Reading: Valve Handwheel Types : Fixed, Hammer, Gear
Inst Tools > Blog > Control Valves > Valve Handwheel Types : Fixed, Hammer, Gear
Last updated: March 21, 2019 3:27 pm
Control Valves
2 Min Read
Valve actuators are selected based upon a number of factors including torque necessary to operate the valve and the need for automatic actuation.
Valve Handwheel TypesHandwheels Fixed to StemHammer HandwheelGears
Types of actuators include manual handwheel, manual lever, electrical motor, pneumatic, solenoid, hydraulic piston, and self-actuated.
All actuators except manual handwheel and lever are adaptable to automatic actuation.
Manual actuators are capable of placing the valve in any position but do not permit automatic operation.
The most common type mechanical actuator is the handwheel. This type includes handwheels fixed to the stem, hammer handwheels, and handwheels connected to the stem through gears.
As illustrated in Below Figure, handwheels fixed to the stem provide only the mechanical advantage of the wheel.
When these valves are exposed to high operating temperatures, valve binding makes operation difficult.
Figure : Fixed Handwheel
Hammer Handwheel
As illustrated in below Figure, the hammer handwheel moves freely through a portion of its turn and then hits against a lug on a secondary wheel.
The secondary wheel is attached to the valve stem. With this arrangement, the valve can be pounded shut for tight closure or pounded open if it is stuck shut.
Valve Hammer Handwheel
Figure : Hammer Handwheel
Gears
If additional mechanical advantage is necessary for a manually-operated valve, the valve bonnet is fitted with manually-operated gear heads as illustrated in below Figure.
A special wrench or handwheel attached to the pinion shaft permits one individual to operate the valve when two individuals might be needed without the gear advantage.
Because several turns of the pinion are necessary to produce one turn of the valve stem, the operating time of large valves is exceptionally long.
The use of portable air motors connected to the pinion shaft decreases the valve operating time.
Valve Gears
Figure : Manual Gear Head
Articles You May Like :
Different Valve Types
Valve Position Indication
Self Operated Valves
Globe Valve Seat & Disk
Control Valves Noise
How Needle Valve Works ?
Control Valves Pre-Commissioning Checklist
What is Lift Check Valve ?
Types of Valve Actuators
Control Valve Volume Booster Working Principle
Control Valve Parts Questions and Answers
What are Isolation valves? – Purpose, Types, Configurations
Classification of Gate Valves
When to choose Full Bore Valve or Reduced Bore Valve ?
What is a 3-way Solenoid Valve ?
Electronic Valve positioners
Basics of Valves
Flow Control Valves Interview Questions
Solenoid Valve with Manual Reset Working Principle
Direct Acting Control Valve Positioner
Pneumatic Valve Positioner Working Principle
Inherent vs Installed Control Valve Flow Characteristics
Valve Interlock
Valve Interlock
PISTON CHECK VALVE THEORY
Valve Materials Comparison Notes
Solenoid-Valve-Working-Animation
Solenoid Valve Working Animation
Control Valve in Last Position
Control Valve Fail Safe Action
Self Actuated Pressure Control Valve Functional Testing
What is Swing Check Valve ?
SOA-C02 Exam Certification
Know the Best Path to Achieve SOA-C02 Exam Certification
Raspberry Pi Projects
200 Raspberry Pi Projects
DeltaV System to Excel
How to Export Data from DeltaV System to Excel
CNC Custom Machining
What is Custom Machining in CNC? Why Should You Choose It?
Gas Compressor Seal Oil System
Automatic Circuit Recloser
What is Automatic Circuit Recloser? Principle and Types
FOUNDATION Fieldbus junction boxes
Fieldbus Cables
