Reading: Difference Between Serial and Parallel Communication
Inst Tools > Blog > Communication > Difference Between Serial and Parallel Communication
In this post, we will understand the difference between serial and parallel communication, their advantages & disadvantages.
Last updated: October 17, 2023 1:53 pm
Communication Control Systems
3 Min Read
In this post, we will understand the difference between serial and parallel communication.
Serial CommunicationParallel CommunicationCompare Serial and Parallel Communication
There are two ways of communication in a computer –
  1. Serial and
  2. Parallel.
The difference between both of them can just be easily understood by their name.
As the name implies, serial communication means data is transmitted serially one by one; whereas, in parallel communication, data is transmitted in multiple links at one time.
Serial communication is much simpler and easier to perform due to single link usage and less complexity in transmitting and receiving data.
In serial communication, data is transmitted serially because of only one link.
Suppose there are 4 bits in the sequence – 0,1,1,1. Then, 0 will be transmitted first, followed by 1, then 1 and at last, 1.
This type of communication is best suitable for long distances; as only a single wire link is used. But, every method has some disadvantages.
Due to the single transmission of data, the time required for travel is large.
In parallel communication, data is transmitted in multiple links at one go.
Suppose there are 4 bits in the sequence – 0,1,1,1. All of these 4 bits will be transmitted at only one time due to multiple links.
This type of communication is best suitable for short distances; as multiple wires are used. But due to multiple transmissions of data at once, the time required for travel is very short than serial communication
If you look at bandwidth requirements, then serial communication can support higher bandwidth while parallel communication supports lower bandwidth.
Also, error and noise generated are much lower than in parallel communication.
There are some other issues in parallel communication like crosstalk. It means that due to multiple usages of links and near proximity, then there are chances of data colliding with other data lines.
So, if you compare both of these types, parallel communication only has a major advantage of speed. Apart from that, most of the systems in communication use serial type.
  • Shift Registers
  • Foundation Fieldbus
  • PLC Hot Standby
  • Electrical Signal Types
  • Fiber Optic Communication
How to Configure a Smart Transmitter Using a HART Communicator?
What is Instrument Hook Up Diagram ?
Cascade Control Principle
What is Electromagnetic Noise Interference?
Security of Industrial Automation Systems
Compressor Emergency Shutdown Root Cause Analysis
Configuration of PlantPAx Library in Factory Talk Studio
Recognizing a Porpoising PID Controller
Levels in Industrial Automation
Five Levels in Industrial Automation
DCS Alarm Summary Dashboard using Microsoft Power BI
What is a Network
What is a Network ?
Types of Industrial Control Systems
Electrical Ground Loop
How to Solve Electrical Ground Loop Problems?
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
DCS Troubleshooting Control Valve Loop
Permanent Magnet DC Motor (PMDC) Questions
Modbus Function code 02 – Read Contact(s)
Modbus Function Command Formats
Zigbee Projects
Zigbee Based Project Ideas and List
Gang Switch Principle
Reading Electrical Schematics
How do Electric Motors Work
All About Electric Motors and Universal Motors
Omron CX programmer shift register
The Concept of Shift Register in Omron PLC with Example
Cable Float Level Switch Principle
Cable Float Level Switch Working Principle
