Reading: Turbine Flow Meter Installation Procedure
Inst Tools > Blog > Erection & Commissioning > Turbine Flow Meter Installation Procedure
Turbine Flow Meter installed with respect to the arrow pointing in the direction of fluid flow. Learn the installation procedure.
Last updated: November 2, 2023 11:22 am
Erection & Commissioning Flow Measurement
2 Comments
7 Min Read
Turbine flow meters are designed with wear-resistant internal components to provide trouble-free operation and long service life.
Turbine Flow MeterInstallation ProcedureStart-Up ProcedureOperation LimitationsCorrosionPulsationVibrationFilter/StrainerTurbine Flowmeter Troubleshooting Guide
Turbine Flow Meter
Fluid entering the flow meter is first conditioned by the inlet flow straightener which reduces turbulence in the fluid.
The moving fluid causes the rotor to spin at a speed that is proportional to its flow rate.
As the blades on the rotor pass through the magnetic field of the pickup, an electronic pulse is generated.
This pulse train signal can then be used to monitor the fluids actual flow rate or the total amount of fluid that has passed through the flow meter.
The number of electronic pulses generated by the meter, per unit volume, is known as its K-Factor. Each flow meter is calibrated to find its unique K-Factor, which is supplied with the flow meter when purchased.
Before installation, the flow meter should be checked for foreign material and to ensure that the rotor spins freely.
All upstream fluid lines should also be cleared of any debris. Also, make sure that fluid flow has been shut off and all pressure in the lines has been released prior to installing the flow meter into an existing system.
The flow meter must be installed with the flow direction arrow pointing in the direction of fluid flow. The flow direction arrow can be found on the side of the flow meter.
The flow meter is designed to work in any orientation, but the preferred orientation is to have the meter installed in horizontal piping.
The fluid to be measured is recommended to be filtered. The best location for the filter or strainer would be upstream of the flow meter, after any other system components, while maintaining straight piping requirements.
The preferred plumbing setup is one containing a bypass line (above figure). This allows meter inspection and repair without interrupting flow, as well as the ability to cycle the fluid through the system filter before diverting to the flow meter.
If a bypass line is not used, it is important that all flow control valves be located downstream of the flow meter (below figure).
Turbine Flow Meter Guide
For optimum flow meter performance a minimum length of upstream and downstream piping is required.
It is recommended that a minimum length equal to 10 pipe diameters of straight pipe be installed directly on the upstream side of the flow meter and 5 pipe diameters on the downstream side of the flow meter.
This helps to eliminate turbulence in the fluid. Having shorter pipe lengths, other system components and elbows to close to the flow meter may adversely affect the accuracy and repeatability of the flow meter. Piping should be the same size as the meter bore or port size.
Do not locate the flow meter or the connection cable close to electric motors, transformers, sparking devices, high voltage lines or place connecting cable in a conduit with wire supplying power for such devices.
These devices can induce false signals in the flow meter coil or cable, causing the meter to read inaccurately.
Start-Up Procedure
The following procedures should be observed when installing the flow meter and running it for the first time after installation.
  1. After meter installation, close the isolation valves and open the bypass valve. Flow liquid through the system for a sufficient time to eliminate any air or gas in the flow line.
  2. Slowly open the upstream isolating valve to fill the flow meter with liquid.
  3. Open the downstream isolating valve to start fluid flow through the flow meter, permitting the flow meter to start to operate, then close the bypass valve completely.
  4. If the downstream valve is used as a flow control valve, adjust the valve to provide the required flow rate through the flow meter.
Note :
  • Air and gas, running at a high velocity, can damage the internal components of the flow meter.
  •  Never hit a flow meter, empty of fluid, with full fluid flow. This fluid shock or hammering effect on the internals of the flow meter can permanently damage the internal components.
We will discuss some important operation limitations regarding the turbine flow meter here.
  • Corrosion,
  • Pulsation,
  • Vibration,
  • Filter/Strainer
Corrosion
The internal parts are constructed from stainless steels and tungsten carbide with a nickel binder. Ensure that your fluid is compatible with these materials.
Incompatible fluids could deteriorate the internal parts, causing inaccurate readings. Consult the manufacturer of the fluid regarding its chemical compatibility with these materials.
Pulsation
Severe fluid pulsation will have a negative effect on the flow meters accuracy and may shorten the life of the flow meter.
Vibration
Severe vibration may decrease the life of the flow meter.
Filter/Strainer
A filter or strainer is recommended to be installed upstream of the flow meter. Particles entering the flow meter may cause pitting of the internal components, reducing its service life.
Build up of particles on rotating parts can adversely affect the performance of the flow meter.
Turbine Flowmeter Troubleshooting Tips
Reference:  Aw-lake Turbine Flow Meter Manual
  • Continuous Flow Measurement
  • Liquid Flow Control Loop Controller
  • What is a Paddle wheel flow meter?
  • Fundamentals of Valves and Types
  • DP Flow Transmitter Re-Ranging
Orifice Plate Questions and Answers
Magnetic Flow Meter Animation
Piston Flow Meters Working Principle with Animation
Coriolis Flow Meter Construction
Installation & Commissioning Tips for HART Devices
Monsoon Protection for Field Instruments and Junction Boxes
2 Comments
  • shantilal parmar says:
    July 5, 2018 at 4:31 pm
    Instrumentation tool is very helpful site for engineers
    Thanks
  • Sunil says:
    September 3, 2019 at 12:18 pm
    thanks for this article!
Square-root characteristics of Differential Pressure Flow Meters
P&ID Guidelines for Pumps Heat Exchangers
Instrumentation Cables Armor
Important Factors Consider during Piping Design
V Cone Flow Meter – Principle, Advantages, Disadvantages
What is a Turbine Flow Meter?
DP Level Measurement Problems
What is a Thermal Flow Meter?
What is a K Factor
Flow Meter K-factor and Calculations
Instrumentation Cables Questions Answers
Instrumentation Cables Questions & Answers
What is a Condensate Pot? How to Install it?
Difference between Orifice & Restriction Orifice
orifice-plate
Orifice Plate Turndown ratio
What is Instrument Air Manifold
What is Instrument Air Manifold ?
What is Averaging Pitot Tube
What is an Averaging Pitot Tube? – Principle, Advantages
Orifice Flow Measurement Formula
Basics of Flow Measurement
Motion Detection based Street Light PLC Logic Solution
Motion Detection based Street Light: PLC Logic Solution
One Shot Rising PLC Example Program
Transformers Coolers Weld Joints Oil
Transformers Coolers Weld Joints Oil Oozes Were Eye Sores
Three Element Drum Level Control System
DTMF Based Project Topics and Ideas
Top 100 DTMF Based Projects, Topics and Ideas
Electron Spin Resonance Questions & Answers
Bolted to Vessel Flange Displacer Level Transmitter
Seal Level Differential Pressure Transmitter Problems
Types of Industrial Relays
What is a Relay? Types of Industrial Relays
