Reading: Temperature Sensor calibration procedure
Inst Tools > Blog > Calibration > Temperature Sensor calibration procedure
Last updated: September 15, 2016 9:43 pm
Calibration Temperature Measurement
2 Min Read
Most instrument manuals state there is no calibration of the temperature sensor, but the temperature sensor must be checked to determine its accuracy. This accuracy check is performed at least once per year and the accuracy check date/information is kept with the instrument.
If the accuracy check date/information is not included with the instrument or the last check was over a year, the temperature sensor accuracy needs to be checked at the beginning of the sampling event. If the instrument contains multiple temperature sensors, each sensor must be checked.
This procedure is not normally perform in the field. If the instrument is obtained from a rental company, the rental company should performed the calibration check and include with the instrument documentation that it was performed.
Temperature-gauge-calibration
Calibration Procedure:
1. Fill a container with water and adjust the water temperature to below the water body’s temperature to be measured. Use ice or warm water to adjust the temperature.
2. Place a thermometer that is traceable to the National Institute of Standards and Technology (NIST) and the instrument’s temperature sensor into the water. Wait for both temperature readings to stabilize.
3. Compare the two measurements. The instrument’s temperature sensor must agree with the reference thermometer measurement within the accuracy of the sensor (e.g.,±O.2°C). If the measurements do not agree, the instrument may not be working properly and the manufacturer needs to be consulted.Calibration-of-a-temperature-sensor
4. Adjust the water temperature to a temperature higher than the water body to be measured.
5. Compare the two measurements. The instrument’s temperature sensor must agree with the reference thermometer measurement within the accuracy of the sensor (e.g.,± 0.20 C). If the measurements do not agree, the instrument may not be working properly and the manufacturer needs to be consulted.
Temperature Sensor Accessories
Thermal Imaging Temperature Measurement
Temperature Measurement Interview Questions
Thermocouple Calibration
Thermocouples Law of Intermediate Metals
  • Mohan says:
    November 30, 2017 at 9:47 am
    What is 3 -Point Calibration especially for Thermcouples
Seebeck Effect Theory
What is Bump Testing ?
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Electrical Standards
Resistance Temperature Detectors Troubleshooting Tips
General Specification of Thermowell
How to calculate the tolerance of a RTD sensor
Bimetallic strip thermostat
Mechanical Temperature Measuring Sensors
Temperature Coefficient of Resistance
Temperature Coefficient of Resistance (α)
Temperature Sensors Questions
Questions on Thermocouple and Pyrometer
Filled-bulb Temperature Measurement
Filled-bulb Temperature Sensors
Single Position Calibration of Temperature Bath
Three Wire RTD Circuit
What is a Three-wire RTD ?
Convert 2 wire RTD to 4 wire RTD Sensor
How to Convert 2 wire RTD into 3 or 4 wire RTD?
Sand Probe Functional Testing
What is a Thermostat
Thermostat – Types, Working Principle, Advantages, Applications
Ultrasonic Level Switch Principle
Sinking and Sourcing Devices Operation
What is Photoionization Detector (PID)
What is Photoionization Detector (PID)?
Nonlinear Control Systems
Constructing Phase-Trajectories
Electrical Torsion Meter
Electrical Torsion Meter Principle
PLC project for traffic signals automation
Complete PLC Project: Traffic Light Auto and Manual Automation
baffle-and-nozzle assembly
Pneumatic Sensing Elements
