Reading: Example of Automated Guided Vehicle with PLC
Inst Tools > Blog > PLC Tutorials > Example of Automated Guided Vehicle with PLC
Last updated: March 4, 2021 2:25 pm
3 Min Read
Explain PLC programming for the Automated Guided Vehicle (AGV) in the manufacturing plant. Here we are discussing some part of the working in AGV as an example program in PLC.
Here we are using the ultrasonic sensor concept for object detection in the way of AGV. The automated guided vehicle work as line follower robot. If there is an object in front of the AGV it will stop running.
For this, we will use the ultrasonic sensor for object detection. When the object is detected, the ultrasonic sensor will give the command to the PLC.
The ultrasonic sensor generates the sound on some frequency which travels through air and if objects in its path it will bounce from the object and back to sensor. From the equation, we can count the distance.
For example – We can calculate the distance as per the equation.
Consider here sound wave takes 294micro second for traveling (total time is taken from the sensor to object and object to the sensor). So here we can calculate the distance.
Time = Distance/speed
Distance = Time*Speed = 294 microsecond * 0.034 cm/microsecond = 9.999cm
Speed of the light = 340 m/s
List of Inputs
Register A:- Measured echo or traveling time.
List of Outputs
Q1:- AGV motor output
NETWORK 1:-
DIV mathematics instruction in plc
DIV mathematics instruction is used for unit conversion. Time speed is converted from m/s to cm/microseconds.
NETWORK 2:-
Multiplication instruction in plc
Multiplication instruction is used to calculate the distance of the object.
NETWORK 3:-
Distance Logic in PLC
For example, we have taken a 10cm safe distance. If the detected distance is less than 10cm, Object may near to AGV so it needs to be stopped.
Note:- Above application may be different from the actual application. This example is only for explanation and educational purposes only.
Author: Bhavesh
  • Data Comparison Instructions
  • Simulate Gate Array Logic
  • PLC Communication Network
  • Analog Measurement in PLC
  • Security of SCADA Systems
Scaling with Parameters (SCP) Instruction in PLC
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
DP Master System Configuration in PLC
Heating and Mixing of Products using PLC Example Tutorial
Sorting & Distribution Line PLC Programming – Advanced Logic
HMI Screen Design for Hazardous Applications
Move Instruction in Tia Portal
How to use FIFO Block in TIA Portal? – Siemens PLC Programming
Main differences between Sinking and Sourcing Circuits
Siemens TIA Portal Elevator System with Safety Features
Conveyor Sorting Machine PLC Program with Calculation Function
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
How to Blink Lights in Ladder Logic
How to Blink Lights in Ladder Logic?
traffic light plc program
Introduction to SCL Programming in Siemens PLC
Types of Expressions in the SCL Language of the Tia Portal
PLC Program using Logic GATEs
PLC Logic GATE Program
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Shutdown Motors in Timed Operation PLC Program
PLC program for VFD Drive Multiple Speeds
Drive Multiple Speeds with Different Reference using PLC
Analog Electronics Objective Questions – Set 6
Flow Control Valves
Difference Between a Flow Control & a Needle Valve
Pulverizer Electrical Problem Solved
Differential Pressure Transmitter Question
Differential Pressure Transmitter Questions
Level Transmitter
What is a Bridle?
Omron PLC Example
Design a Water Pump PLC Program using CX-Programmer
Monsoon Protection for Field Instruments and Junction Boxes
Preventa XPS MC, XPS MP - Safety controllers
High-end Programmable Logic Controller – Schneider PLC
