Reading: Comparison Instructions in PLC Programming
Inst Tools > Blog > PLC Tutorials > Comparison Instructions in PLC Programming
Last updated: March 4, 2021 3:11 pm
2 Comments
6 Min Read
Comparison instructions in PLC are used to test pairs of values to condition the logical continuity of a rung.
Types of Comparison InstructionsEqual (EQU) InstructionNot Equal (NEQ) InstructionLess Than (LES) InstructionLess Than or Equal (LEQ) InstructionGreater Than (GRT) InstructionGreater Than Or Equal (GEQ) InstructionMasked Comparison for Equal (MEQ)Limit Test (LIM) InstructionTrue/False Status of the LIM Instruction
Thus, comparison instructions would seldom, if ever, be the last instruction on a rung.
Types of Comparison Instructions in PLC
As an example, suppose a LES instruction is presented with two values. If the first value is less than the second, then the comparison instruction is true.
Equal (EQU) Instruction in PLC Programming
Use the EQU instruction to test whether two values are equal. If source A and source B are equal, the instruction is logically true. If these values are not equal, the instruction is logically false.
Source A must be an address.
Source B can be either a program constant or an address.
Values are stored in two’s complementary form.
Not Equal (NEQ) Instruction in PLC Programming
Use the NEQ instruction to test whether two values are not equal.
If source A and source B are not equal, the instruction is logically true.
Less Than (LES) Instruction in PLC Programming
Use the LES instruction to test whether one value (source A) is less than another (source B).
If source A is less than the value at source B, the instruction is logically true.
Less Than or Equal (LEQ) Instruction in PLC Programming
Use the LEQ instruction to test whether one value (source A) is less than or equal to another (source B).
If the value at source A is less than or equal to the value at source B, the instruction is logically true.
Greater Than (GRT) Instruction in PLC Programming
Use the GRT instruction to test whether one value (source A) is greater than another (source B).
If the value at source A is greater than the value at source B, the instruction is logically true.
Greater Than Or Equal (GEQ) Instruction in PLC Programming
Use the GEQ instruction to test whether one value (source A) is greater than or equal to another (source B).
If the value at source A is greater than or equal to the value at source B, the instruction is logically true.
Masked Comparison for Equal (MEQ) Instruction in PLC Programming
Use the MEQ instruction to compare data at a source address with data at a compare address.
The Use of this instruction allows portions of the data to be masked by a separate word.
Source is the address of the value you want to compare.
Mask is the address of the mask through which the instruction moves data.
The mask can be a hexadecimal value.
Compare is an integer value or the address of the reference.
If the 16 bits of data at the source address are equal to the 16 bits of data at the compare address (less masked bits), the instruction is true.
The instruction becomes false as soon as it detects a mismatch.
Limit Test (LIM) Instruction in PLC Programming
Use the LIM instruction to test for values within or outside a specified range, depending on how you set the limits.
The Low Limit, Test, and High Limit values can be word addresses or constants, restricted to the following combinations:
  • If the Test parameter is a program constant, both the Low Limit and High Limit parameters must be word addresses.
  • If the Test parameter is a word address, the Low Limit and High Limit parameters can be either a program constant or a word address.
If the Low Limit has a value equal to or less than the High Limit, the instruction is true when the Test value is between the limits or is equal to either limit.
If the Low Limit has a value greater than the High Limit, the instruction is false when the Test value is between the limits.
Limit Test (LIM) Status
JUMP Instruction in PLC Programs
Master Control Reset (MCR) in PLC
One Shot Rising & Falling Instructions
Sequence and Logic Control in PLC
Scaling with Parameters Instruction
T-Junction Traffic Control System – PLC Programming
Types of Interrupt OB in Siemens Tia Portal
How to Program a Star-Delta System using 1 Button in PLC?
Mixing Program with Timers and Counters in Omron PLC
What is 21 CFR in SCADA and HMI Systems?
2 Comments
  • Romel Roy says:
    September 4, 2019 at 8:14 pm
    Dear Sir
    This is the fantastic Documents for Study & Learning you have given.
    Indeed there are lots of lessons to learn.
    Kindly, keep on teaching us so that we can upgrade the human civilization.
    With Regards
  • Florencio says:
    September 17, 2019 at 3:28 am
    The logical instructional tools will help us greatly in developing our skills between PLC and SCADA …
    keep providing these tools
    graciously
Studio 5000 Tutorial: PLC Programming for Digital Alarms
Batch Simulator PLC Example Program using LogixPro Simulator
SCADA and HMI Systems – Differences, Similarities, Purpose
Rules for Writing SCL Language in Tia Portal
Structured Text PLC Code for Sequential Process Data Storage
What is Process Control?
FIFO Instruction in Allen Bradley PLC Programming
PLC Ladder Logic Example based on Set Coil and Reset Coil
ControlLogix
Difference Between CompactLogix and ControlLogix
How to Filter Digital and Analog Inputs in a PLC
How to Filter Digital and Analog Inputs in a PLC?
Learn PLC Programming
Basics of Ladder Diagram in PLC Programming
Instrument Junction Box
Instrumentation System Architecture
0 to 10 mA Current Loop
What is Live Zero in 4-20 mA Current Loop?
Difference between Analog Signal and Digital Signal
PLC Example on Manufacturing Line Assembly
Measure Duty Cycle using Multimeter
How to Measure Duty Cycle using Multimeter
Strip-Chart-Recorder-Working-Principle
Strip Chart Recorder Working Principle
Basic Pneumatic System
Pneumatic Handbook
Difference between BDV and PSV
Volumetric Flow Calculations
Difference Between Skin Effect and Proximity Effect
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
