Reading: Types of Relays – Questions and Answers
Inst Tools > Blog > Electrical MCQ > Types of Relays – Questions and Answers
Understand the different types of relays through our detailed questions and answers for electrical and electronics engineering students.
Last updated: August 31, 2024 8:12 pm
Electrical MCQ Electronics MCQ Instrumentation MCQ
16 Min Read
Types of RelaysWhat is an SPST relay?What is an SPDT relay?What is a DPST relay?What is a DPDT relay?What is a TPST relay?What is a TPDT relay?What is a 4PST relay?What is a 4PDT relay?What are Electromechanical Relays?What are Solid State Relays (SSR)?What are Reed Relays?What are Hybrid Relays?What are Thermal Relays?What are Mercury Wetted Relays?What are Polarized Relays?What are Overcurrent Relays?What are Impedance Relays?What are Differential Relays?What are Distance Relays?What are Frequency Relays?What are Supervisory Relays?What are Buchholz Relays?What are Time Delay Relays?What is a Form A relay?What is a Form B relay?What is a Form C relay?What is a Form D relay?What is a Form X relay?What is a Form Y relay?What is a Form Z relay?What is a Form U relay?What is a Form K relay?What is a Form R relay?What is a Form S relay?What is a Form W relay?Which relay type is commonly used for simple on/off control applications?Which relay configuration is best for switching between two power sources?What type of relay is suitable for controlling three-phase motors?Which relay is ideal for reversing the direction of a motor?For applications requiring the simultaneous disconnection of two circuits, which relay should be used?What relay type is used when a circuit needs to alternate between two outputs?Which relay configuration is used for complex switching operations requiring multiple circuits?Which relay type can control four separate circuits simultaneously?What type of relay is used for applications requiring delayed operations?Which relay type is best for switching high current loads with minimal contact wear?What relay type is used to protect electrical equipment by comparing the current entering and leaving a protected zone?Which relay type is suitable for applications requiring memory functions?Which relay type is most suitable for applications requiring alternate control between two circuits?Which relay is ideal for industrial applications requiring high current switching?What type of relay is used to control all phases of a three-phase motor simultaneously?
Types of Relays
The electrical video below provides detailed explanations for the relay questions.
Relay Types - Electrical Questions and Answers
Question 1
A. A relay with two poles and single throw
B. A relay with a single pole and single throw
C. A relay with four poles and double throws
D. A relay with three poles and two throws
Show the Answer
Question 2
A. A relay with two poles and two throws
B. A relay with one pole and two throws
C. A relay with one pole and one throw
D. A relay with three poles and three throws
Show the Answer
Question 3
A. A relay with four poles and single throw
B. A relay with two poles and two throws
C. A relay with three poles and two throws
D. A relay with two poles and single throw
Show the Answer
Question 4
A. A relay with two poles and double throws
B. A relay with three poles and triple throws
C. A relay with one pole and double throws
Show the Answer
Question 5
B. A relay with three poles and single throw
Show the Answer
Question 6
A. A relay with four poles and triple throws
B. A relay with three poles and three throws
C. A relay with three poles and double throws
D. A relay with three poles and single throw
Show the Answer
Question 7
B. A relay with two poles and single throw
C. A relay with four poles and single throw
D. A relay with four poles and double throws
Show the Answer
Question 8
B. A relay with four poles and double throws
D. A relay with four poles and triple throws
Show the Answer
Question 9
A. Relays using mechanical movement to open/close contacts
B. Relays with semiconductor components
C. Relays with no moving parts
D. Relays that use pneumatic control
Show the Answer
Question 10
A. Relays with mechanically operated switches
B. Relays using semiconductors for switching
C. Relays using thermal actuators
D. Relays with mercury-wetted contacts
Show the Answer
Question 11
A. Relays with hermetically sealed contacts actuated by a magnetic field
B. Relays sensitive to voltage changes
C. Relays with heavy-duty contacts
D. Relays using pneumatic controls
Show the Answer
Question 12
A. Relays combining mechanical and solid-state components
B. Relays with thermal bimetallic strips
C. Relays with only mechanical parts
D. Relays that use vacuum tubes
Show the Answer
Question 13
A. Relays that respond to temperature changes
B. Relays with vacuum-sealed contacts
C. Relays that use semiconductors
D. Relays operated by magnetic fields
Show the Answer
Question 14
A. Relays with solid-state components
B. Relays with bimetallic strips
C. Relays with mercury-wetted contacts for low resistance
D. Relays operated by air pressure
Show the Answer
Question 15
A. Relays that use a permanent magnet to maintain a set position
C. Relays with thermal actuators
D. Relays with no polarity sensitivity
Show the Answer
Question 16
A. Relays sensitive to temperature
B. Relays that activate with excess current
C. Relays using time delay mechanisms
D. Relays with solid-state components
Show the Answer
Question 17
A. Relays that measure impedance to determine faults
B. Relays with mercury contacts
C. Relays sensitive to voltage changes
D. Relays with bimetallic strips
Show the Answer
Question 18
A. Relays comparing two electrical quantities
B. Relays with mechanical contacts
C. Relays that operate based on frequency changes
D. Relays using thermal sensors
Show the Answer
Question 19
A. Relays measuring the distance to a fault
C. Relays that use thermal expansion
Show the Answer
Question 20
A. Relays sensitive to voltage
B. Relays that respond to frequency variations
C. Relays that measure current
D. Relays with thermal actuators
Show the Answer
Question 21
A. Relays that monitor and control other relays
C. Relays with bimetallic strips
D. Relays using solid-state components
Show the Answer
Question 22
A. Relays used in power lines
B. Relays measuring temperature changes
C. Relays with solid-state components
D. Gas-actuated relays for oil-filled transformers
Show the Answer
Question 23
A. Relays with mechanical contacts
B. Relays with instantaneous operation
C. Relays sensitive to current changes
D. Relays that operate after a preset time delay
Show the Answer
Question 24
A. Relay with DPST contacts
B. Relay with SPST normally closed contact
C. Relay with DPDT contacts
D. Relay with SPST normally open contact
Show the Answer
Question 25
B. Relay with SPST normally open contact
D. Relay with SPST normally closed contact
Show the Answer
Question 26
A. Relay with SPDT contact
B. Relay with DPST contacts
C. Relay with SPST normally closed contact
Show the Answer
Question 27
A. Relay with SPDT normally closed contact
B. Relay with DPDT contacts
C. Relay with DPST normally open contacts
Show the Answer
Question 28
A. Relay with SPST normally open contact
B. Relay with SPST normally open and normally closed contacts
D. Relay with DPDT contacts
Show the Answer
Question 29
A. Relay with SPST normally open and normally closed contacts
B. Relay with DPST normally open contacts
C. Relay with SPST normally open contact
Show the Answer
Question 30
A. Relay with DPST normally open contacts
B. Relay with SPDT normally open and normally closed contacts
C. Relay with DPST normally closed contacts
D. Relay with SPDT normally closed contact
Show the Answer
Question 31
A. Relay with DPST normally closed contacts
C. Relay with DPDT normally closed contacts
Show the Answer
Question 32
B. Relay with SPDT normally open contact
D. Relay with DPDT contact configuration
Show the Answer
Question 33
C. Relay with SPDT normally closed contact
Show the Answer
Question 34
A. Relay with SPDT normally open contact
D. Relay with DPST normally open contacts
Show the Answer
Question 35
B. Relay with DPDT contact configuration
Show the Answer
Question 36
A. SPST
B. TPST
C. SPDT
D. DPDT
Show the Answer
SPST
Question 37
A. SPDT
B. SPST
C. DPST
D. 4PDT
Show the Answer
SPDT
Question 38
A. DPDT
B. TPST
C. SPDT
D. SPST
Show the Answer
TPST
Question 39
A. DPST
B. SPDT
C. SPST
D. DPDT
Show the Answer
DPDT
Question 40
A. 4PDT
B. DPST
C. SPST
D. SPDT
Show the Answer
DPST
Question 41
A. SPST
B. 4PST
C. DPST
D. SPDT
Show the Answer
SPDT
Question 42
A. DPDT
B. 4PST
C. SPST
D. SPDT
Show the Answer
DPDT
Question 43
A. 4PST
B. SPDT
C. SPST
D. DPDT
Show the Answer
4PST
Question 44
A. Reed Relay
B. Thermal Relay
C. Time Delay Relay
D. Differential Relay
Show the Answer
Time Delay Relay
Question 45
A. Differential Relay
B. Buchholz Relay
C. Mercury Wetted Relay
D. Impedance Relay
Show the Answer
Question 46
A. Impedance Relay
B. Reed Relay
C. Thermal Relay
Show the Answer
Differential Relay
Question 47
A. Polarized Relay
B. Mechanical Relay
C. Differential Relay
D. Time Delay Relay
Show the Answer
Polarized Relay
Question 48
A. SPDT
B. SPST
C. 4PST
D. DPST
Show the Answer
SPDT
Question 49
A. DPDT
B. SPST
C. SSR
D. 4PDT
Show the Answer
SSR
Question 50
A. SPDT
B. TPST
C. SPST
D. DPDT
Show the Answer
TPST
  • PLC MCQ Questions and Answers
  • Difference Between Contactor and Relay
  • Switch Types and Common Terminology
  • Power System Protection and Relays Questions
  • Single Phase Preventer Relay Working Principle
Electronic Amplifiers Objective Questions
DC Machine Quiz
Industrial Automation Components Questions and Answers
Data Transmission Objective Questions
Electrical & Electronics Measurements Objective Questions – Set 4
Electrical Welding Multiple Choice Questions and Answers (MCQ)
Electronic Devices & Circuits Quiz – Set 8
DC Motors Characteristics Quiz
PID Controller Multiple Choice Questions
Time Division Multiplexing Objective Questions
Process Control & Instrumentation Objective Questions – Set 3
Tomography Objective Questions
Chemical Sensors Objective Questions
illumination Multiple Choice Questions and Answers
illumination Multiple Choice Questions and Answers (MCQ)
Compensation Winding Quiz
Power Systems MCQ Series 5
Electrical Engineering Materials Objective Questions
200 Electrical Engineering Materials Objective Questions & Answers
Fiber Optic Measurement Techniques
Fiber Optic Measurement Multiple Choice Questions (MCQ)
Electronic Devices & Circuits Quiz – Set 15
Differences between No-load Supply Current and Load Current
PLC Program for Car Parking
PLC Program for Entry and Exit Control of Car Parking
Concepts of State, State Variables & State Model
Transformer Efficiency
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
Solar Pump
What is a Solar Pump VFD? – Advantages, Principle
Electric Motor Actuators
What is Motor Actuator ?
Weighing Balance Calibration
Calibration Procedure of Weighing Balance and Common Mistakes
