    • Process Fundamentals
  • Control Systems
Reading: Allen Bradley PLC Interview Questions and Answers
  • Control Systems
Inst Tools > Blog > Instrumentation Interview Questions > Allen Bradley PLC Interview Questions and Answers
Allen Bradley PLC Interview Questions : This article covers Allen Bradley PLC programming interview questions and answers. Visit InstrumentationTools.
Last updated: November 2, 2023 4:02 pm
Instrumentation Interview Questions PLC Tutorials
3 Comments
6 Min Read
Allen Bradley PLC Interview Questions and Answers : This article covers industrial automation interview questions and answers which covers basically AB PLC related questions and answers
Allen Bradley PLCWhat are the PLC ranges available in Rockwell?What are the software Used with AB?What is use of RS Linx software?What is use of RS Logix software?What file gets created in PC for RS Logix PLC program?How to creating linkage between PLCs and PLC programming software?Hardware configuration (PLC and I/Os)What is the meaning of Upload and Download?What are the various communication interfaces supported by AB?Give information about DH, Control Net, DeviceNet and Ethernet protocol.What is latency in communication?How the communication protocols are distinguished?Comparison between various Protocols used with ABIs Allen Bradley Rockwell?What is RSLogix?Who owns Rockwell Automation?
Allen Bradley PLC
Allen Bradley PLC Interview Questions & Answers
Programmable Logic Controller – Allen Bradley
  1. Pico : Non modular small PLCs
  2. Micrologix 1000, 1200 and 1500 Series
  3. SLC : SLC 5/01, 5/02, 5/03
  4. Control Logix Flex Logic and Soft PLC
  • For Pico soft for Pico PLC programming
  • RS Logix 500 for Micrologix and SLC PLCs programming
  • RS Logix 5000 for Control Logix PLCs programming
  • SCADA – RS View earlier Control View
RS Linx software is used to perform following tasks.
  • Configure communication drivers
  • View configured drivers and active nodes
  • Enable communication tasks such as uploading, downloading, going online, updating firmware and sending messages.
RS Logix is a PLC programming software. It contains all the instructions needed for PLC programming.
We can develop the program, down load / upload the program, work on line / off line and force the I/Os using the software.
  • RS Logix 500 is used for Micrologix and SLCs
  • RS Logix 5000 is used for Control Logix PLCs
The extension of the file will be .rss. So if you create an application with “Demo” name the file created will be “Demo.rss”.
By default it will be stored in “c:\Program Files\RockwellSoftware/RS Logix 500 Eng location.
The RS Linx software is used for linking the PLC and software Either you can manually configuration the communication settings or By using Auto Configure facility the software will detect the communication settings automatically.
  1. Manual configuration
  2. Auto detect
  • Upload means transferring the program data from PLC to PC
  • Download means transferring the program data from PC to PLC
The commonly used communication protocol in AB includes DH+, DH485, ETH, Modbus, Device Net and Control Net.
Data Highway:
The proprietary data network used by Allen Bradley PLCs to communicate information to and from other PLCs on the network or to and from host computers attached to the network.
ControlNet:
A real-time, control-layer network providing high-speed transport of both time- critical IO data and messaging data, including upload/download of programming and configuration data and peer-to-peer messaging, on a single physical media link
DeviceNet:
A low-cost communication link that connects industrial devices to a network. It is based on broadcast-oriented communication protocol – the Controller Area Network (CAN).
Ethernet:
The standard for local communications networks developed jointly by Digital Equipment Corp., Xerox, and Intel. Ethernet base band coaxial cable transmits data at speeds up to 10 megabits per second.
Ethernet is used as the underlying transport vehicle by several upper-level protocols, including TCP/IP.
The delay time between the end of one communication and the start of another.
During this time, the processes associated with the communication are hung up and cannot continue. The latency has to be minimum.
The protocols are distinguished with following specifications
No. of nodes supported, total network length , Speed of communication .
various Protocols used with AB PLC
Allen–Bradley is the brand-name of a line of Factory Automation Equipment manufactured by Rockwell Automation (NYSE ROK).
What is RSLogix?
The RSLogix™ family of IEC-1131-compliant ladder logic programming packages helps you maximize performance, save project development time, and improve productivity.
Rockwell Automation traces its history to 1903 and the formation of the Compression Rheostat Company, founded by Lynde Bradley and Dr. Stanton Allen with an initial investment of $1000. In 1904, 19-year-old Harry Bradley joined his brother in the business.
  • Top Electrical Engineering Questions & Answers
  • Allen Bradley RSLogix 500 PLC Programming
  • PLC Program to Control Level of Two Tanks
  • Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
  • PLC Program to Heat and Bend Glass Tubes
Tia Portal – OB30 Cyclic Interrupt Organization Block
Control Valve Interview Questions and Answers
PLC Timer Application in Security Camera Recording
PID in Studio 5000
What is Loop Checking?
3 Comments
  • Waseem Ahmad says:
    February 1, 2017 at 6:29 pm
    it’s really good helpful for us
  • M R RAVI CHANDRAN says:
    February 2, 2017 at 1:45 pm
    it is very useful to every one in instrumentation field
  • Ahmed Mongy says:
    April 11, 2018 at 2:10 pm
    very nice and useful.
208kSubscribersSubscribe
T-Junction Traffic Control System – PLC Programming
SCADA Software and their Comparison
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
PLC Program for Artificial Fishpond Water Level Monitoring System
Free Industrial Control System (ICS) Cyber Security Training Course
Siemens Drum block for Sequencer Operation
SCADA Engineer Job Responsibilities and Skills
Basic Concepts of the Safety Relay
different PLC brands of Distributed IO
What is Distributed IO? – Decentralized Peripherals in PLC
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
PLC Power Supply and Operating Voltages
PLC Program to Count and Pack Parts from conveyor
Count and Pack Objects from Conveyor using PLC Ladder Logic
FBD Logic
Free Schneider PLC Training - Automation Course
Free Schneider PLC Training – Automation Course
Siemens CPU Clock Memory
Alarm Acknowledge using PLC
Rotor Angle Stability of Synchronous Generators in Power System
PLC Automation for Product Weighing and Labeling
PLC Controlled Conveyor and Weighing with Labeling Automation
PID Tuning recommendations
PID Tuning Recommendations based on Process Dynamics
Three Valve Manifold
3 Valve Manifold Operation
Differential Pressure Switch Principle
Heat Flow Balance Systems Objective Questions
Control Valve flow coefficient (Cv)
Why we Measure Control Valve flow coefficient (Cv)?
Piston Check Valve
What is Piston Check Valve ?
