Reading: How to Test a Battery using a Multimeter?
Inst Tools > Blog > Common > How to Test a Battery using a Multimeter?
In this article, we will learn the detailed step-by-step procedure regarding how to test a battery using a multimeter.
Last updated: February 24, 2023 1:10 pm
Common Electronic Basics
Batteries are required in almost many electronic instruments. Be it your TV remote or a car, a battery is used in it to charge the corresponding devices. But, many times, we get confused as to how long we can run the battery.
Bad Battery SymptomsHow to Test a Battery with a Multimeter?
A battery has some rated voltage and it will run for a certain period of time. But, if we overuse it sometimes, then it may get drained easily.
So, we need to sometimes test the battery if we feel that it is going to die before we get into any issues. Batteries are normally tested using a multimeter.
A battery is defined by its rated voltage. A rated voltage can be for example 1.5V. So, this means that the battery will power the devices requiring this voltage.
If the battery voltage goes lower than this, then the battery is dead and needs to be either replaced or charged in case of chargeable batteries. There are some symptoms to see whether the battery is going dead or not.
Let us see some of them:
  1. If the battery is getting drained quickly, then you will notice that the device is malfunctioning quickly.
  2. If you notice some physical issues like heating, leaking, or broken terminals, then it is a sign of a bad battery.
  3. The third and most general one is voltage. If you check the voltage and find it low below the rated voltage, then it is dead.
These signs generally indicate that the battery is of no use.
How to Test a Battery using Multimeter
As discussed, the most technical way to test a battery is by using a multimeter. The standard way to check is by checking the voltage. Because we have only this parameter to understand a battery function. The voltage of a battery is in DC form. So, we need to keep the multimeter function in DC voltage.
Simply, connect the multimeter probes to the battery. The red probe will be connected to the positive end of the battery and the black probe will be connected to the negative end of the battery.
Suppose, for example, the rated voltage is 2V. The basic rule is that the voltage must not be lower than at least 1V minus the rated voltage. So, if you find that the voltage is less than 1.9V, then it means that the battery is of no use now.
You can always compare the battery with another one. This is the best way to cross-check it. If you find that the other one has a greater voltage than the testing one, and if it is also powering up the device properly, then it is a clear indication that the voltage testing you did was correct and the battery is not performing as per expectation.
As a battery powers a load, we can also check it under load conditions using a multimeter. The way we connected probes to the battery, connect a resistor across the probes.
Connecting a resistor means voltage will drop, which is equal to simulating a load. When the load is connected, the voltage drops a little across the battery. By connecting the resistor, if the voltage drops only a little (within the desired band as discussed earlier), then the battery is fine. But if the battery voltage drops sharper, that means the battery is of no use.
In this way, we understand how to test a battery using a multimeter.
  • What is Non-Linear Device?
  • Electrical Motor Concepts
  • IEC Resistors Color Code
  • What is Electrical Wire Mesh?
  • Factors Affecting Inductance
How does the IIoT work? – Industrial Internet of Things
Field Instrumentation Tips
Modern Instrumentation & IoT: Key Innovations & Trends
FPGA vs. CPLD – What are the differences between them
What is Hot Air Welding? – Advantages
What is an IP address? How to Set IP Address of the Computer?
What is a Diaphragm Pump?
Proximity Sensor
Different Types of Sensors used in Automotive Vehicles
What is Linear Electric Motor?
Top 3 Online Bachelor’s Programs in Electronics Engineering
The Aghorn Hydrogen Sulfide Accident – H2S Gas
How Not to Install an Instrument and Wrong Practices
Accuracy, resolution, range, counts, digits and precision
Definition of Accuracy, Precision, Resolution, Range
Pilot Operated Back Pressure Regulator Valve
Caliper Calibration
What is a Differential Mode Signal
Difference Between Differential Mode and Common Mode
Video Borescope
5 Questions to Ask Before Choosing Your Industrial Borescope
Web Tension Measurement
Web Tension Measurement and Control Technologies
Sugar Industry Logics
Mill Interlocks in the Sugar Industry
Difference Between Resistive Touch and Capacitive Touch
Programmable Read Only Memory Objective Questions – Part 1
Structured Text PID control loop in PLC
Positive Displacement Pumps
What are Positive Displacement Pumps and their Types?
Inability to Test Repaired HT Motors
Inability to Test Repaired HT Motors in Workshop Posed Problems
PN Junction Questions & Answers
Measurement and Instrumentation Objective Questions – Part 5
Cage-guided globe valves
What is Cage-guided Globe Valve ?
Instrumentation and Control Engineer Subject
Competency Factors of Instrument & Control Engineer (Design Engineering)
