Reading: Why V/f Ratio is kept Constant in VFD?
Inst Tools > Blog > Electrical Basics > Why V/f Ratio is kept Constant in VFD?
When motor running through VFD the V/f ratio is kept constant in order to minimize the eddy current and hysteresis losses.
Last updated: March 23, 2021 3:07 pm
Electrical Basics
VFD is used for speed control of induction motor to save energy and for better process control. Let us first understand the working of induction motor. The motor converts electrical energy into mechanical energy.
V/f Ratio Constant in VFDWhat happens if flux is increased above the rated capacity?
However, one more intermediate stage of conversion before converting the electrical energy into mechanical energy is the magnetic energy. Thus, the motor converts the electrical energy into magnetic energy and then the magnetic energy is again converted into electrical energy and finally to mechanical energy.
The motor has its rated magnetic energy handling capacity. The magnetic energy or air gap power depends on the flux. The core of the motor is designed to carry the rated flux. More than the rated flux should never be allowed to pass through the core.
Let us see on what factors the magnetic flux of the motor depends.
If AC voltage is applied to stator of the induction motor, the flux is generated. The flux generated is in phase with the applied voltage.
Φ = Φm Sinωt
According to the Faraday’s law of electromagnetic induction, the self EMF induced generated in the stator is expressed as;
e = – N (dΦ/dt)
e = – N [(dΦm Sinωt/dt)]
e = – NwΦm Cosωt
e = 2πfN Φm Cosωt
e = Em Cosωt
Here Em = 2πfN Φm
RMS value of voltage induced;
erms = Em/√2
erms = (2πfN Φm) /√2
erms = 4.44 Φm f N
Φ = erms / 4.44 f N
Φ =e/f = v/f
Thus the flux generated in the stator depends on the ratio of the volt/Hz.
In VFD motor, speed is controlled by changing the frequency, as the speed of the motor is proportional to the frequency.
N = 120f/p
The speed of the motor can be changed by varying the frequency, however the voltage needs to be increased or decreased in the same proportion of the frequency to maintain the constant flux in the motor.
The PWM inverter of the VFD maintain the constant V/f ratio in order to maintain the constant flux in the motor. Suppose an induction motor of rating 440 volts,50 Hz is to be operated through VFD and if the speed is half of its rated speed, then PWM inverter output 25 Hz AC.
If voltage remains 400 volts then the ratio of v/f = 400/25 =16. The motor will experience double flux of its rated flux capacity in this case. Therefore when frequency is 25 Hz, the voltage will be 200 volts and v/f ratio is equal to 8.
Higher flux than its rated capacity leads to increased eddy current and hysteresis losses. The increased losses cause the heating of the core and as a result of this the insulation of core will get damaged.
Therefore, when motor running through VFD the V/f ratio is kept constant.
Author: Satyadeo Vyas
  • Torque Boosting in Variable Frequency Drive
  • Variable Frequency Drive Working Principle
  • Motor Speed Control using VFD and PLC
  • AC Motor Speed Control
  • Magnetism
Differences between Watts and Volt Amps
What is a Damper? Types of Dampers in HVAC
Proper Sizing of Conductors
What is a Link Box?
What are Inverse Time and Instantaneous Trip Circuit Breakers?
Electrical Contactor Interlocking Circuit Explained
Difference Between HV and LV Cables
What is an Instrument Transformer? – Types, Principle, Advantages
What is a VFD? – Theory, Advantages, Disadvantages
Basics of Electrical Transformer
Cathodic Protection – Sacrificial Anodic and Impressed Current
Electrical Feeder Automation in Smart Grid
Intelligent Motor Control Center
What is an Intelligent Motor Control Center? – IMCC
What is a Magnetic Field
Difference Between Electric Field and Magnetic Field
Arc Protective Clothing
What is Arc Protective Clothing? – Importance, Features, Materials
Motor Slip Calculation
Electrical Motor Terms and Concepts
What is a Lightning Arrester? How does it work?
How to Locate Faults in Cables? - Fault Analysis and Location
How to Locate Faults in Cables? – Fault Analysis & Location
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
Understanding Protection Relays
Understanding Protection Relays – 50, 50N, 51, 51N
4-20mA Current Loop
Basics of 4-20mA Current Loop
What is Barring Gear Logic? Why is it Required in the Steam Turbine?
Differential Pressure Sensor with pair of Strain Gauges
Differential Pressure Sensor with Pair of Strain Gauges
water treatment station
What is a Vent Filter? – Water Treatment Plant
Temperature Transmitter with Thermocouple
Thermocouple Extension and Compensating Cables
Single Phase Preventer Relay
Working Principle of Single Phase Preventer Relay
Manchester encoding
Foundation Fieldbus Electrical Parameters
Humidity sensor Working Principle
Humidity Sensor Working Principle
