Reading: Emergency Stop Switch Spurious Trip
Inst Tools > Blog > Control Systems > Emergency Stop Switch Spurious Trip
In this article, you will learn about the emergency stop push button switch spurious trip and how to avoid them.
Last updated: May 3, 2023 9:54 am
vicky
Control Systems Electrical Basics PLC Tutorials
3 Min Read
Today we will discuss about one of the most important components used in the Instrumentation system i.e. NC contact. This is widely used in Emergency Stop or Stop pushbutton as a fail-safe condition is needed there.
Emergency Stop Switch Spurious TripInternal Components of SwitchProblem Solution
NC Contact with Push button
This system may lead to spurious trips in long run. Yes, you read it right SPURIOUS TRIP!
The switch Normally-Close (NC) contact used has a simple internal as shown below. The main components are spring and contact in a switch.
Switch Internal Components
Now as per the fail-safe concept, the stop button contact should be closed in non-actuated conditions for many hours and days as per the required application. Whenever the pushbutton is pressed, which is maintained mainly by a spring and contact, the contact should open.
Now due to the aging effect, this spring may fail or its strength may be lost after some time. Sometimes these issues may create an open contact and actuate the pushbutton without actually pressing the stop button, which is a SPURIOUS TRIP.
Problem Solution
To avoid these types of problems, 2 out of 2 configurations should be used. For this, 2 sets of contacts in a single pushbutton must be used in place of 1 set of contact of the Normally-closed push button.
Emergency Stop Push button
Whenever both contacts are actuated then only, stop/trip action should take place i.e. both contacts should be connected in parallel.
If the switch contacts are taken as Digital Input in PLC or DCS logic, then 2 different DI should be used so that the health of both pushbuttons can be monitored in the logic, i.e. alarm should appear whenever a contact is actuated such that respective action can be configured in the logic.
How to Check Switch Contact Status?
In non-actuated conditions (for NC contact), resistance should be below 1 ohm, while in the actuated condition it should give resistance in mega Ohm.
When to Check Switch Contact healthiness?
We have to check the switch contact healthiness every 3 years or during a major plant shutdown.
If your plant has any specific control philosophy then you have to follow the recommended documents or standards.
  • Scan Cycle in SIEMENS PLC
  • Cloud-Based SCADA Projects
  • PLC-based Gas Detection System
  • Create New Project in Studio 5000
  • Rockwell Allen Bradley PLC Projects
Structured Text PLC Example for Motor Interlocking and Control
Why is HV Testing important in Electrical Panels?
What is Function Module in Siemens PLC?
D Flip Flop PLC Ladder Logic
  • Cesar M says:
    July 14, 2023 at 11:18 am
    The ‘aging” causing the effect of having spurious trip with the switch opening the contacts (Normally closed), will it be a permanent spring failure? or can it be that the spring work normally after the spurious trip? Should we recommend a switch / pushbutton / relay with two set of NC contacts? thanks
Complete PLC Project: Traffic Light Auto and Manual Automation
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
Introduction to SCADA
S7-1200 Hardware Configuration – Siemens PLC Tutorials
Difference Between MCB and RCBO
Motor Control using Modbus Communication and Hardwired Signals
SCADA Graphics
What is SCADA ? How does SCADA Works ?
Mixing Tank Relay Circuit
PLC Program for Mixing Tank
Difference Between Wifi and Industrial Wireless
The STAR-DELTA Auto And Manual Program
What is Trunking
Difference Between Trunking and Conduit
Free Download PLC Simulator using Excel
PlantPAx DCS
Introduction to PlantPAx Distributed Control System
Formula of AMP, KW, KVA, HP for AC and DC Voltages
two-way communication between PLC systems
Transferring Data Across PLC Systems – TSEND_C and TRCV_C
Difference Between Adhesion and Cohesion
Smart HART Transmitter
water filter level control system
Practical Process Control System Questions & Answers – 6
Voltage and Current Phase Relationships in an Inductive Circuit
Gas detection system Interview Questions
Interview Questions on Gas detection System
Features of Scada Which are Must in an IoT System
baffle nozzle Operation
Practical Pneumatic Instruments
