Reading: Electrical Power Grid Automation
Inst Tools > Blog > Electrical Basics > Electrical Power Grid Automation
Learn electrical power grid automation and some general industrial automation techniques in power distribution and generation.
Last updated: May 24, 2023 1:55 pm
Electrical Basics
The electrical grid is a very important part of power distribution. Be it power generation, transmission, or distribution, an electrical grid is a must for all these systems. Due to such a large amount of electricity handling involved in it, some proper and reliable control must be required in it.
Electrical Power GridSmart Grid Automation
Improper control can hamper the electricity cycle and harass hundreds of consumers in a very short span of time. So, industrial automation technologies are widely used in an electrical grid, to operate it safely and also handle load demands efficiently.
In this post, we will learn some general automation techniques used for an electrical grid.
First of all, let us understand what an electrical grid is. Electricity has three modes of operation – generation, transmission, and distribution. When electricity is generated, it needs to be transmitted to a substation first, and after the substation, it will be distributed to all the local consumers.
The substation handles the electricity at a local range. For example, suppose you are living in a radius of 500 sq. km; then you will have 2-3 substations that will manage the load distribution required in such an area for various types of consumers. But, this local range is not enough when consumers increase or when there is a requirement for an uninterrupted power supply for critical areas. In that case, a grid is required.
As the name implies, an electrical grid is a complete network of substations, power generation plants, and distribution centers. It operates in a very wide range and handles electricity for thousands of kilometers and even beyond.
The electrical grid comes in two types – regional and national. A regional grid will interconnect different substations and other systems; whereas a national grid will interconnect regional grids.
Because an electrical grid handles such a large amount of electricity, industrial automation is mostly used for smartly managing them. A large amount of data can be handled and security, and efficiency is increased to a great extent with the use of automation.
Let us have a look at some of the techniques of automation used in electrical grids.
  • Solutions are available for advanced metering infrastructure and meter data management, which provide accurate data analysis and storage capabilities. Because energy meters are an integral part of electrical systems, due to these features, they can also be integrated with SCADA systems, providing historical trends and storing their data in a huge capacity. This can be used in increasing billing efficiency, network power inventory balancing, outage management, load profiling, forecasting, remote operation of meters from any SCADA system, and reporting.
  • Electrical devices which employ automation data in them are built in such a way that they can survive harsh environments with ease. Also, they are highly electromagnetic compatible (highly resistant to electromagnetic noise). Due to this, you get data from them easily with any environmental condition, and helps to integrate with SCADA easily.
  • Because energy devices are sharing such a large amount of data with network systems, cybersecurity is a must. They are equipped with cybersecurity features, to help them protect them from theft, hacking, or any other type of attack. This makes your data well-secured and reliable to use.
  • Smart solutions in grid automation use optical fibre cables for handling data at large distances. If traditional wires were used, then data communication distance would be small and you would not get data quickly too. Such a lag in data is of no use in fast automation solutions for grid networks.
  • With automation, you can have advanced earth-fault detection and protection, which helps in protecting the devices from damage.
  • Almost everything, from voltage regulators to switchgear to sensors and controllers are integrated with enterprise-level software and secure communications, to increase productivity, efficiency and reduce costs.
  • What is a Ground Rod?
  • Types of Stepper Motors
  • Electrical Conduit Seal
  • Electrical Overheating
  • Motors Efficiency Classes
How to Read the Nameplate of a Motor?
Benefits of SIMOCODE over Intelligent MCC
Differences between Watts and Volt Amps
Applications of Variable Frequency Drive (VFD)
Advantages of Three Phase System Compared to Single Phase System
What Happens When a Pump Runs Dry? How to Avoid it?
What is Electrical Busbar? Types, Advantages, Disadvantages
Proper Sizing of Conductors
What is insulation? How to Choose the Insulation Material?
Difference between Stepper Motor and Servo Motor
Working Principle of Overload Relay
Partial Discharge in Power Lines and its Detection through Sensors
Electrical Maintenance Engineer's Biggest Enemy
Electrical Components Overheating – Causes, Troubles, Prevent
Burst Transformers Root Cause Analysis
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
What is a Current Transformer
What is a Current Transformer?
Time Delay Fuse
What is a Time Delay Fuse? – Principles and Advantages
MCCB (Molded Case Circuit Breaker)
Industrial Circuit Breakers – Most Common Types – Principle
Motor Disconnector Switch
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Armoured cable
What is an Armoured Cable? Classification of Cables
Change-of-Quantity Flow Measurement
A typical wiring diagram from Field Transmitter to Control Room
How to Wire a Field instrument to Control Room with Example
Dissolved Oxygen Analyzers Interview Questions
Dissolved Oxygen Analyzer Interview Questions & Answers
Why does SMPS Need isolation - Switch Mode Power Supply
Why does SMPS Need isolation? – Switch Mode Power Supply
Common Valve Abbreviations
Common Valve Abbreviations in US Engineering Drawings
Override Control Functions
What is Override Control? – Need & Applications
Synchronous Motors Power and Torque Questions
Failure Demand in Safety Control Circuit
Safety Instrumented System Module Failure
