Reading: What is a Head Mount Temperature Transmitter? – Advantages
Inst Tools > Blog > Temperature Measurement > What is a Head Mount Temperature Transmitter? – Advantages
Head mount temperature transmitter converts the signal from RTD or thermocouple into 2 wire loop powered 4 to 20 mA signal.
Last updated: March 18, 2021 11:36 am
3 Min Read
Head mount temperature transmitter receive the signal from the resistance temperature detector (RTD) or Thermocouple (TC), and converts the measured temperature signal into 2 wire loop powered 4 to 20 mA equivalent signal.
Head Mount Temperature TransmitterAdvantages of Head Mount Temperature Transmitter
Head mount transmitter is in housed in the connection head of the sensor and thus the transmitter size is very compact. Moreover, it has minimal wiring because the transmitter is fitted in the head section of the sensor.
The conventional transmitter is mounted far from the sensor, and the additional precautions like lead wire compensation is required to minimize the measurement error. It also requires the long cable which incur additional cost. If the sensor is thermocouple type, then the additional thermocouple compensating cable is required.
However, in the case of head mount transmitter the lead wire compensation is not required as sensor and the transmitter is fitted in the same housing. As a result of this, the measuring accuracy of head mount transmitter is much better than the conventional 2 wire or 4 wire temperature transmitter.
If the head mount transmitter is used for thermocouple sensor, then no thermocouple compensation cable is required.
The head mount transmitter is a universal temperature transmitter and it has many advantages over a conventional temperature transmitter. The head temperature transmitter have a HART communication protocol , and the transmitter parameters like temperature range, type of temperature sensor and other parameters can be remotely programmed.
The salient features of Head Mount Temperature Transmitter are as follows.
  1. It accepts Pt-100 input and Types J/K/T/E/R/S/B/N Thermocouples.
  2. User can configure the transmitter with PC software
  3. Universal setting with HART protocol for various input signal.
  4. It has galvanic and optical isolation and hence signal to noise ratio is more, and loop grounding problem gets eliminated.
  5. It has non-volatile memory with data logging
  6. It has internal temperature sensor for active temperature compensation
  1. Higher measuring accuracy resulting from decreased cable length from sensor to transmitter.
  2. No compensating cable required with use of thermocouples
  3. Easy replacement of the sensor and transmitter.
  4. Easy programming of various input signals
  5. Built-in cold junction compensation
  6. Low signal to noise ratio
  7. Reduced cabling
  8. Remote programming and calibration
  9. Low cost
Author: Satyadeo Vyas
  • Why 4 wire RTD is best?
  • Thermowell Problems
  • Components of RTD
  • RTD Standards
  • Thermocouple Details
Relationship between Temperature Scales
Thermowell Insertion and Immersion Length
How to calculate the tolerance of a RTD sensor
How to calculate Thermocouple Temperature by measuring the output millivoltage
RTD Testing Methods in Calibration Laboratory
Facts on Thermowell Insulation Thickness
Thermocouple Questions and Answers
What is RTD Sensitivity ?
Types of Thermowells
RTD Calculator : Calculate Temperature from Resistance
Resistance Temperature Detectors (RTD) Construction
What is a Probe Thermometer? How to Calibrate and Use it?
Why have been limits imposed on the frequency ratio for thermowells?
Resistance Temperature Detectors Working Principle
Laws of Thermocouples
Three Wire RTD Temperature Compensation
Ambient Temperature Effects on RTD
Thermovcouple Circuit
Thermocouple and its Principle
RTD Calculator Software
Skin Type Thermocouple
Effect of Lead Wire Resistance on RTD
RTD Standards list
RTD Standards
Thermocouple Voltage Curves
What are the Thermocouple Applications?
Formula of 2 Wire RTD, 3 Wire RTD & 4 Wire RTD
Download Free Robotics Software
Step by Step Guidelines to Download Free Robotics Software
Closed Tank Level Measurement using DP Transmitter
Cat and Mouse type Level Indicator
Open-Tank-DP-Level-Transmitter-with-Zero-Suppression-Calibration
DP Level Transmitter with Zero Suppression Calibration
WHILE DO Statement in SCL Language
PLC Questions & Answers
Programmable Logic Controller Questions and Answers
PLC Program to control level of parallel tanks
Parallel Tanks Level Control using PLC Ladder Diagram Tutorial
