Reading: Difference between Calibration and Ranging
Inst Tools > Blog > Calibration > Difference between Calibration and Ranging
Last updated: March 5, 2019 12:29 pm
Calibration
The concepts of calibration (trimming) and ranging are often difficult for new engineers of instrumentation to immediately grasp.
A simple analogy useful for understanding these topics is that of setting a digital alarm clock.
Suppose you purchase a digital alarm clock to wake you up at 7:00 AM in the morning so that you can get to school on time. It would be foolish to simply unpack your new clock from its box, power it up, and set the wake-up time to 7:00 AM expecting it will wake you at the correct time. Before trusting this alarm time of 7:00 AM, you would first have to synchronize your new clock to some standard time source (like as per your country standard time zone) so that it accurately registers time for the zone in which you live. Otherwise, the wake-up setting of 7:00 AM will be hopelessly uncertain.
Once your clock is synchronized against a trusted time source, however, the wake-up (alarm) time may be set at will. If your class schedule changed, allowing one more hour of sleep, you could re-set the wake-up time from 7:00 AM to 8:00 AM without any need to re-synchronize (re-calibrate) the clock. The only reason for re-synchronizing your clock to the time standard is to compensate for inevitable drift due to imperfections in the clock circuitry.
Synchronizing the clock to a standard time source is analogous to “calibrating” or “trimming” a smart transmitter: you are establishing an accurate correspondence between what the device’s microprocessor perceives and what the actual (real-life) values are. This step need only be done at the very beginning of the device’s service, and every so often as warranted by the device’s calibration drift over time.
Setting the wake-up (alarm) time on the clock is analogous to setting the LRV and URV parameters of a smart transmitter: you are defining the action(s) taken by the device at certain measured values. For the alarm clock, you are defining the hour and minute of day when the alarm sounds. For the transmitter, you are defining the measured variable values at which it will output 4 mA and 20 mA (for a 4-20 mA analog output range).
By contrast, an analog transmitter blends the functions of calibration and ranging into one. A useful analogy for this is to imagine using a simple wind-up mechanical timer to wake you at 7:00 AM. Such a crude timing device does not even register time in hours and minutes like a digital alarm clock: instead, it simply counts down time from its starting point and sounds an alarm when the descending count reaches zero. In order to set this device for a 7:00 AM wake-up alarm, you must first determine the current time and then calculate how many hours the timer must run before the time reaches 7:00 AM (e.g. if you are setting the wind-up alarm when you go to bed at 10:30 PM, this would equate to a timing period of 8.5 hours).
Every single time you set this wind-up alarm, you must consult a time standard to know how many hours and minutes of count-down time to set it for. If you decide to wake up at a different time in the morning, you must (once again) consult a standard time source, perform the necessary arithmetic, and set the timer accordingly. Setting the alarm time on this mechanism necessitates re-calibrating it to the local standard time without exception. Here, there is no distinction between synchronization and alarm setting; no distinction between calibration and ranging – to do one is to do the other.
Continue Article : SMART Transmitter Calibration
Pig Signalling Switches Functional Testing
Specific Conductance Calibration Procedure
Differential Pressure Transmitter Calibration Procedure
Calibrating Level Transmitter with Remote Seals
Self Actuated Pressure Control Valve Functional Testing
Difference between Repeatability and Reproducibility
DeadWeight Tester Questions
Pressure Switch Calibration Procedure
Smart Transmitter Calibration Tutorial Part 3
Control Valve Stroke Test Procedure
Calibration of Pyrometers using Black Body
As-found and As-left Documentation during Calibration
Coriolis Mass Flow Meter Verification Procedure
Prover Tank Calibration and Mass Flow Meter Verification Procedure
History of Measurement
Pressure Gauge Calibration according to Standard DKD-R-6-1
Capacitance Level measurement principle
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Magnehelic Gauge Calibration
Importance of Unit Measurement
transmitter calibration procedure
Infrared Temperature Calibrators
Different Types of Temperature Calibrators
O Ring Failure
How O-Ring Failure caused NASA’s shuttle to Blast ?
Boiler-Drum-Level-transmitter-calibration
Boiler Drum Level Transmitter Calibration
Process Variable Damping Graph
Process Variable Damping of Transmitter
Tube Fitting Parts
Procedure for Crimping the Connector
What is a Process Alarm
What is a Process Alarm? Types of Alarms
Pulse Height Analyzer Questions & Answers
What is a Pilot Valve?
What is a Pilot Valve? When do we use a Pilot Valve?
Mechanical Temperature Indicators (MTI) Problem
