Reading: Coriolis Flowmeter Advantages and Limitations
Inst Tools > Blog > Flow Measurement > Coriolis Flowmeter Advantages and Limitations
Last updated: October 31, 2023 10:48 am
Flow Measurement
Even though a Coriolis flowmeter inherently measures mass flow rate, the continuous measurement of fluid density allows the meter to calculate volumetric flow rate if this is the preferred means of expressing fluid flow.
Coriolis FlowmeterAdvantages of Coriolis Mass FlowmetersDisadvantages of Coriolis Mass Flowmeters
Coriolis Flowmeter
The relationship between mass flow (W), volumetric flow (Q), and mass density (ρ) is quite simple:
Coriolis flowmeter capabilities and limitations
All the flowmeter’s computer must do to output a volumetric flow measurement is take the mass flow measurement value and divide that by the fluid’s measured density.
A simple exercise in dimensional analysis (performed with metric units of measurement) validates this concept for both forms of the equation shown above:
Coriolis flowmeter limitations
Coriolis mass flowmeters are very accurate and dependable. They are also completely immune to swirl and other fluid disturbances, which means they may be located nearly anywhere in a piping system with no need at all for straight-run pipe lengths upstream or downstream of the meter.
Their natural ability to measure true mass flow, along with their characteristic linearity and accuracy, makes them ideally suited for custody transfer applications (where the flow of fluid represents a product being bought and sold).
The American Gas Association (AGA) formalized the use of Coriolis mass flowmeters for the measurement of natural gas with their Report #11. This standard is equivalent to AGA #3 for orifice meters, AGA #7 for turbine meters, and AGA #9 for ultrasonic meters.
Perhaps the greatest disadvantage of Coriolis flowmeters is their high initial cost, especially for large pipe sizes. Coriolis flowmeters are also more limited in operating temperature than other types of flowmeters and may have difficulty measuring low-density fluids (gases) and mixed-phase (liquid/vapor) flows.
The bent tubes used to sense process flow may also trap process fluid inside to the point where it becomes unacceptable for hygienic (e.g. food processing, pharmaceuticals) applications.
Straight-tube Coriolis flowmeter designs, and designs where the angle of the tubes is slight, fare better in this regard than the traditional U-tube Coriolis flowmeter design.
However, a disadvantage of straight tubes is that they are stiffer than U-shaped tubes, so straight-tube Coriolis flowmeters tend to be less sensitive to low flow rates than their U-tube counterparts.
  1. True mass flow measurement
  2. Additional temperature and density measurements
  3. Very high accuracy for mass flow measurements
  4. Highly accurate density measurement
  5. Unaffected by pressure, temperature, and viscosity
  6. No inlet and outlet sections required
  7. Operates in both flow directions (forward and reverse)
  8. Measuring range settings can be optimized for flow rate and density
  9. Self-draining
  1. Affected by gas inclusions
  2. Vibration sensitive when improperly installed
  3. Limited choice of materials
  4. Nominal diameter is limited at the top
  • Mass Flow Calculations
  • Flow Meter Calibration
  • Coriolis Meter Uncertainty
  • Magnetic Flow Meter Principle
  • Pressure Flow Meter Theory
Difference between Fixed Area & Variable Area FlowMeters
In-Line Flow Switch Working Principle and Animation
Weirs and Flumes Flow Measurement
What is Differential Pressure and Pressure Loss?
Annubar Flow Meter – Principle, Advantages, Disadvantages
Comparison of Venturi and Orifice flow meter
Variable Area Flow Meters – Principle, Advantages, Disadvantages
Microwave Flow Sensor – Working Principle and Applications
Factors Affecting the Performance of Ultrasonic Flow Meters
Orifice Plate Turndown ratio
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
All About Vortex Flow Meters
DP Flow Transmitter Re-Ranging Calculation
What is a Condensate Pot? How to Install it?
Differential Pressure versus Flow Rate
Orifice Flowmeter Rangeability
Custody Transfer Meter Checks
Checklist for Custody Transfer Meters: Mass Flowmeter
Ultrasonic Doppler Flow Meter Advantages and Disadvantages
Spring Loaded Variable Area Flowmeter Working Principle
Spring Loaded Variable Area Flow Meter Working Principle
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Troubleshooting Ultrasonic Flow Meter Common Problems
Vortex Flow Meter Animation
Static and Dynamic Characteristics of an Instrument
Zero Interface Level Calculation
How to do Interface Level Calculation using DP Transmitter ?
Magnetic Flow Meter Liner Damaged
Magnetic Flow Meter Liner Damaged and Winding Burnt
Digital Electronics Objective Questions – Set 8
Eddy Current
Eddy Current Working Principle Animation
Types of Digital Outputs in PLC
what is calibration
Important Terms in Calibration
Irrigation based Projects
Irrigation based Projects for College Students
