Reading: Types of Signals Based on Electromagnetic Compatibility (EMC Performance)
Inst Tools > Blog > Common > Types of Signals Based on Electromagnetic Compatibility (EMC Performance)
Learn the types of signals based on electromagnetic compatibility (EMC Performance) in electrical and electronic circuits.
Last updated: August 28, 2023 3:38 pm
Common
A very common issue occurring in electrical and electronic circuits is electromagnetic interference. It is also called EMI in electrical terms. This problem hampers the performance of a circuit in a very big way, if not restricted in time. To tackle them, another term related to electrical circuits is EMC.
What Causes Electromagnetic Interference?EMC PerformanceClass-1 (Sensitive)Class-2 (Slightly sensitive)Class-3 (Slightly interfering)Class-4 (Interfering)
EMC stands for electromagnetic compatibility. It is the ability of electrical equipment and devices to restrict the EMI in their systems. Based on EMC, various types of signals are classified according to their performance. In this post, we will learn the types of signals based on EMC performance.
Everyone knows that the electrical field and magnetic field are related to each other. When electricity flows through a circuit, it produces a magnetic field around it. This theory is the base of electricity. Inversely, a moving magnetic field also produces an electric current. Electricity is nothing but the flow of electrons and atoms in it.
Atoms can be positively or negatively charged. Opposite poles attract each other and the same poles repel each other. This rapid movement of electrons produces a magnet like operation every time, thus generating a magnetic field.
Now, inversing the theory as discussed, a moving magnetic field indirectly pushes or pulls electrons in it. This flow of electrons generates an electric field near it. So, this base of electricity is the foundation of other theories.
Now, coming back to our concept, let us first understand how EMI is generated. Basically, electromagnetic interference can be man-made or natural. In natural causes, sources like lightning, solar storms, and solar flares produce high electrostatic discharges. When this discharge interacts with the electromagnetic field, it produces spikes and surges in such a way that signal distortion occurs.
This means, a normal electromagnetic field has some standard electrical and magnetic field calculations, which is suddenly disturbed by these interferences. It produces very high rates of changes in signals, thus distorting it.
Similarly, man-made interferences can be caused by high radio frequencies, improperly designed devices, high-power motors, transformers, or other types of conductors. The signals of high frequency are always emitted from them, which interferes with other electromagnetic fields, causing EMI.
EMC Performance
Electromagnetic
To reduce electromagnetic interference, the EMC term comes into the picture. As discussed earlier, EMC is the ability of devices to tackle electromagnetic interference and reduce its effect. This compatibility is the main factor for reducing interference.
So, the electrical circuits designed for EMC are classified in various categories. These circuits handle the electromagnetic noise according to their EMC factors. Based on this EMC performance, the signals are classified into four types:
Class-1 (Sensitive)
This is the lowest category of circuits, which has the highest effect of electromagnetic interference in it. They carry low-level signals like analog output, instrument transformers, measuring circuits, probes, and radio receivers. These signals are immediately affected by EMI and have very less EMC factors.
These cables are slightly sensitive to electromagnetic interference. They are low-level digital circuits, instrument transformers with digital outputs, control circuits for resistive load, and low-level DC power supplies. These signals can disturb class-1 signals too.
These cables have fewer effects on EMI on them, but a negative point is that they start to disturb other lower-class signals. So, instead of being sensitive, they slowly categorize themselves into slightly interfering. They disturb class 1 and 2 signals.
They are control circuits for inductive loads (relay, contactor, coil), AC power supplies, and main power supplies for high-power devices. It is from these types of signals that they start to carry noise, though they themselves are less susceptible to EMI.
These cables are the least affected by EMI (highest levels of EMC), but the highest source of EMI disturbance for other cables. They disturb the other three classes’ cables. The types are welding machines, high-power circuits, electronic speed controllers, and SMPS. They are thus, also named as interfering signals.
In this way, we saw the various types of signals based on EMC performance.
Measurement Unit Conversions
How Does Starlink Work?
Understanding RS-485 Communication
Introduction to MEMS (Microelectromechanical Systems)
What is an Instrument Skid? – Example of Metering Skid
Know the Best Path to Achieve SOA-C02 Exam Certification
The Impact of Knowledge Management Platforms on Business Operations
How to Use a Paint Thickness Gauge?
Vision Camera Systems in Industrial Automation
Applications of Robots in Various Fields
The Information About Resistor Color Code You Should Know
Best Engineering Mobile Apps on Google Play & App Store
What is PPE? – Types – Personal Protection Equipment
Critical Factors to Consider for Engineering Students to Ensure a Smooth Path
Encoder Principle
Encoder Working Principle
Bracelet Scanner
How to Use Bracelet Scanner? – Ultrasonic Thickness Gauge
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
Essential Safety Tips for Glass Workers
Piezo-electric Acceleration Measuring Device
Difference between DSP and DAC - Digital Electronics
Difference between DSP and DAC – Digital Electronics
Arduino Zero
What is Arduino? Different Models of Arduino Controllers
Microprocessors Objective Questions – Set 5
Comparison of Pressure Instruments - Industrial Instrumentation
Comparison of Pressure Instruments – Industrial Instrumentation
pn-junction-with-depletion-layer
How a PN Junction Formed in a Diode
Advanced Process Control
What is Advanced Process Control (APC)?
Insulators, Conductors and Semiconductors
Pressure Transmitters Filled impulse lines
Siemens Simatic HMI
How to Design an Effective HMI? – Human Machine Interface
Measuring Instruments MCQ
