Reading: Top 50 Electrical Switch Questions and Answers
Inst Tools > Blog > Electrical MCQ > Top 50 Electrical Switch Questions and Answers
Study the top 50 electrical switch questions and answers focusing on definitions, types, functions, and wiring for students and engineers.
Last updated: July 25, 2024 6:02 am
Electrical MCQ Electronics MCQ Instrumentation MCQ
12 Min Read
Electrical Switch QuestionsWhat does SPST stand for in electrical switches?What does DPDT stand for in electrical switches?What does SPDT stand for in electrical switches?How many positions does a DPDT switch have?What is the main function of a DPST switch?Which switch type allows a single circuit to be switched between two different outputs?What type of switch would you use to connect or disconnect two circuits at the same time?How many terminals does a DPST switch have?Which type of switch is commonly used in changeover circuits?What is the primary use of a SPST switch?What type of switch allows independent control of two circuits?Which switch has three terminals and can route a signal to one of two outputs?What does a DPST switch typically control?Which switch type can change the direction of a motor by reversing connections?How many output connections does a SPDT switch have?What kind of switch is used to make or break a single connection?Which type of switch can control three circuits with a single toggle?What does SP3T stand for in electrical switches?How many terminals does a 4PST switch have?Which switch type is used for changing between three different outputs?What does TPDT stand for in electrical switches?How many positions does a 4PDT switch have?Which switch can control four circuits independently but simultaneously?What is the primary application of a SP4T switch?How many circuits can a 3PST switch control?More Types of Electrical SwitchesWhat does DP3T stand for in electrical switches?What does a 3PDT switch control?What is a common use for a 3PDT switch?What does 4P3T stand for in electrical switches?Which switch type allows selecting one of four circuits from a single input?What is the primary function of a 4PST switch?How many terminals does a TPST switch have?Which switch type is used for routing signals to three different outputs?How many positions does a DP3T switch have?Which switch type allows for selecting between multiple power sources?How many terminals does a 4PDT switch have?Which switch type is used for reversing the direction of a three-phase motor?How many poles does a TPDT switch have?Which switch is used to control four circuits with each circuit having two possible connections?What is the key feature of a 4PDT switch?How many terminals are there in a SP4T switch?Which switch type allows for selecting one of three circuits from a single input?How many positions does a TPST switch have?Which type of switch is ideal for changing the path of a signal between multiple circuits?What does 3PST stand for in electrical switches?How many terminals does a DP3T switch have?Which switch type allows for the independent control of four circuits?What is a common application for a DP3T switch?How many terminals does a 4P3T switch have?Which switch type is used for selecting between four different signals?
This electrical switches video provides the detailed explanations for the first 25 questions.
Electrical Switch - Basic Engineering Questions and Answers
Question 1
A. Single Pole Single Throw
B. Single Pole Single Toggle
C. Single Phase Single Throw
D. Single Point Single Toggle
Show the Answer
Question 2
A. Dual Pole Dual Throw
B. Double Pole Double Toggle
C. Double Pole Double Throw
D. Double Point Double Throw
Show the Answer
Question 3
A. Single Pole Dual Throw
B. Single Pole Double Throw
C. Single Phase Double Throw
D. Single Point Dual Throw
Show the Answer
Question 4
A. Two
B. Four
C. Six
D. Eight
Show the Answer
Four
Question 5
A. Control two circuits simultaneously
B. Control the direction of current flow
C. Connect two power sources
D. Break two circuits at the same time
Show the Answer
Question 6
A. DPDT
B. SPST
C. SPDT
D. DPST
Show the Answer
SPDT
Question 7
A. SPDT
B. DPDT
C. SPST
D. DPST
Show the Answer
DPST
Question 8
A. Two
B. Four
C. Six
D. Eight
Show the Answer
Four
Question 9
A. SPST
B. DPST
C. SPDT
D. DPDT
Show the Answer
DPDT
Question 10
B. On/off control of a single circuit
C. Switch between two outputs
D. Reverse polarity
Show the Answer
Question 11
A. SPST
B. DPST
C. SPDT
D. DPDT
Show the Answer
DPDT
Question 12
A. SPST
B. DPST
C. SPDT
D. DPDT
Show the Answer
SPDT
Question 13
A. One circuit
B. Two circuits independently
C. Two circuits simultaneously
D. Three circuits
Show the Answer
Question 14
A. SPST
B. SPDT
C. DPST
D. DPDT
Show the Answer
DPDT
Question 15
A. One
B. Two
C. Three
D. Four
Show the Answer
Two
Question 16
A. DPST
B. SPDT
C. DPDT
D. SPST
Show the Answer
SPST
Question 17
A. SP3T
B. DPDT
C. 3PST
D. 3PDT
Show the Answer
3PDT
Question 18
A. Single Pole Triple Throw
B. Single Point Triple Throw
C. Single Phase Triple Throw
D. Single Pole Third Throw
Show the Answer
Question 19
A. Four
B. Eight
C. Twelve
D. Sixteen
Show the Answer
Eight
Question 20
A. SPST
B. SP3T
C. DPDT
D. TPDT
Show the Answer
SP3T
Question 21
A. Triple Pole Dual Throw
B. Triple Pole Double Toggle
C. Triple Phase Double Throw
D. Triple Pole Double Throw
Show the Answer
Question 22
A. Two
B. Four
C. Six
D. Eight
Show the Answer
Four
Question 23
A. 4PST
B. 4PDT
C. SP4T
D. DPST
Show the Answer
4PDT
Question 24
A. Switching a single circuit on/off
B. Switching between four outputs
C. Controlling four circuits simultaneously
D. Reversing motor direction
Show the Answer
Question 25
A. One
B. Two
C. Three
D. Four
Show the Answer
Three
The following video provides explanations for the next electrical switch questions.
Types of Electrical Switches: Common Questions and Answers
Question 26
A. Double Pole Three Throw
B. Double Pole Triple Throw
C. Dual Pole Triple Throw
D. Dual Phase Triple Throw
Show the Answer
Question 27
A. One circuit
B. Two circuits
C. Three circuits
D. Four circuits
Show the Answer
Three circuits
Question 28
A. On/off control of a single circuit
B. Switching between two outputs
C. Reversing motor direction
D. Controlling three circuits simultaneously
Show the Answer
Question 29
A. Four Pole Triple Throw
B. Four Point Triple Throw
C. Four Phase Triple Throw
D. Four Pole Three Toggle
Show the Answer
Question 30
A. SPST
B. DPST
C. 4PDT
D. SP4T
Show the Answer
SP4T
Question 31
A. Control one circuit
B. Control two circuits
C. Control four circuits independently
D. Control four circuits simultaneously
Show the Answer
Question 32
A. Three
B. Six
C. Nine
D. Twelve
Show the Answer
Six
Question 33
A. SPST
B. SPDT
C. SP3T
D. DPDT
Show the Answer
SP3T
Question 34
A. Three
B. Six
C. Nine
D. Twelve
Show the Answer
Six
Question 35
A. SPST
B. SPDT
C. DPDT
D. DP3T
Show the Answer
DPDT
Question 36
A. Eight
B. Twelve
C. Sixteen
D. Twenty
Show the Answer
Twelve
Question 37
A. SPST
B. DPST
C. 3PDT
D. SPDT
Show the Answer
3PDT
Question 38
A. One
B. Two
C. Three
D. Four
Show the Answer
Three
Question 39
A. SPST
B. DPDT
C. 4PDT
D. SP4T
Show the Answer
4PDT
Question 40
A. Controls one circuit
B. Controls two circuits
C. Controls three circuits
D. Controls four circuits
Show the Answer
Question 41
A. Four
B. Five
C. Eight
D. Ten
Show the Answer
Five
Question 42
A. SPST
B. SPDT
C. SP3T
D. DPDT
Show the Answer
SP3T
Question 43
A. One
B. Two
C. Three
D. Four
Show the Answer
Two
Question 44
A. SPST
B. SPDT
C. SP3T
D. DPDT
Show the Answer
SP3T
Question 45
A. Triple Pole Single Toggle
B. Triple Pole Single Throw
C. Triple Phase Single Throw
D. Triple Point Single Throw
Show the Answer
Question 46
A. Four
B. Six
C. Eight
D. Nine
Show the Answer
Eight
Question 47
A. SPST
B. DPDT
C. 4PDT
D. SP4T
Show the Answer
4PDT
Question 48
A. On/off control
B. Reversing motor direction
C. Signal routing
D. Power isolation
Show the Answer
Signal routing
Question 49
A. Four
B. Eight
C. Twelve
D. Sixteen
Show the Answer
Twelve
Question 50
A. SPST
B. DPST
C. SP4T
D. 4PDT
Show the Answer
SP4T
  • Switch Types and Common Terminology
  • Electrical Switches Working Animation
  • Shutter Door Control – Motor and Switches
  • Electrical Ladder Diagram Control using Timers
  • What is a Motor Disconnector Switch?
Thermo Electric Transducers Objective Questions
Electrical Engineering Documents – Engineers Questions
Instrumentation Engineering Materials Test
Electric Circuits Objective Questions – Set 3
Feedback Control Loop Questions & Answers
250+ Electronic Measurements and Instrumentation MCQ Questions
Induction Motor Rotor EMF, Current and Power
Interactive Control Valve Parts Quiz: Drag & Drop Challenge
Nuclear Plant Sensors and Detectors Quiz
Flow and Level Measurement Quiz
Electrical Machines MCQ Series 7
Encoder MCQ – Electrical Drives Technology
Frequency Measurement Objective Questions
Electronic Devices & Circuits Quiz – Set 9
Electrical Welding Multiple Choice Questions and Answers
Electrical Welding Multiple Choice Questions and Answers (MCQ)
Top 200 Electrical Engineers Objective Questions and Answers
Common Valve Abbreviations
Common Valve Abbreviations in US Engineering Drawings
Synchronous Machines EMF Polygon Questions
Electric Circuits Objective Questions – Set 11
Power Systems MCQ Series 8
Thermocouple Temperature Ranges
Thermocouple Temperature Range Questions and Answers
Synchronous Motor Power Factor Correction Questions
Plant Air Storage Tank
PM of Instrument Air Compressor
PM of Instrument Air Compressor in Oil & Gas Plants
Air Filter Regulator Working Principle Animation
Allen-Bradley MicroLogix controller
Programmable Logic Controller (PLC) Questions and Answers – 16
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
PID Controller Functionality
PID Controller Loop Tuning Tips
Electrical Motors Interview Question And Answers
Synchronous Machines Distributed Winding Quiz
