Reading: Gas Valve Sizing
Inst Tools > Blog > Control Valves > Gas Valve Sizing
Gas Valve Sizing
Last updated: October 17, 2023 4:02 pm
Control Valves
3 Min Read
Sizing a control valve for gas or vapor service is more complicated than for liquid service, due to the compressibility of gases and vapors.
As a gas or vapor compresses with changes in pressure, its density changes correspondingly. In previous mathematical analyses of fluid flow restriction, one of our assumptions was that fluid density (ρ) remained constant.
This assumption may hold true for some flowing gas conditions as well, provided minimal pressure changes within the path of flow.
However, for most gas control valve applications where the very purpose of the valve is to introduce substantial pressure changes, the assumption of constant gas density is unrealistic.
Gas Valve Sizing
Gas Valve Sizing
Shown here is one of the simpler gas valve sizing equations you will encounter:
Where,
Q = Gas flow rate, in units of Standard Cubic Feet per Hour (SCFH)
Cv = Valve capacity coefficient
ΔP = Pressure dropped across valve, pounds per square inch differential (PSID)
P1 = Upstream valve pressure, pounds per square inch absolute (PSIA)
P2 = Downstream valve pressure, pounds per square inch absolute (PSIA)
Gg = Specific gravity of gas (ratio of gas density to standard air density)
T = Absolute temperature of gas in degrees Rankine (oR), equal to degrees Fahrenheit plus 459.67
This equation holds true only for “subcritical” flow, where the moving gas stream velocity never approaches the speed of sound (Note). Other equations exist for calculating flow rates of gas through control valves in the presence of sonic flow regimes.
Note the inclusion of absolute pressures in this equation, and not just differential pressure (ΔP, or P1 − P2). This is intended to correct for effects related to compression of the gas under pressure.
Note : The ISA Handbook of Control Valves cites this equation as being valid for conditions where the valve’s downstream pressure (P2) is equal to or greater than one-half the upstream pressure (P1), with both pressures expressed in absolute units. In other words, P2 ≥ 0.5P1 or P1 ≤ 2P2. An upstream:downstream pressure ratio in excess of 2:1 usually means flow through a valve will become choked.
Valve sizing is complicated enough, both for liquid and gas service, that the use of valve sizing computer software is strongly recommended as opposed to hand-calculations.
The number of important parameters, nonlinear factors, and alternative equations relevant to control valve sizing are numerous enough to bewilder most technicians (and more than a few engineers).
Valve sizing software will also predict noise levels generated by the valve, and in many cases specify actual valve trim styles offered by the manufacturer for mitigating problems such as noise.
Also Read : Basics of Control Valve Sizing
Progressive Control Valve Sequence
Automated Block Valve (ABV)
How to Troubleshoot Control Valve? – Problems and Solutions
What is Travel Stop in Control Valve?
Difference between BDV and PSV
Air Cylinder Consumption Calculation for Control Valves
What is Reducing Valve ?
Effect of Differential Pressure on Control Valve Lift
What is Pump Cavitation? How to Avoid Cavitation?
Instrumentation Inspection Report
What are Isolation valves? – Purpose, Types, Configurations
Control Valve Positioner Working Principle
What is Pinch Valve ?
Solenoid Valves Selection Guidelines
What is Partial Stroke Test
What is Partial Stroke Test?
Cavitation Test Setup
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
Digital Control Valve Working Principle
Ball Valve Parts
What is Ball Valve ?
Shut down valve
What is Shutdown Valve?
valve control system
Solenoid Valves Practical Problems
Control Valve in PlantPAx Project
Configuration of Control Valve in Studio 5000
Totally Enclosed Fan Cooled (TEFC) Motor
Totally Enclosed Fan Cooled (TEFC) Motors Rampant Winding Burnouts
Career Opportunities in Instrumentation Engineering
Job and Career Opportunities in Instrumentation Engineering
Instrumentation Standards
Allen-Bradley MicroLogix 1000 controller
PLC Switch Actuation Status
Electric Circuits Objective Questions – Set 11
Pressure Transmitters Purged impulse lines - 2
Gas Chromatography Questions & Answers
