Reading: Differential Pressure Transmitter with 5 Way Manifold Valve
Inst Tools > Blog > Practical Questions > Differential Pressure Transmitter with 5 Way Manifold Valve
Last updated: November 13, 2020 7:33 pm
Practical Questions Pressure Measurement
2 Min Read
Some differential pressure transmitters are equipped with 5 way valve manifolds. These valve networks allow for blocking, equalizing, and bleeding of the transmitter’s two pressure ports, the valves being arranged in this pattern:
Differential Pressure Transmitter5 Way Manifold Valve
Shown using standard P&ID symbols – instrumentation equivalent of an electrical schematic diagram – the transmitter and manifold arrangement looks like this:
5 Way Manifold Valve Schematic Diagram
Identify the normal, operating valve positions (open/closed) for a five-valve manifold. Describe the proper sequence of manifold valve operation to successfully prepare the transmitter for removal from the process.
Why do you think we have such things as 5-valve manifolds? What can be done with this manifold that cannot be done with a three-valve manifold?
Answer:
Normal valve positions:
  • Both block valves open.
  • Both equalizing valves closed.
  • Vent valve closed.
Removing differential pressure transmitter from service:
  • Close one block valve.
  • Open both equalizing valves (which one first does not matter).
  • Close the other block valve.
  • Open the vent valve.
  • Tag all valves, notifying of transmitter’s planned return time/date.
  • Disconnect the transmitter from the manifold.
Restoring the transmitter back to service is as simple as reversing all the steps taken to remove it from service (i.e. go through the list backwards, doing the reverse of each instruction).
Difference between 5-valve manifold and 3-valve manifold?
One feature that 5-valve manifolds provide over 3-valve manifolds is the ability to route a vent tube to a remote (safer) location, for use with particularly hazardous process fluids.
5-valve manifolds allow for in-place transmitter calibration, provided one of the ∆P transmitter’s sides has an atmospheric vent. By connecting the calibrating pressure source to the vent line, one can route the calibrating pressure to either side of the transmitter (only), while keeping the other side vented.
  • Instrument Hook Up Diagram
  • Instrumentation and Control MCQ
  • Pressure Gauge Datasheet
  • Temperature Controller Problem
  • Pressure Measurement MCQ
Credits: Tony R. Kuphaldt
Inclined-limb Manometer Principle
Pressure Measurement Objective Questions
Air Pressure Inside the Tank
Identify High and Low Ports on Pneumatic DP Transmitter
Tank uses 3 Pressure Transmitters to Measure Level & Density
Draw the appropriate Pressure Switch Symbol ?
  • Ajay Kumar says:
    June 14, 2020 at 8:00 pm
    Dear sir,
    How to calibrate or zeroing of DPT with 5-way manifold.
DP Transmitter Located 10 feet Beneath the Vessel
The Principle of Dead Weight Pressure Tester
Practical Level Sensors Questions and Answers
Questions on Allen-Bradley MicroLogix 1000 PLC
U-tube Manometer with equal & unequal limb types
PLC Programming Question & Answer
Programmable Logic Controller (PLC) Questions and Answers – 9
Hydraulic Actuated Lift
Oil and Air Pressure Actuated Lifts Questions
Types of Pressure
Types of Pressure – Instrument Questions and Answers
two chemical streams are mixed together
Fisher model 546 I to P transducer
Fisher model 546 I/P transducer
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
Inductive proximity switches
How to Connect Proximity Switch (Source Type) to Make LED ON ?
Simple High Level Indicator Circuit
Safety PLC Programming steps
Safety Door Interlock PLC Program
Measurement and Instrumentation Objective Questions – Part 2
Gas Chromatography Questions & Answers
Steam conditioning valves
Concept of Steam Conditioning Valves
Inlet Pigtail
Primary Reformer – Each Turnaround done expensive Tubes Repairs
Performance Characteristics of Sensors and Transducers
AI AO DI DO Questions
