Reading: FactoryTalk View Studio – Import and Export Tutorial
Inst Tools > Blog > PLC Tutorials > FactoryTalk View Studio – Import and Export Tutorial
Learn how to save time and effort in your industrial automation projects with FactoryTalk View Studio import and export options.
Last updated: September 17, 2024 3:27 pm
When a programmer is working on a project, and then working on a similar one next time, he does not want to rework it from the start. So, he requires options where he can copy-paste the tools and objects for time-saving ideas. It saves project cost and manpower.
FactoryTalk View Studio Import and ExportText Strings Import and ExportDisplay Screens Import and ExportRecipe Editor Import and ExportAlarms Import and ExportTags Import and Export
Many industrial automation software providers give options to import and export some objects easily in their software.
One of the most used ones is FactoryTalk View Studio of Rockwell Automation. In this post, we will see the import and export options in FactoryTalk View Studio.
The texts that you have used in a project can be used in some other project by exporting and importing the language objects, popularly known as text strings in this software.
Refer to the first image below. Here, you have to select languages and then you will be asked to import or export, either in text or Excel format.
FactoryTalk View Studio - Import and Export Tutorial
The most recommended one is an Excel file due to easy use. Once done, the Excel file looks like in the second image.
Export project in FactoryTalk View Studio
The first row shows the project name, the second row shows the component type, the third row shows the exact location of the text, the fourth row shows the label of the text and the last row shows the name of the text used in the screen.
This is one feature that every programmer demands to save time. Suppose you have created 60 screens in a project, and you require the same 40 screens out of that in a similar project. Instead of redeveloping, just export and import the screens.
The software stores the information exported and imported in XML format. Right-click the displays option and you get to export and import the screens whichever you require.
When you are creating recipes in HMI or SCADA, you will mostly require the same in similar projects, as the settings will be the same. So, you can export and import recipe groups in this software.
Refer to the below image. You have to click Recipe+ Editor and click open. The window shown will open, where you can export and import recipes. The information is stored in CSV formats.
Import configuration in FactoryTalk View Studio
Alarms are the most basic feature of a graphic display. If a project is very large-scale and has enormous alarms, you can export and import them into a different project, instead of redeveloping. The software stores this information in Excel format or XML format. The most recommended one is an Excel file, which is very easy to edit.
Refer to the below image, where you get to edit all the properties of a FactoryTalk View (FTV) alarm. This makes tasks much easier to complete.
FactoryTalk View Studio project import tutorial
This is one very interesting feature of this software. As you know, one of the best advantages of Rockwell Automation is that you get to access tags of PLC, without actually opening the program, through RSLinx software.
Now, when designing tags in the HMI or SCADA backup, you can export and import the tags, by clicking the tag import and export wizard in the tools option, as shown in the image below. The data is stored in csv format.
Step-by-step import export in FactoryTalk View
In this way, we saw the import and export options available in FactoryTalk View Studio software.
  • Vijeo Designer software Import and Export
  • Why different PLC Programming Languages?
  • Create Templates in FactoryTalk View Studio
  • Configure PlantPAx Library in Factory Talk Studio
  • Import PlantPAx Add-On Instruction in Studio 5000
Electrical Switches Principle & Types
Connecting Blocks in Functional Block Diagram – Studio 5000
Automatic Box Filling System using PLC Programming
PLC Controlled Conveyor and Weighing with Labeling Automation
Heating and Mixing of Products using PLC Example Tutorial
PLC Program Example on Multiple LEDs using Set Coil
Drive Multiple Speeds with Different Reference using PLC
SCADA and HMI Systems – Differences, Similarities, Purpose
Positive and Negative Edges using Statement List Language
Smart Spray System using Wecon PLC
Electrical Earthing Calculations
PLC Interlock Logic with First Input Priority
PLC Program Upload
How to Upload Siemens PLC Programs?
Conveyor Control with Main Motor and Backup Motor
RSLogix 5000 PLC Programming Procedure
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
PLC Emergency Stop Example Program
PLC Timer Application in Security Camera Recording
Elevator Control
Safety interlock for motor starters in Siemens PLC
Motor Starter Logic using Siemens PLC Tia Portal
Measurement of Impedance Objective Questions
Gas Detection System Abbreviations
Level Gauges
Level Gauge Design
Non-variable reducing valves
What is Reducing Valve ?
What is an ELV System - Extra Low Voltage
What is an ELV System? – Extra Low Voltage
DP Transmitter Wet Leg Compensating Impulse Line
Questions on DP Transmitter Wet Leg Compensating Impulse Line
Top 100 Proteus Design Suite Projects for Engineering Students
Reciprocating Piston Meters
Overview of Positive Displacement Flow Meters
