Reading: Flip-Flop PLC Programming: Lights with Adjustable Timers
Inst Tools > Blog > PLC Tutorials > Flip-Flop PLC Programming: Lights with Adjustable Timers
Learn Flip-Flop PLC programming techniques to operate lights with adjustable timer intervals with start and stop buttons.
Last updated: October 21, 2024 10:24 pm
7 Min Read
This article discusses the PLC program “Flip-Flop Lamp” using the XG-5000 PLC software. This Flip-Flop program has 2 lights that will light up alternately at adjustable time intervals. The quantity of repetitions of the lights on can be adjusted. Lights 1 and 2 will stop lighting when the quantity of repetitions has been reached. The system can only be Run if the “Set Value” parameter of the timer interval and the “Set Value” parameter of the quantity of repetitions have been Set. This Flip-Flop program has a Start and Stop button to turn the system On and Off, and a Trigger button to Run the system.
Flip-Flop PLC ProgrammingAddressingLights with Adjustable Timers PLC Programming
Buttons used:
  1. The START (P00000) button is used to turn ON the system.
  2. The STOP (P00001) button is used to turn OFF the system.
  3. The TRIGGER button (P00002) is used to RUN the system.
SYSTEM ON (Standby)
When the START button (P00000) is Pressed, the system will be ON in the “Standby” state and when the STOP button (P00001) is Pressed, the system will be OFF.
Before the system is Run, the “Set Value” Timer parameter TIMER1 (T0000) & TIMER2 (T0001) in the memory word SV_TIMER1 (D00002) & SV_TIMER2 (D00003) must be set.  The Parameter “Set Value” of repetitions can be Set on the word memory SV_LOOP (D00000).
SYSTEM RUNNING
When the TRIGGER button (P00002) is Pressed, the system will Run.
Lamp 1 LAMP1 (P00043) will turn ON according to the “Set Value” time that has been set in the word memory SV_TIMER1 (D00002).
Next, Lamp 2 LAMP2 (P00044) will turn ON according to the “Set Value” time that has been set in the memory word SV_TIMER2 (D00003).
Lamp 1 LAMP1 (P00043) and Lamp 2 LAMP2 (P00044) will turn ON alternately with repetitions according to the “Set Value” that has been set in the memory word SV_LOOP (D00000).
The system will Stop if the quantity of repetitions has been reached.
PLC Flip-Flop Lamp Program
Addressing
CommentInput (I)Output (Q)Memory WordMemory BitsTimer
STARTP00000
STOPP00001
TRIGGERP00002
LAMP1 P00043
LAMP2 P00044
TIMER1    T0000
TIMER2    T0001
SYSTEM_ON   M00000
IR_FLIP_FLOP   M00001
SV_LOOP  D00000
PV_LOOP  D00001
SV_TIMER1  D00002
SV_TIMER2  D00003
RUNG 1
In this Rung, the memory bit SYSTEM_ON (M00000) changes to the HIGH state if the START button (P00000) is Pressed. Because it uses the SET Coil Instruction, the memory bit SYSTEM_ON (M00000) will remain in the HIGH state even though the START (P00000) button has been Released.
RUNG 3
Because it uses the RESET Coil Instruction, the memory bit SYSTEM_ON (M00000) will be in the LOW state if the STOP (P00001) button is Pressed.
RUNG 6
In this Rung, the memory bit IR_FLIP_FLOP (M00001) will become the HIGH state if the NO contact of memory bit SYSTEM_ON (M00000) in the HIGH state and the TRIGGER (P00002) button is Pressed and the value in the memory word SV_TIMER1 (D00002), SV_TIMER2 (D00003) and SV_LOOP (D00000) is not equal to zero “0”.
Because it uses the SET Coil Instruction, the memory bit SYSTEM_ON (M00000) will remain in the HIGH state even though the TRIGGER (P00002) button has been Released.
RUNG 16
In this Rung, if the NO contact of memory bit IR_FLIP_FLOP (M00001) in the HIGH state, then Timer TIMER1 (T0000) will start counting. When Timer TIMER1 (T0000) finishes counting, the NO contact of Timer TIMER1 (T0000) will be in the HIGH state and Timer TIMER2 (T0001) will start counting.
When Timer TIMER2 (T0001) has finished counting, Timer TIMER1 (T0000) and TIMER2 (T0001) will be OFF, because the NC contact of Timer TIMER2 (T0001) in the HIGH state.
RUNG 24
In this Rung, if the NO contact of the memory bit IR_FLIP_FLOP (M00001) in the HIGH state, then the Output LAMP1 (P00043) becomes ON. The Output LAMP1 (P00043) will be OFF if NC contact of
Timer TIMER1 (T0000) in HIGH state.
Output LAMP2 (P00044) will be ON if the NO contact of Timer TIMER1 (T0000) in the HIGH state.
Flip-Flop Lamp Logic
RUNG 32
In this Rung, if the NO contact of the memory bit TIMER2 (T0001) in the HIGH state, then the value in memory word PV_LOOP (D00001) will increase (+1), because it uses the ADD instruction.
RUNG 39
In this Rung, if the NO contact of memory bit SYSTEM_ON (M00000) in the HIGH state and the value in memory word PV_LOOP (D00001) is equal to SV_LOOP (D00000), then the memory bit IR_FLIP_FLOP (M00001) becomes in the LOW state and the value in memory word PV_LOOP (D00001) will be zero “0”, because the MOV instruction moves the zero value “0” to memory word PV_LOOP (D00001).
  • PLC 1 Button To Activate 4 Different Machines
  • Vijeo Designer software Import and Export
  • FactoryTalk View Studio Import and Export
  • System Architecture in Industrial Automation
  • Structured Text vs. Instruction List Languages
Types of PLC
Software Redundancy in Siemens PLC – Hardware versus Software
PLC Timer Example: Sequential Control of Three Lights with Reset
What is CODESYS? Why Do You Need to Learn it?
Automatic Curtain Control – PLC Programming Solution
Glass Cutting and Polishing Machine: PLC Automation Solution
  • Nik Kinze says:
    January 14, 2025 at 1:56 am
    I see this as more of an advertisement of how to use as many different obtuse methods as possible,
    If you are just trying to demonstrate a Flip/Flop, you should be able to do it with less than rungs.
    If you have been doing this as long as I have, you know to use economy in your code. Each line adds up to execution time, which increases scan times.
    Keep your programs as simple as possible, document your code so that a 5th grader could follow it, and save the bells and whistles for where you need them.
Concept of Interlocking in PLC
Single-Acting Cylinder Control using Proximity Sensor
Example PLC Program
Product Painting PLC Program using Omron CX-Programmer
Free InTouch SCADA Tutorial Course for Beginners
Communication between Wincc and Tia Portal
PLC Program for motor operation based on time cycle
PLC Motor Operation based on Time Cycle Sequence – Program
PLC Ladder Diagram program
Contacts and Coils in PLC Ladder Logic
Motor Clock Wise Operation using PLC
CW and CCW Operation of Motor from Same Push button
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
PLC Cabinet
PLC Programming Videos
Example of PLC Programming based on Logic Circuit
HART Communication Tutorial 2
Transmission and Distribution Objective Questions and Answers
175+ Transmission and Distribution Objective Questions and Answers
Advanced Skills Required for a PLC Programmer to Get a Job
Electric Circuits Objective Questions – Set 3
Drum water level control
Closed Loop Control System : Boiler Water Level Control System
Analog Modulators Objective Questions
Failed Letdown Valve
Failed Letdown Valve Shuts down a Urea Plant Several Hours
