Reading: Animation of Electromagnetic Relay
Inst Tools > Blog > Animation > Animation of Electromagnetic Relay
Last updated: March 4, 2021 4:58 pm
Animation Control Systems PLC Tutorials
2 Comments
When a voltage is applied to the coil, a current passes through it and this creates a magnetic circuit which includes the core, armature and the yoke.
Animation of Electromagnetic RelaySimple Relay Schematic :Relay Schematic : When Switch Not PressedRelay Schematic : When Switch Pressed
The core attracts the armature, which pivots and presses the push rod against the common contact, breaking the electrical connection with one contact and making the electrical connection with the other contact. When the voltage is removed from the coil the magnetic attraction of the armature to the core ceases.
A spring then returns the contacts, pushrod and armature to the initial position. In this example, the common contact also acts as the spring, but in other relays, a separate spring is employed.
The above animation shows that when we apply a voltage to the relay coil, the Relay contacts will change.
For example the Normally Open (NO) becomes Normally Closed (NC) and similarly the Normally Closed (NC ) becomes Normally Open (NO). When we remove the applied voltage to the relay coil then the relay contacts again comes into default state.
Design a relay (CR1) circuit which controls two lamps, one is Red lamp (R) and another is Green Lamp (G). These lamps will be controlled by using a single switch (S).
When switch is pressed then Red lamp will be ON and Green lamp will be ON during switch de-energised state.
Relay Wiring Schematic
Relay Schematic Animation
Circuit Operation :
  • When Switch S in Open state
  • Relay Coil CR1 will be De-energized
  • Relay Contact CR1-1 will be Open (Here Relay NO contact is using in the circuit.)
  • Red Lamp will be OFF as relay contact CR1-1 is Normally Open (NO). so circuit open and no current flow.
  • Relay Contact CR1-2 will be Closed (Here Relay NC contact is using in the circuit.)
  • Green Lamp will be ON as relay contact CR1-2 is Normally Closed (NC). so circuit closes and there is a current flow.
Animation of Relay Ladder Logic
Circuit Operation :
  • When Switch S in Closed state
  • Relay Coil CR1 will be Energized
  • Relay Contact CR1-1 will be Closed (Here Relay NO contact is using in the circuit.)
  • Red Lamp will be ON as relay contact CR1-1 Normally Open (NO) contact becomes Normally closed as Relay is energized.
  • Relay Contact CR1-2 will be Open (Here Relay NC contact is using in the circuit.)
  • Green Lamp will be OFF as relay contact CR1-2 Normally Close (NC) contact becomes Normally Open as Relay is energized.
Switch Types and Common Terminology
Why we use NAMUR Output Sensor?
Pressure Switch to control two lamps
Sink or Source? PNP or NPN
PLC Program for Flow Totalizer
Safety PLC Coding Practices – Programming Recommendations
Network Operating System
How to Read the PLC Datasheet? – Important Notes About PLC
CODESYS HMI Interface
2 Comments
  • Deepak says:
    July 9, 2017 at 4:06 pm
    Dear sir I need help in configuration of pid loops in Siemens s7 200 smart PLC using microwin software
  • Ryszard says:
    July 11, 2017 at 7:13 pm
    Great engineering imformation. I have a question about relay schematic: when switch is pressed: Are NO relay CR1-1 has good symbol?
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
Difference between PLC and HMI
Can a PLC Function Without an HMI or SCADA?
Connecting Faceplate to PLC Project – HMI Tutorial
PLC to Start or Stop 3 Machines using 1 Switch Program
Delta WPL Soft Counter
Delta PLC Counter with Comparison
PLC Digital Inputs
PLC Digital Input and Digital Output Modules
Lights with Adjustable Timers PLC Programming
Flip-Flop PLC Programming: Lights with Adjustable Timers
Omron PLC Example
Design a Water Pump PLC Program using CX-Programmer
Conveyor and Puncher PLC Program
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
Industrial Gas Detection Systems
PLC based Gas Detection System using Ladder Logic Project
Ladder Logic Counters Instruction
Up Counter PLC Program
Zener Diode Regulator
Zener Diode Voltage Regulators
Advantages and Disadvantages of Air Blast Circuit Breakers
Difference Between Robotics and Automation
Microwave Barrier Level Switch Working Principle
Electromagnetic Field Theory Questions and Answers
On Delay Timer TON in Tia Portal
Timers in PLC Programming – Siemens Tia Portal Tutorials
Top PLC Manufacturers
