Reading: Data Handling Instructions in PLC Programming
Inst Tools > Blog > PLC Tutorials > Data Handling Instructions in PLC Programming
Last updated: March 4, 2021 3:14 pm
We already discussed Timers, counters and other instructions used in PLC programming. Sometimes we may need some operations in the PLC programs which involve blocks of data operations. The instructions like timers and counters handle single bit of data, either 1 or 0.
Using MOV for Variable InitializationMasked Move (MVM) InstructionBitwise And (AND) InstructionClear (CLR) Instruction
The data handling instructions deals with more than a bit, like moving or transferring numbers from one memory location to another, comparing data values or performs simple arithmetic operations.
Move (MOV) Instructions
This output instruction moves the source value to the destination location. As long as the rung remains true, the instruction moves the data on each scan.
Move (MOV) Instruction in PLC
Entering Parameters
Source is the address or constant of the data you want to move.
Destination is the address where the instruction moves the data.
Application Note: If you wish to move one word of data without affecting the math flags, use a copy (COP) instruction with a length of 1 word instead of the MOV instruction.
MOV Logic Example in PLC
S:1/15 is a bit in the status date file that is energized for exactly one PLC scan when the PLC is placed in run mode.
It Can be used to condition the initialization of variables used elsewhere in the ladder logic.
The MVM instruction is a word instruction that moves data from a source location to a destination and allows portions of the destination data to be masked by a separate word.
Masked Move (MVM)
Entering Parameters
Source is the address of the data you want to move.
Mask is the address of the mask through which the instruction moves data; the mask can be a hexadecimal value (constant).
Read Also: PLC Example with MVM Instructions
This instruction performs a bit-by-bit logical AND. The operation is performed using the value at source A and the value at source B. The result is stored in the destination.
Bitwise AND
Source A and B can either be a word address or a constant; however, both sources cannot be a constant. The destination must be a word address.
Application Note: When entering constants, you can use the ampersand (&) operator to change the radix of your entry.
Instead of entering –1 as a constant, you could enter &B1111111111111111 or &HFFFF (Actual PLC only).
Nore – Use 1111111111111111B or FFFFH for the simulator purpose.
Read Also: Bitwise Logical Operations
The CLR instruction is used to set the destination value of a word to zero.
Clear (CLR) Instruction in PLC
This instruction always sets the Zero (Z) flag (S:0/2). Other arithmetic status bits are always cleared (reset)
  • S:0/0, carry (C)
  • S:0/1, overflow (V)
  • S:0/3, sign (S)
Math Functions in PLC
Ladder Logic using Switches
Types of Instructions in PLC
VFD Control using PLC program
PLC Car Washing Control Logic
PLC Techniques for I/O Mapping
Machine Tool and Coolant Control: PLC Ladder Logic Design
Oil and Water Separation Process using PLC Programming
PLC Program to Count Running Hours of any Equipment
Modbus Communication between Delta PLC with VFD
  • Rayfer says:
    September 6, 2019 at 6:27 pm
    very useful, thanks
PLC Temperature Control using Pulse Width Modulation (PWM)
What is Rewire Tool in Simatic Manager?
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
Modbus Communication between PLC and Energy Meter
PID Controller Output Types – PID_PWM and PID_Output
100 Electrical Circuit Breaker Quiz
PLC Programming for Weight-Based Packaging
SCADA backup too has been configured
FactoryTalk Studio and SQL Server for Data Logging
CPU Communication Ports in Siemens PLC
Types of CPU Communication Ports in Siemens PLC
4-20mA Loop Power Supply Questions
PLC Circuit with Switches
PLC Example with Switches
Control Loops
PLC Program for Water Level Control
PLC Program for Water Level Control Logic
Types of Interrupts Organization Blocks in Tia Portal
Types of Interrupt OB in Siemens Tia Portal
Difference Between AIS and GIS Panels
Difference Between Modbus TCP IP and Profinet
Safety Requirement Specifications (SRS) - Safety Instrumented System
Safety Requirement Specifications (SRS) – Safety Instrumented System
Ambient Air Quality Monitoring System Principle
Types of Electrical Loads
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
Density Measurement using Remote Seal Transmitters
Remote Seal Differential Pressure Transmitters Principle
Cycloconverters Objective Questions
