Reading: What is a Variable Area Flow Meter?
Inst Tools > Blog > Flow Measurement > What is a Variable Area Flow Meter?
An example of a variable area flow meter is the rotameter, which uses float as a flow indicator, suspended in the midst of a tapered tube.
Last updated: November 2, 2023 5:35 am
Flow Measurement
A variable area flow meter is one where the fluid must pass through a restriction whose area increases with the flow rate.
Variable Area Flow MeterRotameter
This stands in contrast to flow meters such as orifice plates and venturi tubes where the cross-sectional area of the flow element remains fixed.
The simplest example of a variable-area flowmeter is the rotameter, which uses a solid object (called a plummet or float) as a flow indicator, suspended in the midst of a tapered tube:
As fluid flows upward through the tube, a pressure differential develops across the plummet. This pressure differential, acting on the effective area of the plummet body, develops an upward force (F = PA). If this force exceeds the weight of the plummet, the plummet moves up.
As the plummet moves farther up in the tapered tube, the area between the plummet and the tube walls (through which the fluid must travel) grows larger. This increased flowing area allows the fluid to make it past the plummet without having to accelerate as much, thereby developing less pressure drop across the plummet’s body.
At some point, the flowing area reaches a point where the pressure-induced force on the plummet body exactly matches the weight of the plummet. This is the point in the tube where the plummet stops moving, indicating flow rate by it position relative to a scale mounted (or etched) on the outside of the tube.
Rotameter
The following rotameter uses a spherical plummet, suspended in a flow tube machined from a solid block of clear plastic. An adjustable valve at the bottom of the rotameter provides a means for adjusting gas flow:
Rotameter principle
The same basic flow equation used for pressure-based flow elements holds true for rotameters as well:
Rotameter Formula
However, the difference in this application is that the value inside the radicand is constant since the pressure difference will remain constant (Note) and the fluid density will likely remain constant as well. Thus, k will change in proportion to Q. The only variable within k relevant to the plummet position is the flowing area between the plummet and the tube walls.
Note: If we know that the plummet’s weight will remain constant, its drag area will remain constant, and the force generated by the pressure drop will always be in equilibrium with the plummet’s weight for any steady flow rate, then the relationship F = PA dictates a constant pressure.
Thus, we may classify the rotameter as a constant-pressure, variable-area flow meter. This stands in contrast to devices such as orifice plates, which are variable-pressure, constant-area. Most rotameters indicate devices only. They may be equipped to transmit flow information electronically by adding sensors to detect the plummet’s position in the tube, but this is optional.
Rotameters are very commonly used as purge flow indicators for pressure and level measurement systems requiring a constant flow of purge fluid. Such rotameters are usually equipped with hand-adjustable needle valves for manual regulation of purge fluid flow rate.
  • Fixed Area Flow Meters
  • Liquid-In Glass Thermometer
  • Basics of Venturi Flow Meter
  • Multi-phase Flow Meter
  • Turbine Meter Verification
How does an Orifice Measures Flow?
Coriolis Flow Meter Construction
What is an Orifice Meter?
  • lily1987 says:
    October 23, 2019 at 8:40 am
    Variable Area Flow Meter is also called rotameter , great and reliable flow measuremnt device.
What is a Square Root Extractor? – DP Flow Measurement
Difference between Orifice & Restriction Orifice
Calculate Flow Transmitter Output Current
Oval Gear Meter – Principle, Advantages, Limitations, Applications
V Cone Flow Meter – Principle, Advantages, Disadvantages
Basics of Orifice Plates
DP Flow Transmitter Re-Ranging Calculation
Annubar Flow Meter – Principle, Advantages, Disadvantages
Vortex Flow Meters
All About Vortex Flow Meters
Advantages and Disadvantages of Flow Measurement Techniques
Advantages & Disadvantages of Different Flow Meters
ROTARY ABUTMENT FLOW METERS WORKING ANIMATION
Rotary Abutment Flow Meters Working Principle and Animation
Vortex flow meter Bluff Body
Types of Vortex Flow Meter Sensors
Reciprocating Piston Meters
Overview of Positive Displacement Flow Meters
What is Averaging Pitot Tube
What is an Averaging Pitot Tube? – Principle, Advantages
Paddlewheel flowmeter principle
What is a Paddle Wheel Flow Meter?
Turbine Flow Meters Working Animation
Turbine Flow Meters Animation
Gas Detection Excel Converters
Electromechanical_Relays Circuit
Relay Loop Back Circuit
Electrical Machines Short Answers
Industrial Automation Projects
Evaluating Industrial Automation Projects Return on investment (ROI)
Intrinsic Safe Calculation
Thermal Differential Level Measurement
What is Thermal Differential Level Measurement?
Parallel Circuit Unknown Resistance
Simplified Formulas for Parallel Circuit Resistance Calculations
Flow Control Valves Interview Questions
