In this article, you will learn what is a displacement transducer, the types of transducers, their advantages, disadvantages, and their applications.
What is a Displacement Transducer?
- A displacement transducer converts the motion of an object or machine into electromagnetic, magneto-electric, or electrostatic signals.
- The signals received from these transducers are read and interpreted into data.
- Displacement transducers are classified based on a motion such as linear & rotary.
- This transducer helps to measure the physical distance between the sensor & a target.
- Generally, these transducers measure static & dynamic displacements & for measuring the vibration of an object.
- The displacement value varies from micro inches to a few feet.
- The working principle of displacement transducers is based on reliable inductive measurement.
- These transducers are very easy to use, & rugged, to attain high precision. Displacement transducers yield reliable measurement results in various areas of production, research & development.
- These transducers are used for both direct and indirect displacement measurements.
Types of Displacement Transducer
The basic types of displacement transducers are mentioned below.
- Strain Gauge
- Resistive Transducer
- Capacitive Transducer
- Inductive Transducer
- LVDT
- RVDT
Strain Gauge
- A strain gauge displacement transducer changes physical quantities into mechanical strain.
- This mechanical strain is changed into a proportional electrical signal
- The strain gauges are mounted on the elastic body.
- A strain gauge-type displacement transducer is mainly used to measure the displacement in the range of 0 to 10 mm.
- The length of the Strain Gauge transducer is short compared to LVDT & is free from electromagnetic effects.
- This strain gauge transducer is highly stable & reliable.
- A resistive transducer is known as a variable resistance transducer.
- This works on the principle of variable resistance transduction.
- It consists of resistive elements along with movable contact.
- This transducer is the most frequently used displacement transducer.
- The motion may be translational rotational or helical or a combination of either motion.
- This measures various physical quantities like pressure, displacement, force, temperature, and vibrations and converts them into an equivalent electrical signal.
- A capacitive transducer is a type of passive transducer.
- Capacitive transducers detect motion, chemical composition acceleration, electric field, pressure, and so on.
- Due to the applied voltage across the capacitor plate equal & opposite charges are generated on transducer plates separated by the dielectric material.
- This transducer works by using external power.
- This transducer measures pressure, displacement, movement, force, velocity & other parameters.
- This transducer works on the principle of variable capacitance.
- The capacitance of this transducer varies due to some factors like dielectric constant, & overlapping of plates.
- An inductive transducer is another type of displacement transducer compared to resistive and capacitive transducers.
- An inductive transducer works on the principle of transduction or electromagnetic induction.
- Measurement of some necessary physical quantities such as displacement, force, velocity, pressure, acceleration, torque, mutual inductance, or self-inductance varies.
- Inductive Transducer is further classified as a Linear Variable Differential transducer or Rotary Variable Differential Transducer.
- But LVDT is considered the best example of an Inductive Transducer.
Linear Variable Differential Transformer (LVDT)
- The Linear Variable Differential Transformer (LVDT) is one type of displacement transducer.
- It is an electromechanical device.
- This coil generates proportional output voltage relative to the displacement of the iron core and transformer.
- This transducer consists of three coils symmetrically spaced with each other.
- Here the primary coil is the center coil & secondary coils are the remaining two coils.
- The secondary windings are identical concerning the turning number and placement of both sides of the primary winding.
- These coils are mainly connected in series & positioned equally around the main coil.
- A sine volt is used to excite the primary coil.
- A movable core generates an electrical signal in proportion to its displacement.
- When the core is in the middle a sinusoidal voltage appears across two secondaries.
Rotary Variable Differential Transducer (RVDT)
- A rotary variable differential transducer (RVDT) is used to measure rotational angles.
- It is an electromechanical transducer that gives a variable AC output voltage in linear proportionality to the angular displacement.
- This transducer also works on the LVDT principle both RVDT and LVDT work similarly.
- RVDT transducer consists of two windings, such as one primary winding and two secondary windings.
- LVDT uses a flexible cylindrical iron core, whereas RVDT uses a rotary ferromagnetic cam-type core.
- RVDT senses the angular displacement and converts it to the proportional electrical signal.
- RVDT features linearity over +40 or -40 degrees.
- The sensitivity of RVDT ranges from 2mV to 3mV per degree of rotation.
Circuit Diagram of Displacement Transducer
The displacement transducer shown below diagram is an inductive transducer.
- This circuit measures displacement with an Inductive transducer.
- The transformer consists of one primary winding & two secondary windings.
- The endpoints of two secondary windings are linked to each other.
- Here, both these secondary windings are connected in a series position.
- The Primary voltage “VP” is applied at the primary winding of the transformer.
- Let, ????????1 & ????????2 be voltage developed across every secondary winding of the transformer.
- Finally, the output voltage ‘V0’ is generated across the first points of secondary windings.
- So the output voltage at the secondary of the transformer is given as V0 = VS1 – VS2.
- The output voltage generated at the secondary of the transformer has dissimilarity between VS1 & VS2 since the transformer is the differential transformer.
- If the core is placed at the center, then the induced voltages across two windings S1 & S2 are equivalent, so output voltage becomes zero (V0=0) hence there is no displacement at this condition.
- If the core is placed above the center, then the induced voltages generated across S1 are maximum (V1>V2).
- Similarly, if the core is placed below the center then the induced voltages generated across S1 are maximum (V2>V1).
- So in above both cases, we have two displacements one is upward & other is downward.
- Hence, the magnitude of output voltage ‘V0’ is in proportion to the core position relative to the center.
- To measure the displacement of the body we must connect it to the central core.
- The middle point of the core varies when the body shifts in a straight line which makes the output voltage ‘V0’ vary accordingly.
Advantages of Displacement Transducer
The advantages of displacement transducers are mentioned below.
- Linearity is excellent.
- Accuracy is extremely high in wide temperature ranges.
- Resolution is up to 0.01 µm.
- They are tolerant to high magnetic fields.
- The design is strong with excellent stability
- These transducers can be fixed in any direction
- Power consumption is very less.
- hysteresis loss is low
- This transducer has no or minimum friction.
- High measurement range.
- Sensitivity is high
- Alignment & maintenance is easy.
Disadvantages of Displacement Transducer
The disadvantages of displacement transducers are mentioned below.
- Requires very high displacement to generate high voltage.
- Requires shielding due to being more responsive to the magnetic field.
- The performance is affected by vibrations & temperature changes.
- An external demodulator is required to generate DC output.
- Limited dynamic response.
Applications of Displacement Transducer
Displacement transducers are used in the following applications.
- Measurement of relative movement between the sensor tip & the rotating shaft.
- CNC machines to measure displacement.
- To measure the thickness of rolled metal sheets
- For measuring force, acceleration & pressure
- Within flight control systems
- Hazard Identification
- Smart Sensors in Industry
- Delta HMI and VFD Logic
- Motor Temperature Sensors
- MOVE Instruction in PLC
