Reading: Transistor as Amplifier
Inst Tools > Blog > Electronic Devices & Circuits > Transistor as Amplifier
Last updated: September 27, 2016 3:58 pm
1 Min Read
A transistor raises the strength of a weak signal and thus acts as an amplifier. The Below Fig shows the basic circuit of a transistor amplifier. The weak signal is applied between emitter-base junction and output is taken across the load RC connected in the collector circuit.
In order to achieve faithful amplification, the input circuit should always remain forward biased. To do so, a d.c. voltage VEE is applied in the input circuit in addition to the signal as shown. This d.c. voltage is known as bias voltage and its magnitude is such that it always keeps the input circuit forward biased regardless of the polarity of the signal.
As the input circuit has low resistance, therefore, a small change in signal voltage causes an appreciable change in emitter current. This causes almost the same change in collector current due to transistor action. The collector current flowing through a high load resistance RC produces a large voltage across it. Thus, a weak signal applied in the input circuit appears in the amplified form in the collector circuit. It is in this way that a transistor acts as an amplifier.
What is Kirchhoff’s Current Law
Transistor Amplifier Working Principle
Applications of Photo diodes
Electronic Symbols
Combining Independent Voltage Sources in Series
Center Tapped Full Wave Rectifier Operation
Positive & Negative Diode Clippers
Phototransistor Working Principle
Characteristics of Photo diode
Seven Segment Display Working Principle
How a Multi Color LED Works ?
Comparison of Transistor Configurations
Semiconductors Diodes Questions & Answers
Forward Bias & Reverse Bias of a Diode
basic-electronics-questions-answers
Basic Electronics Questions & Answers
parallel-resistors-circuit-example
Series and Parallel Resistors
Derivation-of-Ohms-Law
Basics of Ohm’s Law
Schottky Diode Vs PN junction Diode
Difference between Schottky Diode and PN junction Diode
full-wave-bridge-rectifier-with-voltage-regulator
Basics of Voltage Regulators
Short Circuit and Open Circuit
Why Silicon is preferred over Germanium ?
Optocoupler Principle
Optocouplers Working Principle
statuses of all lamps and relay coils in the circuit
Analyze the Relay Circuit and Find the Status ?
factorytalk view studio hmi
How to Create Templates in FactoryTalk View Studio?
Control Valve in PlantPAx Project
Configuration of Control Valve in Studio 5000
Edge Detection in PLC
Edge Detection in PLC Programming
LAYERS OF PROTECTION ANALYSIS
Layers of Protection Analysis (LOPA) Interview Questions
Overview of Proximity Switches
Four Wire RTD Circuit
What is a Four-wire RTD ?
Car Cooling System Automotive Radiator
What is an Automotive Radiator?
