Reading: Comparison of Temperature Sensors – Industrial Process Control
Inst Tools > Blog > Temperature Measurement > Comparison of Temperature Sensors – Industrial Process Control
The temperature sensors come in various types, each with its own set of characteristics suitable for specific applications. Compare Now.
Last updated: October 30, 2023 5:46 am
3 Min Read
Comparison of Temperature Sensors - Industrial Process Control
Here we compared the popular temperature sensors in the below table. let’s have a look at it.
ParameterThermocoupleRTD (Resistance Temperature Detector)ThermistorInfraredBimetallic StripSemiconductor (IC)Fiber Optic
Principle of OperationSeebeck effectResistance varies with temperatureResistance varies exponentially with temperatureEmission of infrared radiationMechanical bending due to thermal expansionBandgap of semiconductor varies with temperatureLight wavelength changes with temperature
Temperature RangeWide (-200 to 2300°C)Moderate (-200 to 850°C)Limited (-100 to 300°C)Wide (-50 to 1000°C)Limited (-30 to 120°C)Moderate (-55 to 150°C)Wide (-200 to 800°C)
AccuracyModerateHighModerate to HighModerateLow to ModerateModerate to HighHigh
Response TimeFastModerateFastFastSlowFastFast
SensitivityLowModerateHighModerateLowModerateHigh
CostLowHighLowModerate to HighLowModerateHigh
LinearityNon-linearLinearNon-linearNon-linearNon-linearLinearLinear
Self-heatingLowModerateHighNoneNoneModerateNone
Ease of InstallationEasyModerateEasyModerateEasyModerateModerate
Safety AspectsGenerally SafeGenerally SafeGenerally SafeLimited (eye safety)Generally SafeGenerally SafeGenerally Safe
Here’s a brief explanation of the terms used:
  • Principle of Operation: The basic principle that allows the sensor to measure temperature.
  • Temperature Range: The range of temperatures the sensor can accurately measure.
  • Accuracy: How precisely the sensor can measure temperature.
  • Response Time: How quickly the sensor can respond to changes in temperature.
  • Sensitivity: How much the output changes for a given change in temperature.
  • Cost: The relative financial outlay required to purchase and install the sensor.
  • Linearity: Whether or not the output is directly proportional to the temperature.
  • Self-heating: Whether the sensor itself generates heat during operation, which could affect its accuracy.
  • Ease of Installation: How simple it is to install the sensor.
  • Safety Aspects: Considerations regarding the use of the sensor in hazardous conditions.
  • What is a Probe Thermometer?
  • Response Time Test of RTD
  • Transmitter Burnout Function
  • Thermowell Outer Diameter
  • Temperature Transmitter Maintenance
Temperature Controller Problem
Use of Temperature Transmitters instead of Direct Wiring
Types of Thermocouple Measuring Junction
Relationship between Temperature Scales
How to calculate Thermocouple Temperature by measuring the output millivoltage
Distributed Temperature Sensors (DTS) in Power Lines
Thermocouple Details
Spiral Bimetallic Thermometer Principle
Response Time Test of RTD and Thermocouple
Resistance Temperature Detectors (RTD) Sources of Error
RTD Calibration Procedure
Temperature Error of 2-Wire, 3-Wire & 4-Wire RTD
Temperature Switch Working Principle
Radiation Pyrometer Working Principle
RTD Connection Diagram
Difference Between 2 wire RTD, 3 wire RTD, and 4 wire RTD’s
Skin Type Thermocouple
Temperature Sensors Questions
Questions on Thermocouple and Pyrometer
Thermocouple Types
Types of Thermocouples
Measuring temperature with RTD
How RTD Measuring the Temperature
RTD Standards list
RTD Standards
Temperature Sensors Fault
Calibration of Temperature Sensor with Indicator
Transducer
What is a Transducer ?
Career Scope in Mechanical Engineering
Power Systems MCQ Series 3
Gauge Cock
Pressure Gauge Cocks
Best PLC for Your Project
Finding the Best PLC for Your Project – Tips and Tricks
Home Automation Project Ideas
Parking Lights PLC Program Explained with Video
Power Transistor Quiz
