Reading: Ultrasonic Flow Meters Working Principle
Inst Tools > Blog > Animation > Ultrasonic Flow Meters Working Principle
Ultrasonic flow meters operate using difference in time travelled by the two ultrasonic waves is directly proportional to the flow velocity.
Last updated: November 1, 2023 5:48 am
Animation Flow Measurement
2 Comments
2 Min Read
Ultrasonic flow meters operate using the transit-time differential method. The Transit-time differential measurement is based on a simple physical fact.
Ultrasonic Flow MetersPros and Cons of Ultrasonic Flow Meters
Imagine two canoes crossing a river on the same diagonal line, one with the flow and the other against the flow. The canoe moving with the flow needs much less time to reach the opposite bank.
Ultrasonic waves behave exactly the same way. A sound wave traveling in the direction of the flow of the product is propagated at a faster rate than one traveling against the flow (vAB > vBA).
Transit times tAB and tBA are measured continuously. The difference (tBA – tAB) in time traveled by the two ultrasonic waves is directly proportional to the mean flow velocity (vm).
Where,
  • tAB is the Time required for an ultrasonic wave to travel from Sensor A to B sensor
  • tBA is the Time required for an ultrasonic wave to travel from Sensor B to A sensor
Ultrasonic Flow Meters Advantages & Disadvantages
  • Wedge Flow Meter Principle
  • Variable Area Flow Meters
  • Ultrasonic Level Sensor Principle
  • Calibrate Different Flow Meter
  • What is a Vortex Flow Meter?
How to Measure Pressure in Inches of Water Column
What is a Paddle Wheel Flow Meter?
Magnetic Float Level Switch Working Animation
Hot Wire Anemometer Principle and Types
Configure the Instruments in Flow Control Loop
2 Comments
  • Amar says:
    June 2, 2017 at 9:55 am
    Pls, hindi version available ?
    • S Bharadwaj Reddy says:
      June 2, 2017 at 2:01 pm
      Hi, Open Any Article > In Right Side bottom, you can find language translate option, select your required language.
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
What is a Velocity-based Flow Meter?
Transit Time Flow Meter Principle
Square-root characteristics of Differential Pressure Flow Meters
Basics of Globe Valves
Magnetic Level Gauge Working Principle Animation
Heat Tracing Problems
Guided-wave Radar Level Measurement Animation
Differential Pressure versus Flow Rate
Orifice Flowmeter Rangeability
Orifice Specifications
Averaging Pitot Tube Working Principle
Resistor-Color-Code-Chart
Resistor Color Code Animation
Turbine Flow Meter
All About Turbine Meters
Oval gear Flow Meter Principle
Oval Gear Meter – Principle, Advantages, Limitations, Applications
pressure-gauge-animation
Bourdon Tube Pressure Gauge Working Principle Animation
Siemens Tia Portal PLC Training Course
Hand Switch Pressed Working Animation
Pushbutton switches and Types of Switches
Mass Flow Calculations of flow measurement
Difference of Energy Gap
Difference between Intrinsic and Extrinsic Semiconductors
Superheated Steam Temperature Control System
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Temperature Switch Working
Basics of Temperature Switch
Thermal Dispersion Flow Switch Working Principle
