Reading: Cathode Ray Tube Deflection System
Inst Tools > Blog > Electronic Devices & Circuits > Cathode Ray Tube Deflection System
Last updated: April 1, 2018 8:32 am
This Post Deflection system of CRT is a continuation of my previous post Electron Gun of CRT. This post completely covers the Deflection system of the CRT. When the electron beam is accelerated it passes through the deflection system, with which beam can be positioned anywhere on the screen.
The deflection system of the cathode-ray-tube consists of two pairs of parallel plates, referred to as the vertical and horizontal deflection plates. One of the plates in each set is connected to ground (0 V). to the other plate of each set, the external deflection voltage is applied through an internal adjustable gain amplifier stage. To apply the deflection voltage externally, an external terminal, called the y input or the x input, is available.
As shown in the image below, the electron beam passes through these plates. A positive voltage applied to the y input terminal (V y) causes the beam to deflect vertically upward due to the attraction forces, while a negative voltage applied to the y-input terminal will cause the electron beam to deflect vertically downward, due to the repulsion forces.
Similarly, a positive voltage applied to X-input terminal(V x) will cause the electron beam to deflect horizontally towards the right; while a negative voltage applied to the X-input terminal will cause the electron beam to deflect horizontally towards the left of the screen. The amount of vertical or horizontal deflection is directly proportional to the corresponding applied voltage.
When the voltages are applied simultaneously to vertical and horizontal deflecting plates, the electron beam is deflected due to the resultant of these two voltages.
The face of the screen can be considered as an X-Y plane. The (X,Y) position of the beam spot is thus directly influenced by the horizontal and the vertical voltages applied to the deflection plates Vx and Vy respectively.
The horizontal deflection (X) produced will be proportional to the horizontal deflecting voltage, Vx, applied to X-input.
X = KxVx
Where, Kx is constant of proportionality.
The deflection produced is usually measured in cm or as number of division , on the scale, in the horizontal direction.
Then Kx = x/Vx where Kx expressed as cm/volt or division/volt, is called horizontal sensitivity of the oscilloscope.
Similarly, the vertical deflection (y) produced will be proportional to the vertical deflecting voltage, Vy, applied to the y-input.
Y= KyVy
Ky=y/Vy and Ky, the vertical sensitivity, will be expressed as cm/volt, or division/volt.
The schematic arrangement of the vertical and the horizontal plates controlling the position of the spot on the screen is shown in the figure.
The values of vertical and horizontal sensitivities are selectable and adjustable through multi positional switches on the front panel that controls the gain of the corresponding internal amplifier stage. The bright spot of the electron beam can thus trace (or plot) the X-Y relationship between the two voltages, Vx and Vy.
Seven Segment Display Working Principle
Tunnel Diode Working Principle
Full Wave Bridge Rectifier Peak Inverse Voltage
Energy Diagrams of PN Junction & Depletion Region
Transistor Collector Feedback Bias
Difference between Schottky Diode and PN junction Diode
Basic DC Power Supply Circuit
Semiconductors Diodes Questions & Answers
JFET Working Animation
Comparison of Transistor Configurations
Series and Parallel Resistors
Half Wave Voltage Doubler using Diodes
Basics of Transistors
How to Test a Diode using Multimeter
Transistor Load Line Analysis
MOSFET VI Characteristics
Power MOSFET
Open Circuit without Freewheeling diode
Freewheeling Diode Working Principle
Short Circuit and Open Circuit
Fluorescent Screen of CRT
CRT Fluorescent Screen
Derivation-of-Ohms-Law
Basics of Ohm’s Law
Comparison of MOSFET and BJT
phototransistor-circuit
Phototransistor Circuit Example
Arc Fault Breaker (AFB) Electrical Problem Solved
Thermowell Immersion Length
Thermowell Insertion and Immersion Length
DP-Level-Transmitter-Open-tank-calibration
Generator Action in a Motor
DeadWeight Tester
DeadWeight Tester Questions
BALL CHECK VALVE THEORY
Types of Check Valves
Steam Generator Parts
Parts and functions of Steam Turbine
Synchronous Motor Principle
Synchronous Motors
