Reading: Understanding the Chiller Maintenance – HVAC Tutorials
Inst Tools > Blog > Common > Understanding the Chiller Maintenance – HVAC Tutorials
This article offers helps you to understand the HVAC chiller maintenance on weekly and annual schedules and their checklist.
Last updated: September 16, 2024 10:46 am
Common
Chiller MaintenanceWeekly Maintenance: What You Need to Do1. Compressor Oil Level2. Oil Top-up3. Oil Pressure4. Refrigerant Flow5. Operating Pressures6. System Inspection7. Record Keeping8. Leak DetectionAnnual Maintenance1. Inspection of Valves, Piping, and Filters2. Surface Cleaning and Repainting3. Chilled Water Circuit Check4. Comprehensive Maintenance
Chiller Maintenance
Operating your chiller at its peak efficiency not only saves energy but also minimizes maintenance costs.
Understanding the Chiller Maintenance - HVAC Tutorials
The following points are to be covered in the weekly maintenance of a chiller unit.
Ensure the oil level is visible through the sight glass while the machine is running at full load. Allow the compressor to function for 3-4 hours before adding any oil and recheck every half an hour. If the level isn’t as expected, seek help from a professional refrigeration mechanic.
Note: In units with tandem or trio scroll compressors, the oil level should be checked when the compressors are off as the running oil level may not be accurate.
2. Oil Top-up
Remember, overcharging the compressor with oil can be as damaging as not having enough oil. Always consult a professional technician before topping up and use only the oils recommended by the manufacturer.
3. Oil Pressure
Regularly monitor the oil pressure.
4. Refrigerant Flow
The flow of liquid refrigerant through the sight glass should be steady without bubbles. The presence of bubbles indicates a low charge, a potential leak, or a restriction in the liquid line, which requires immediate attention from a qualified technician.
Check if the operating pressures are higher or lower than the initial recorded pressures when the machine was first used.
Inspect the entire system for any anomalies such as a noisy compressor, loose casing panels, leaky pipes, or vibrating contacts.
7. Record Keeping
Keep a record of temperatures, pressures, dates, times, and any other observations in the service log.
8. Leak Detection
Performing a leak detection test is highly recommended.
Annual Maintenance
The following are to be covered in the annual maintenance of a chiller unit.
Inspect all valves and piping. Clean the filters and condenser tubes if needed. Also, ensure the chilled water piping filters are clean.
CAUTION: The chilled water circuit may be pressurized. Always observe necessary safety measures when depressurizing the circuit before opening it. Failure to do so can lead to accidents and injuries.
Clean all corroded surfaces and repaint them as required.
Inspect the chilled water circuit for any leaks. Additionally, check the functionality of the water circulating pump and its ancillaries. Verify the antifreeze percentage in the chilled water circuit and top up if needed.
Perform all the weekly maintenance tasks. At the start and end of each year, including the seasonal shutdown or restarting procedure, depending on the season. These inspections should cover:
  • Checking contacts of motor contactors and control devices
  • Verifying the adjustment and operation of each control device
  • Conducting an oil acidity analysis and recording the results
  • Changing the oil, if required
  • Following LENNOX’s recommendations for compressor oil
  • Performing a refrigerant leak test
  • Checking motor winding isolation
With the help of this guide, maintaining your chiller’s optimum performance can become an easy task. Happy maintenance!
  • Types of HVAC Chillers
  • HVAC Heat Transfer Loops
  • Automation used in HVAC
  • HVAC Objective Questions
  • Valves in HVAC System
Belt Conveyor Weighing System – Weigh Bridge – Speed Sensor
The Role of Test Automation in a Single Sprint – 5 Steps to Follow
What is Magnetic Tape Recorder ?
Do You Need a VPN on Your Home Computer?
6 Pieces of Essential Equipment For PCB Assembly
The Most Significant Developments in Satellite Technology
  • Ahmad Baharesfan says:
    August 12, 2023 at 5:05 pm
    Dears
    Thanks for your maintenance instruction.
    I want and appreciate to know about installation and the setting of thd driver parameters for start up of the electric expansion valve
    Thanks before
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
Physic Homework Help – Tips to Find Professional Assistance
Electrical Systems vs. Pneumatic Systems
What is a Tactile Sensor? Principle, Advantages, and Applications
Loop diagram and System Inspection Lab Exercise
3 Valve Manifold Operation
Why do Teenagers want to be Entrepreneurs?
Bagging Machine Controller – Principle, Operation Sequence
Ultrapure Water in the Semiconductor Industry
Career Scope in Mechanical Engineering
Types of Angular Velocity Measurement
Stainless Steel CNC Machined Parts
Everything You Need to Know About Stainless Steel CNC Machined Parts
Difference Between Skin Effect and Proximity Effect
Hydraulic Systems
Benefits of IoT in the Manufacturing Industry
How to Prevent Conveyor Problems
Common Conveyor Problems and How to Prevent Them
Total Organic Carbon Analyzers Questions and Answers
Convert an Electrical Diagram into PLC Program
How to Convert an Electrical Diagram into PLC Program?
Control Systems Stability and Algebraic Criteria
Routh-Hurwitz Stability Criterion
PLC Automatic Pedal Switch for Speed Control
pH Analyzer Calibration and Troubleshooting
Troubleshooting pH Analyzer Common Problems
Modbus Vs DNP3
Difference between Modbus and DNP3 Communication Protocols
Interferometer Principle
