  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Define Normal Status of a Process Switch ?
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Practical Questions > Define Normal Status of a Process Switch ?
Last updated: August 15, 2017 10:22 am
Practical Questions
2 Min Read
Switches, whether they be hand-actuated or actuated by a physical process, come in two varieties: normally-open (NO) and normally-closed (NC). You are probably accustomed to seeing both types of switch represented in pushbutton form on schematic diagrams:
Normally Open Switch and Normally Closed Switch
Normally-open pushbutton switches close (pass current) when actuated (pressed). When un-actuated, they return to their “normal” (open) state.
Normally-closed pushbutton switches are just the opposite: they open (stop current) when actuated (pressed) and return to their “normal” (closed, passing current) state when un-actuated.
This is simple enough to comprehend: the “normal” status of a momentary-contact pushbutton switch is the state it is in when no one is touching it. When pressed, the pushbutton switch goes to the other (opposite) state.
Things get more confusing, though, when we examine process switches, such as pressure switches, level switches, temperature switches, and flow switches:
Instrument Switch Status
Flow Switch Status
Define “normal” for each of these process switches. In other words, explain what condition(s) each process switch must be in to ensure it is in the “normal” state; and conversely, what condition(s) need to be applied to each switch to force it into its other state.
Answer :
The “normal” condition for a process switch is the condition of least stimulus.
For example:
  • A pressure switch will be in its “normal” state when there is minimum pressure applied
  • A level switch will be in its “normal” state when there is no level detected by the switch
  • A temperature switch will be in its “normal” state when it is cold
  • A flow switch will be in its “normal” state when there is no flow detected by the switch
Share Your Answers / comments.
Credits : by Tony R. Kuphaldt – under CC BY 1.0
Re-calibrate the Foxboro DP Pneumatic Transmitter
Questions on Resistive Tape Level Sensor
Programmable Logic Controller (PLC) Questions and Answers – 1
Draw the Symbols for Liquid Level Measuring Instruments
Analytical Process Control Question
208kSubscribersSubscribe
Recent Comments
Related Articles
reactor vessel
Vehicle Electrical Batteries upgrade
Upgrading the Electrical System in an Automobile
liquid flow control loop
Liquid Flow Control Loop Controller Action
Drum Level differential pressure transmitter
Calculate Differential Pressure Sensed by Level Transmitter
DP transmitter Errors
DP Transmitter Calibration Errors
Air Pressure Regulator cut-away diagram
Air Pressure Regulator Questions
PSV lift pressure
Calculate PSV Lift Pressure
burner management system P&ID
Solenoid Valves Questions & Answers – 1
More Articles
Non-Salient Pole Machines Quiz
Self-actuated Temperature Regulator
Self-actuated Temperature Regulator – Principle, Types, Advantages
calibrating-and-testing-rtd-sensors
RTD Calibration Procedure
Compressor IP Case Discharge Temperature Gradually Increases
Compressor Anti-Surge Control near-miss incident
Difference between RTJ and T&G Flanges
Difference between RTJ and T&G Flange Facings
DO Analyzer Working Principle
Dissolved Oxygen Analyzer Working Principle
diode-basic-structure-symbol
Forward Bias & Reverse Bias of a Diode
Turbidity Sensor Calibration Procedure
