Reading: What Temperature are Celsius and Fahrenheit Value Same ?
Inst Tools > Blog > Temperature Measurement > What Temperature are Celsius and Fahrenheit Value Same ?
Last updated: November 1, 2019 9:52 am
3 Min Read
Simple Conversions of Celsius and Fahrenheit Temperature Scales
1. Standard Conversion2. Use 1.8 instead of 9/53. Add 40, Multiply, Subtract 404. Fast Conversion but NOT Accurate : What Temperature are Celsius and Fahrenheit Value Same?Reason :
°F to °C : Deduct 32, then multiply by 5, then divide by 9
°C to °F : Multiply by 9, then divide by 5, then add 32
°C to °F :  °C × 1.8 + 32 = °F
°F to °C :  (°F − 32) / 1.8 = °C
°C to °F : Add 40, multiply by 9/5, then subtract 40
°F to °C : Add 40, multiply by 5/9, then subtract 40
°C to °F : Double, then add 30
°F to °C : Subtract 30, then halve
The formulas for converting between degree Celsius and degree Fahrenheit are:
°F = (°C * 9/5) + 32
°C = (°F – 32) * 5/9
To find the temperature when both are equal, we use an old algebra trick and just set ºF = ºC and solve one of the equations.
°C = (°C * 9/5) + 32
°C – (°C * 9/5) = 32
-4/5 * °C = 32
°C = -32 * 5/4
°C = -40
°F = (°F * 9/5) + 32
°F – (°F * 9/5) = 32
-4/5 * °F = 32
°F = -32 * 5/4
°F = -40
So the temperature when both the Celsius and Fahrenheit scales are the same is -40 degrees.
Reason :
Both the Celsius to Fahrenheit and Fahrenheit to Celsius equations are linear (no quadratic terms) implying they are straight lines. They have different slopes and are non-parallel with a single solution. If we solve for this solution or plot both the lines, we see that the intersect at (-40,-40). The fact that they intersected at a whole number is purely coincidental.
Anders Celsius actually defined his temperature scale exactly the opposite way that everybody thinks he did. He originally defined 0 as the boiling point and 100 as the freezing point. This was changed around the time of Celsius’ death in 1744, by two eminent contemporary scientists working independently of each other — Frenchman Jean-Pierre Christin and Celsius’ fellow Swede Carolus Linnaeus. Since this matched the arrangement of the other scales then in use (Fahrenheit and Reaumur, mostly — Kelvin and Rankine were about a century away still), the proposals were widely accepted and we still use 0 for freezing and 100 for boiling today.
Also Read : Peltier Effect Theory
What is Thermowell and How-to choose Thermowell Probe Length ?
Calibration of Temperature Sensor with Indicator
What is Temperature ?
Thermocouple Cold Junction Compensation
Thermocouple Details
Difficulties with Thermocouples for Temperature Measurement
Installation Precautions of Thermocouple and RTD
Basics of Thermocouples and RTD
Temperature Sensor calibration procedure
How Does an Infrared Thermometer Work?
Testing a Thermocouple With a Multimeter
Difference Between RTD, Thermocouple and Thermistor
Components of RTD
Difference between PT100, PT1000, Nickel RTD and Balco RTD
Temperature Sensors Questions
Questions on Thermocouple and Pyrometer
Temperature Gauges and Elements Specifications
Temperature Gauges and Elements : Detailed Specifications
How to Select Right Thermocouple and Thermowell
How to Select Right Thermocouple & Thermowell ?
Resistance Temperature Detectors Troubleshooting Tips
Thermowell Installation near Critical Equipment
RTD Calculator Software
Temperature Controller Problem
Temperature Measurement Interview
Temperature Measurement Interview Questions
PLC Programmer Unknown Do's
Unknown Do’s Need to Know as a PLC Programmer
Positive Displacement Pumps
What are Positive Displacement Pumps and their Types?
Argonite Fire Suppression System Animation
Argonite Fire Suppression System Working Principle
Ratio control
What is Ratio Control ?
PLC Program to Drain Same Products from Two Tanks
gauge’s bourdon tube
Pressure Gauges : Remote and Chemical Seals
Difference Between LED and LCD
Digital Electronics Objective Questions – Set 2
