Reading: Why Viscosity is Not Included in the Orifice Equation?
Inst Tools > Blog > Flow Measurement > Why Viscosity is Not Included in the Orifice Equation?
Has this question troubled you that viscosity is not included in the Orifice equation? This article explains importance of Reynolds number.
Last updated: November 2, 2023 12:10 pm
Flow Measurement
2 Min Read
Orifice PlateDemystifying Reynolds Number
Orifice Plate
Imagine Honey flowing through the pipe and on the contrary water flowing through the Pipe will have the same pressure drop. You have guessed it right the pressure drop won’t be the same.
So why is viscosity not in the equation? This question puzzled Tony Rudolph for 15 years until he had an Eureka moment.
We owe Sir Osborne Reynolds for this discovery.
To understand this let’s take a simple example.
Imagine we pour honey and water on a slide.
Who will reach first?
Viscosity in Orifice equation
Water will reach down first as compared to honey.
Why?
The answer in simple words is water has a lesser tendency to stick along its surface as compared to Honey.
This phenomenon is captured in Reynolds number.
Formula of Reynolds Number
The “Numerator” consists of 3 variables that could be termed together as Inertial force.
V=Velocity, D=Diameter, p=density
The “Denominator” consists of one term and that is absolute viscosity.
Hence, in conclusion, the Reynolds number is the ratio of “Inertial forces” to “Viscous force”.
So higher the Reynolds number the more “Inertial forces” dominate.
And for orifice meter one of the requirements is a high Reynolds number.
Thus as “Viscous forces” at very high Reynolds are negligible we don’t consider them in the equation.
Thanks for reading.
I hope it’s been of value to you.
Credits: I stumbled upon this insightful concept in Tony R Kuphaldt book “Lessons In Industrial Instrumentation”. A great read.
Author: Asad Shaikh
Profile: Linkedin
  • Vent and Drain Holes of Orifice
  • What is Orifice Beta Ratio?
  • Orifice Meters Compensation
  • What is Restriction Orifice?
  • Turndown ratio of Orifice
Coriolis Flow Meter Construction
What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Difference between Transit time and Doppler Ultrasonic Flow Meter
Flow Transmitters Questions and Answers – Instruments Test
Piston Flow Meters Working Principle with Animation
Importance of Flow Meter Turndown Ratio
Is it Easy to Measure Natural Gas Flow and Volume?
What is an Orifice Meter?
What are Multiphase Flow Meters? – Working Principle, Advantages
What is an Insertion Flow Meter? – Types, Principle, Advantages
What is an Averaging Pitot Tube? – Principle, Advantages
Difference between Fixed Area & Variable Area FlowMeters
Continuous Flow Measurement
Bernoulli’s Principle and Equation – Flow Measurement
Turbine Meter Custody Transfer
What is Gas Meter and Regulating Station?
Pressure Temperature Compensation Flow Measurement
Weir Flow Meter Principle
Measure Flow rate using Level Sensors
Water Cut Meter
What is Water Cut Meter?
multi-variable transmitter
Mass Flow Meters
vortex flow transmitter
What is a Vortex Flow Meter?
V Cone Flow Meter Working Principle
V Cone Flow Meter – Principle, Advantages, Disadvantages
HART-IP Principle
What is HART- IP ?
Fire-Triangle-in-Gas-Detection-System
Basics of Fire Detection System
Flame Cables
Difference Between Flame Resistant and Flame Retardant Cables
Elevator Control
Career Scope in Electrical Engineering
Search tank in Intouch Scada
Tank Filling and Emptying using Intouch Scada Script
How to Filter Digital and Analog Inputs in a PLC
How to Filter Digital and Analog Inputs in a PLC?
Analog Instruments
