Reading: Battery Hazards
Inst Tools > Blog > Electrical Theory > Battery Hazards
Battery Hazards
Last updated: July 27, 2018 9:06 pm
Electrical Theory
Because batteries store large amounts of energy, there are certain hazards that are associated with battery operation. These hazards must be fully understood to ensure safe operation of batteries.
Shorted Cell
Cell short circuits can be caused by several conditions, which include the following: faulty separators; lead particles or other metals forming a circuit between the positive and negative plates; buckling of the plates; or excessive sediments in the bottom of the jar. The primary cause of some of these occurrences is overcharging and over-discharging of the battery, which causes sediment to build up due to flaking of active material and buckling of cell plates.
Over-charging and over-discharging should be avoided at all costs. Short circuits cause a great reduction in battery capacity. With each shorted cell, battery capacity is reduced by a percentage equal to one over the total number of cells.
Gas Generation
A lead-acid battery cannot absorb all the energy from the charging source when the battery is nearing the completion of the charge. This excess energy dissociates water by way of electrolysis into hydrogen and oxygen. Oxygen is produced by the positive plate, and hydrogen is produced by the negative plate. This process is known as gassing.
Gassing is first noticed when cell voltage reaches 2.30-2.35 volts per cell and increases as the charge progresses. At full charge, the amount of hydrogen produced is about one cubic foot per cell for each 63 ampere-hours input. If gassing occurs and the gases are allowed to collect, an explosive mixture of hydrogen and oxygen can be readily produced. It is necessary, therefore, to ensure that the area is well ventilated and that it remains free of any open flames or spark producing equipment.
As long as battery voltage is greater than 2.30 volts per cell, gassing will occur and cannot be prevented entirely. To reduce the amount of gassing, charging voltages above 2.30 volts per cell should be minimized (e.g., 13.8 volts for a 12 volt battery).
Battery Temperature
The operating temperature of a battery should preferably be maintained in the nominal band of 60 – 80°F. Whenever the battery is charged, the current flowing through the battery will cause heat to be generated by the electrolysis of water. The current flowing through the battery (I) will also cause heat to be generated (P) during charge and discharge as it passes through the internal resistance (Ri), as illustrated using the formula for power in Equation.
P = I2Ri
Higher temperatures will give some additional capacity, but they will eventually reduce the life of the battery. Very high temperatures, 125°F and higher, can actually do damage to the battery and cause early failure.
Low temperatures will lower battery capacity but also prolong battery life under floating (i.e., slightly charging) operation or storage. Extremely low temperatures can freeze the electrolyte, but only if the battery is low in specific gravity.
Battery Hazards Summary :
  • Short circuits cause a great reduction in battery capacity.
  • To prevent short circuits in a battery, overcharging and over-discharging should be avoided at all costs.
  • The adverse effect of gassing is that if gassing occurs and the gases are allowed to collect, an explosive mixture of hydrogen and oxygen can be readily produced.
  • To reduce the amount of gassing, charging voltages above 2.30 volts per cell should be minimized.
  • Whenever the battery is charged, the current flowing through the battery will cause heat to be generated by the electrolysis of water and by I2Ri power generation.
  • Higher temperatures will give some additional capacity, but they will eventually reduce the life of the battery. Very high temperatures, 125°F and higher, can actually do damage to the battery and cause early failure.
Electro-Dynamo Meter Movement
Types of AC Generators
Capacitance
Voltage and Current Phase Relationships in an Inductive Circuit
Methods of Producing Voltage (Electricity)
Transformer Voltage Ratio
DC Generator
Battery Terminology
Classification of Transformers
Low Voltage Air Circuit Breaker Principle
Simplified Formulas for Parallel Circuit Resistance Calculations
Wiring Diagram
Calculate Power in Parallel RCL Circuit
Ground Detector Principle
Core-Type Transformer
Transformer Turns Ratio
DC Machine
DC Generator Internal Losses
Using Kirchhoff’s Voltage Law to find Current with one Source
Applying Kirchhoff’s Voltage Law
Shunt-Wound DC Motor
Shunt-Wound Motor Operation
Electrical Wiring Terminology
Potential Difference Across a Conductor Causes a Current to Flow
Conductor, Insulator, Resistor and Current Flow
Series - Wound DC Motor
Series-Wound Motor
Compounded DC Generator
Parallel AC Generators
Types of Cable Lengths in Ethernet Network
Temperature Sensor Failure
Wave Trap in Power Line carrier Communication
What is a Wave Trap? – Power Line Carrier Communication
Frequency Measurement Objective Questions
Functional Block Diagram in PLC for Oil and Water Process
Synchronous Motor Starting Methods
Hydrazine analyzer Working Principle
Hydrazine Analyzer Working Principle
How to Create Faceplate in FactoryTalk View Studio
How to Create Faceplate in FactoryTalk View Studio?
