Reading: Battery Terminology
Inst Tools > Blog > Electrical Theory > Battery Terminology
Battery Terminology
Last updated: July 27, 2018 12:13 pm
Electrical Theory
3 Min Read
Batteries are used for a wide variety of services throughout technology today. To begin to study battery operation and characteristics, a few terms that are used with batteries must be understood.
They are
  1. Voltaic cell
  2. Battery
  3. Electrode
  4. Electrolyte
  5. Specific gravity
  6. Ampere-Hour
Voltaic Cell
The term voltaic cell is defined as a combination of materials used to convert chemical energy into electrical energy. A voltaic or chemical cell consists of two electrodes made of different types of metals or metallic compounds placed in an electrolyte solution.
Battery
A battery is a group of two or more connected voltaic cells.
Electrode
An electrode is a metallic compound, or metal, which has an abundance of electrons (negative electrode) or an abundance of positive charges (positive electrode).
Electrolyte
An electrolyte is a solution which is capable of conducting an electric current. The electrolyte of a cell may be a liquid or a paste. If the electrolyte is a paste, the cell is referred to as a dry cell; if the electrolyte is a solution, it is called a wet cell.
Specific Gravity
Specific gravity is defined as the ratio comparing the weight of any liquid to the weight of an equal volume of water. The specific gravity of pure water is 1.000. Lead-acid batteries use an electrolyte which contains sulfuric acid. Pure sulfuric acid has a specific gravity of 1.835, since it weighs 1.835 times as much as pure water per unit volume.
Since the electrolyte of a lead-acid battery consists of a mixture of water and sulfuric acid, the specific gravity of the electrolyte will fall between 1.000 and 1.835. Normally, the electrolyte for a battery is mixed such that the specific gravity is less than 1.350.
Ampere-Hour
An ampere-hour is defined as a current of one ampere flowing for one hour. If you multiply the current in amperes by the time of flow in hours, the result is the total number of ampere-hours. Ampere- hours are normally used to indicate the amount of energy a storage battery can deliver.
Battery Terminology Summary
  • A voltaic cell is a combination of materials used to convert chemical energy into electrical energy.
  • A battery is a group of two or more connected voltaic cells.
  • An electrode is a metallic compound, or metal, which has an abundance of electrons (negative electrode) or an abundance of positive charges (positive electrode).
  • An electrolyte is a solution which is capable of conducting an electric current.
  • Specific gravity is defined as the ratio comparing the weight of any liquid to the weight of an equal volume of water.
  • An ampere-hour is defined as a current of one ampere flowing for one hour.
Inductance and Inductive Reactance
Inductive Time Constant
High Voltage Circuit Breaker Principle
Multimeter & Megger Principle
Voltage Polarity and Current Direction
Parallel Open Circuit Faults
Voltage and Current Phase Relationships in an Inductive Circuit
Series-Wound Motor
Transformer Operation Under No-Load
Transformer Voltage Ratio
Voltage Divider
Types of Capacitors
Classification of Transformers
AC Motor Theory
Power Triangle
Power Triangle
Parallel Circuit Parallel Current Calculations
Parallel Circuit Current Calculations
Capacitors Connected in Parallel
Series and Parallel Capacitors
Calculate Power in Parallel RCL Circuit
Transformer voltage and turns ratio
Transformer Current Ratio
Calculate Power in Series RL Circuit
Power Factor Meter Principle
Types of Batteries
Types of Batteries
Power Triangle
Power Triangle
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 1
Function Block Diagram - Studio 5000 Logix Designer
Define the Order of Execution in Functional Block Diagram of Studio 5000
Difference between Rotary Shaft and Sliding Stem Control Valves
Difference between Rotary Shaft Valves and Sliding Stem Control Valves
NDIR GAS ANALYSER WORKING PRINCIPLE ANIMATION
NDIR Gas Analyser Working Principle
Magnatic Level Indicators Working Animation
Control Valve Calibration
How-to do Control Valve Calibration?
Automatic Car Washing Process using PLC Ladder Diagram
