Reading: Calculate Density and Specific Gravity
Inst Tools > Blog > Practical Questions > Calculate Density and Specific Gravity
Based on this reference data, calculate density and specific gravity of the following liquids.
Last updated: November 9, 2020 9:38 am
Practical Questions
2 Min Read
Question 1:
Water, at its maximum density (temperature of 3.98o C, or approximately 4o C), weighs 62.428 lb/ft3. Based on this reference density, determine the specific gravities of the following liquids:
Sea water: D = 63.99 lb/ft3
Mercury: D = 849 lb/ft3
Olive oil: D = 57.3 lb/ft3
Castor oil: D = 60.5 lb/ft3
Kerosene: D = 51.2 lb/ft3
Benzene: D = 56.1 lb/ft3
Acetone: D = 49.4 lb/ft3
Glycerin: D = 78.6 lb/ft3
Methanol (methyl alcohol): D = 49.41 lb/ft3
Ethanol (ethyl alcohol): D = 49.27 lb/ft3
Ethylene glycol (ethanediol): D = 69.22 lb/ft3
Gasoline: D = 41 lb/ft3 to 43 lb/ft3
Answer:
Sea water: 1.025
Mercury: 13.6
Olive oil: 0.918
Castor oil: 0.969
Kerosene: 0.820
Benzene: 0.899
Acetone: 0.791
Glycerin: 1.26
Methanol: 0.7915
Ethanol: 0.7892
Ethylene glycol: 1.109
Gasoline: 0.657 to 0.689
Question 2:
Toluene has a density of 0.8669 g/cm3 at 20o C. Calculate its density in units of pounds per cubic feet and its specific gravity (unitless).
Answer:
Specific gravity = 0.8669 (same as density in units of g/cm3 )
The units of grams and cubic centimeters are defined in such a way that their density quotient in relation to pure water is 1. This is similar to the Celsius temperature scale, similarly defined at the 0o and 100o points by the freezing and boiling points of pure water, respectively.
To calculate the density of toluene in units of pounds per cubic feet, simply multiply the density of water (62.428 lb/ft3 ) by the specific gravity of toluene (0.8669):
(62.428 lb/ft3 )(0.8669) = 54.12 lb/ft3
  • Pneumatic DP Transmitter
  • Calculate Hydrostatic Pressure
  • Block and Bleed Valves
  • Air Compressor Problem
  • PID Control Loop Faults
Credits: Tony R. Kuphaldt
Galileo Thermometer
Identify the Pressure Gauge Error
Importance of Temperature in Remote Seal Pressure Transmitter
How Do You Connect the Differential Pressure Gauge at the Filter?
How to Draw a Schematic Diagram ?
Calculate Differential Pressure Sensed by Level Transmitter
PT Loop Diagram Faults
Heat Exchanger Differential Pressure Transmitter
Calculate Process Temperature using a Thermocouple
A Question on Density Gauge
Motion-Balance and Force-Balance Instruments
Dip Tube Type Level System
Questions on Dip Tube Type Level System
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
Thermocouple Questions
Thermocouple Terminal block Questions
Pressure-sensing level transmitter
Moving Pressure Sensing Level Transmitter from Top to Bottom
steadily pour a liquid into vertical tube
Vertical Tube Liquid Level Equilibrium
10 Questions on Reforming Furnace Control System
Signal Strength of Guided-wave Radar Level Instrument
Suppose the lamp refuses to light up
Indentify Faults in Simple Lamp Circuit including Failed Wires
LEL vs Percent By Volume vs Parts Per Million vs Parts per Billion
Full Wave Rectifiers Objective Questions and Answers
0-10 VDC to 0-20 mA Conversion
How to Convert Voltage to Current using Resistor ?
Differential Pressure Switch Working Principle
Advantages of VoIP technology
What is VoIP and How Does it Work? Advantages & applications
Poorly Built Switchgears
Bernoulli's Principle
Bernoulli’s Principle and Equation – Flow Measurement
Which Gases Can a Multi-Gas Detector Detect
Which Gases Can a Multi-Gas Detector Detect?
