Reading: High-end Programmable Logic Controller – Schneider PLC
Inst Tools > Blog > PLC Tutorials > High-end Programmable Logic Controller – Schneider PLC
In this article we discussed the high-end programmable logic controller and their features from Schneider PLC.
Last updated: September 28, 2022 4:10 pm
In the first part, we overviewed the PLC’s used for smaller and medium applications. The second part overviews the PLCs used for higher-level applications.
M340 – Mid Range PLCM580 – Ethernet Programmable Controller & Safety PLCPreventa XPS MC, XPS MP – Safety controllers
The first range of high-end processors in Schneider PLC starts with M340 PLC.
It is a very powerful and compact series of PLCs providing high-end efficiency and control solutions in it.
This PLC has a program memory of 4 MB, 128 MB of file storage, and executes 7 instructions in a millisecond. The PLC is a modular type which means it requires a rack to configure.
The communication part comprises a USB port, 3 Ethernet networks, 1 CAN Open, 1 serial port, 4 ASI, and 37 Modbus buses.
The PLC has an embedded web server and file transfer protocols. The main advantage is that the program is stored in a removable SD card.
So, whenever the PLC gets corrupt or damaged, just remove the SD card and insert it in the new PLC.
The software used for programming is Control Expert. You have all the languages available in it.
It is one of the highest-end levels of CPU available in Schneider PLC. It is a smart PLC designed for big manufacturing applications, compatibility with Industry 4.0, and complex hybrid production lines.
A large amount of data flow involved and provision to add multiple communication devices of various types and vendors in it makes it a very suitable PLC for big scale applications.
It has redundant controllers and safety controllers (SIL3) with native Ethernet and cyber-security embedded in it.
This PLC is a safety controller comprising various safety applications. The PLC is Category 4 conforming to EN 954-1 and SIL3 conforming to EN/IEC 61508.
It has 30 types of certified safety functions and libraries built in its programming software. It communicates to PLCs via Modbus, CAN Open, or Profibus network.
Preventa XPS MC, XPS MP - Safety controllers
Schneider range of controllers also has a vast range of distributed IO’s and racks and modules for fail-safe, efficient and hybrid types of communication and programming. It has other controllers and devices too, but we will not cover all the types in this post. I have attempted to cover the most and generally used types of PLCs in Schneider.
In this way, we had an overview of the various types of Schneider PLCs in both the posts; ranging from small-scale to large-scale applications.
  • Electrical Wiring Diagram
  • Simulation in Schneider PLC
  • PID Controller in Schneider PLC
  • Use PLC Flags as Integrity Checks
  • 21 CFR in SCADA and HMI System
PLC Programming Example with Pushbutton and Motor
How to Automatically Close Pop-up in FactoryTalk View Studio?
Mail Box Automation: Programming with Schneider PLC
Surface Grinding Process using PLC Program
#3 PLC Best Practices – Leave Operational Logic in the PLC wherever feasible
Siemens TIA Portal Project: Liquid Temperature Control System
What is a Dry Contact? – Basics of PLC Wiring
Types of PLC
Motor Starter Logic using Siemens PLC Tia Portal
Auto Tiffin Box Filling Station
What is Profinet and How to Configure in Siemens PLC?
PLC System Documentation
OMRON PLC Math Instructions: +(400), -(410), *(420), /(430)
Establish Communication Between Two PLC Via PROFIBUS Protocol
Siemens PLC-to-PLC Communication Project
PLC Program for Tank Heating Control using Heater
PLC Programming for Tank Heating Control using Heater
How to Design a Motor Faceplate in Graphics - SCADA Tutorials
PLC PID tuning parameters
How to Upload PLC Program in Siemens PLC if Upload Icon is Disabled
Upload Option Disabled in Siemens PLC
PLC Load Memory
What is Resources Tab in the Siemens PLC?
Digital Circuits Questions & Answers
Logic Families Questions and Answers
Choppers MCQ
What is a Bus Coupler in Electrical Panel
What is a Bus Coupler in Electrical Panel?
Gas Turbine Troubleshooting Guide
Gas Turbine Troubleshooting Tips
Butterfly Valve
Butterfly Valves Construction, Types, Stem & Bonnet Assembly
DP Transmitter Located 10 feet Beneath the Vessel
Recurring Short Circuit Flash Overs Safety Hazards
Recurring Short Circuit Flash Overs Safety Hazards & Damages
Process Control & Instrumentation Objective Questions – Set 2
