Reading: Ultrasonic Flow Meters Animation
Inst Tools > Blog > Animation > Ultrasonic Flow Meters Animation
Ultrasonic Flow meters measures Fluid velocity by sending ultrasonic pulse from an upstream transducer to a downstream transducer and back again.
Last updated: October 31, 2023 2:35 pm
Animation Flow Measurement
3 Min Read
An ultrasonic flow meter is a meter that measures the flow by detecting the action of fluid flow on an ultrasonic beam (or ultrasonic pulse).
Ultrasonic Flow MetersFeatures of Ultrasonic Flow MetersAdvantages of Ultrasonic Flow MetersDisadvantages of Ultrasonic Flow MetersApplications of Ultrasonic Flow Meters
    Fluid velocity is measured by sending an ultrasonic pulse from an upstream transducer to a downstream transducer and back again.
    The measured difference in the amount of time that each pulse takes to traverse the pipe is directly proportional to the mean fluid velocity.
    Ultrasonic flow meters use this measured velocity to calculate the liquid flow rate based on user-entered information about the process application.
    • Easy to carry;
    • Low maintenance;
    • Can only be used to measure cleaning liquids;
    • Not subject to pipe diameter restrictions;
    • No flow obstruction measurement, and no additional pressure loss.
    • Ultrasonic meters are made up of no moving parts.
    • They experience no pressure loss.
    • They endow with maintenance-free operation. It is a key advantage as compared to conventional mechanical meters such as positive displacement meters, turbines, etc.
    • Furthermore, Ultrasonic flow meters are consistently more accurate and reliable than a lot of other metering systems.
    • With the emergence of 3-beam ultrasonic, all other flow meters like mass, vortex, positive displacement, and turbine flow meters which are used to measure non-conductive fluids, have been successfully replaced by ultrasonic meters.
    • Still problematic for liquid and gas measurements
    • The sound beam must traverse a representative cross-section, therefore flow profile is dependent. Long inlet and outlet sections required
    • Errors due to deposits
    • Transit time meters require clean liquids
    • Doppler meters only for slight contamination or few gas bubbles
    • Doppler meters are affected by sound velocity changes due to temperature, density, and concentration
    • Unsuitable for heavily contaminated liquids
    • Gas bubbles cause errors
    • Ultrasonic flow meters are perfect for wastewater applications or any other dirty liquid that is conductive or water-based.
    • Ultrasonic flow meters normally do not work with distilled water or drinking water. Aerations would be needed in the clean liquid applications.
    • Ultrasonic flow meters are also best suited for applications where low-pressure drop, chemical compatibility, and low maintenance are involved.
    • Reasons to Calibrate Flow Meters
    • Difference between Flow Meters
    • Wedge Flow Meter Principle
    • Positive Displacement Flow Meter
    • Turndown Ratio of a Flow Meter
    Normally-open and Normally-closed Switch Contacts
    All About Instrumentation Impulse Lines
    Scintillation Counter Principle
    Load Cell Working Principle
    Why Turndown Ratio is important when Selecting a Flow Meter?
    Non Contacting Radar Level Transmitter Animation
    Basics of Globe Valves
    Relay Working Animation
    Proximity Switch Working Animation
    TOC Analyzer Working Principle
    Pressure Transmitter Animation
    Lobed Impeller Flow Meters Working Principle
    Flow meter Turndown Ratio
    Importance of Flow Meter Turndown Ratio
    Linear to Square Root Extraction
    Pneumatic Actuators Types Animation
    Types of Pneumatic Actuators Animation
    Sick Flow meters
    Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
    Turbine Flow Meter Installation Procedure
    How a Level Switch Works
    Mass Flow Calculations of flow measurement
    MOS Gas Sensor Principle
    MOS Type Gas Sensor Principle
    Boiler Feed Water Heater Shell Flange Leaks
    Air Circuit Breaker (ACB)
    Types of Relays used in an Air Circuit Breaker (ACB)
    Control Valves Pre-Commissioning Checklist
    IP transducer
    Pilot Valves and Pneumatic Amplifying Relays
    Induction Motor Interview Questions & Answers
    Current to Pressure Converter Principle
    Current to Pressure (I/P) Converter Principle
    OB10 Time of Day Interrupt
    Tia Portal – OB10 Time of Day Interrupt Organization Block
    Level Gauge Interface Measurement
    Level Gauge Interface & Temperature Problems
