Purpose of 100% and 30% Feed Control Valves in a Power Plant
Calculate Temperature of Three Wire RTD
Determine the Temperature of 3 Wire RTD
Instrument Calibration Questions
Types of Scan Time in a PLC
Programmable Logic Controller (PLC) Scan Time – Types, Theory
