This article is about communication between WinCC and TIA portal using simple programming examples and screenshots.
Wincc and Tia Portal
Step 1:
Open TIA PORTAL. Create a new project. Configure the devices and open programming environment.
Step 2:
The same way, create a new project in HMI. I already created an article on it. Read the article before proceed here.
Step 3:
From the above two steps, we created new projects in Tia Portal and WinCC.
After creating new projects, letβs move to establish communication between them.
As shown in the below window click on option βHMIβ and expand it. Double click on βdevice configurationβ.
Step 4:
Click on βnetwork viewβ. Here, you can see PLC is added to the network as we already have configured while creating a new project.
Make sure that you select CPU and HMI have which contains the same port for communication. Here, I have select HMI and CPU which have the same PROFINET port in common.
Step 5:
Now as shown in the below window select Profinet port in green color and drag that to the same port of HMI. Doing that will create a network.
Step 6:
Now to check communication established properly select any one HMI or PLC and do right click on it to open the selection menu as shown in the below window.
Click on βcompileβ and select βhardware rebuild allβ.
Step 7:
You are done with communication. To check IP address select βHMIβ as shown in the below window. Click on βdevice viewβ.
Step 8:
Following window will pop-up. Click on green color Profinet port. In the βgeneralβ section, select the βProfinet interfaceβ where you can find an IP address and you can make changes with your application.
Step 9:
Do follow the same procedure for CPU to check an IP address.
Author: Suhel Patel
- Field instrument to Control System
- What is SCADA System?
- Siemens CPU Status & Errors
- Quiz Questions on Motors
- Siemens PLC Memory
