Reading: Allen Bradley PLC Subroutines
Inst Tools > Blog > PLC Tutorials > Allen Bradley PLC Subroutines
PLC subroutine example to store recurring sections of program logic that must be executed from several points within your application program.
Last updated: November 2, 2023 5:00 pm
3 Min Read
JSR, SBR, and RET instructions are used to direct the controller to execute a separate subroutine file within the ladder program and return to the instruction following the JSR instruction.
The SBR instruction must be the first instruction on the first rung in the program file that contains the subroutine.
  • Use a subroutine to store recurring sections of program logic that must be executed from several points within your application program
  • A subroutine saves memory because you program it only once.
  • Update critical I/O within subroutines using immediate input and/or output instructions (IIM, IOM), especially if your application calls for nested or relatively long subroutines
  • Otherwise, the controller does not update I/O until it reaches the end of the main program (after executing all subroutines)
  • Outputs controlled within a subroutine remain in their last state until the subroutine is executed again.
When the JSR instruction is executed, the controller jumps to the subroutine instruction (SBR) at the beginning of the target subroutine file and resumes execution at that point. You cannot jump into any part of a subroutine except the first instruction in that file.
The target subroutine is identified by the file number that you entered in the JSR instruction. The SBR instruction serves as a label or identifier for a program file as a regular subroutine file. The instruction must be programmed as the first instruction of the first rung of a subroutine.
The RET instruction marks the end of subroutine execution or the end of the subroutine file. The rung containing the RET instruction may be conditional if this rung precedes the end of the subroutine.
In this way, the controller omits the balance of a subroutine only if its rung condition is true.
  • Essential Documents in a PLC System
  • Process Control System Questions
  • Conveyor Ladder Logic Program
  • PLC Energize or De-energize
  • PLC Selective Execution
Siemens HMI Training – Using UDTs with Faceplates
Siemens PLC Mathematics Instructions
How to use Masked Move Instruction in PLC
PLC Programming Example on LED Control
Normally-open and Normally-closed Switch Contacts
Count and Pack Objects from Conveyor using PLC Ladder Logic
  • Shahid ali says:
    September 13, 2018 at 9:13 am
    I know about dcs and scada function of instruments.what is the function of dcs
PLC Program for Alarm Security System
Setpoints and Alarms in Control System
How to Configure IP Address in Rockwell PLC?
Difference Between Normal Counters and Fast Counters – Learn PLC
Latched and Momentary Operation of Motor PLC Program
Two wire loop powered transmitters
Use of Comments in SCL Language
Downloading Free PLC software
Step by Step Guidelines for Downloading Free PLC software
PLC Program for Car Parking
PLC Program for Entry and Exit Control of Car Parking
Download Modscan software
How to Use ModScan Software for Testing Modbus Communication?
PLC Logic for Water Pumping and Chemical Addition
Developing PLC Logic for Water Pumping and Chemical Addition
OMRON PLC program for waste-burning automation
Waste-Burning System OMRON PLC Program Example
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Types of Tank Gauging Level Measurement Systems
Pressure Gauge Accessories
Why Three-phase Voltage is 440 Volts
Why Three-phase Voltage is 440 Volts?
input-output-relationships-of-transmitters
Input-Output Relationships of Transmitters
traffic light plc program
Redundant system communication cable
What is Interface Module in Siemens PLC?
wedge Flow meter
What is a Segmental Wedge Flow Meter?
Gauge Display Scale
How to Read Gauge Analog Scales
