Reading: Target Flow Meter – Working Principle, Advantages, Disadvantages
Inst Tools > Blog > Flow Measurement > Target Flow Meter – Working Principle, Advantages, Disadvantages
A target flow meter measures flow by measuring the amount of force exerted by the flowing fluid on a target suspended in the flow stream.
Last updated: November 1, 2023 11:46 am
Flow Measurement
4 Comments
3 Min Read
Target flow meters, also known as drag force flow meters, insert a target (drag element), usually a flat disc or a sphere with an extension rod, into the flow field.
Target Flow MeterAdvantages of Target Flow MetersDisadvantages of Target Flow Meters
The target flow meter then measures the drag force on the inserted target and converts it to the flow velocity.
Target Flow Meter
Target Meter Principle
Target flow meters measure flow by measuring the amount of force exerted by the flowing fluid on a target suspended in the flow stream. The force exerted on the target by the flow is proportional to the pressure drop across the target.
Similar to differential pressure flow meters, Bernoulli’s equation states that the pressure drop across the target (and hence the force exerted on the target) is proportional to the square of the flow rate.
Target Flow Meters
One major advantage of the target flow meter over other flow meters is, that with a sphere drag element, a proper strain gauge layout, and well-thought-out mathematical formulas, a target flow meter is capable of measuring sporadic and multi-directional flows.
The deflection of the target and the force bar is measured in the instrument.
The force on the target can be expressed as :
F = cd ρ v2 At / 2
where
F = force on the target (N)
cd = overall drag coefficient obtained from empirical data
ρ = density of fluid (kg/m3)
v = fluid velocity (m/s)
At = target area (m2)
  • Low initial set-up cost
  • Can be used with a wide variety of fluids, even viscous fluids, and slurries.
  • Can be used in abrasive, contaminated, or corrosive fluid flow
  • Can be made to measure flow velocity that is sporadic or multi-directional with sphere drag element designs
  • Pressure drop is inevitable due to the rod and the drag element
  • Less popular than it was before
  • Vortex Flow Meter Sensors
  • Optical flow meter Principle
  • Why Turndown Ratio is important?
  • Non-intrusive Flow Instruments
  • Ultrasonic Flow Meter Principle
Troubleshooting Magnetic Flow Meters Common Problems
Volumetric Flow Calculations
Heat Tracing Problems
Flow Switch : What is it? – Applications
Coriolis Mass Flow Sensor Theory
4 Comments
  • Ridwan says:
    May 30, 2018 at 11:38 pm
    Thanks ..
  • Jerry says:
    May 30, 2018 at 11:42 pm
    Thanks for this…
  • IsaacInst says:
    May 30, 2018 at 11:50 pm
    Helpful Site.
  • Harshrajsinh says:
    January 24, 2021 at 8:57 pm
    Thanks
Magnetic Flowmeter vs. Turbine Flowmeter – Comparison
What is a Condensate Pot? How to Install it?
Pressure based Flow Meters
Classification of Flow Measurement Techniques
Hot Wire Anemometer Principle and Types
Importance of Flow Meter Turndown Ratio
Coriolis Flow Meter Inaccuracy
Coriolis Flow Meter Uncertainty and Inaccuracy
Circular Chart Recorder
How to Read Circular Chart Recorder for Flow Measurement?
Impulse line - Purpose & Tapping Point Location
Impulse Line – Purpose & Tapping Point Location
multiphase-flowmeter-working-principle
What are Multiphase Flow Meters? – Working Principle, Advantages
Sick Flow meters
Flare Ultrasonic Flow Meter – SOPAS Engineering Tool
Differential Pressure Flow Meters
Short Notes on Differential Pressure Flow Meters
Electro Magnetic Flow Meter Animation
Variable Area Flow Meters
All About Variable Area Flow Meters
Calculating Loop Voltage Drop
Instrument Cable Voltage Drop
How to Calibrate pH Electrode?
How to Delay a Sensor Signal in PLC?
Burst Transformers Root Cause Analysis
Burst Transformer – Electrical Problem Solved
Delete Siemens CPU Memory
Electrical Machines MCQ Series 18
PLC Controlling a Motor
PLC Motor Control Ladder Logic Programming
Gauge Display Scale
How to Read Gauge Analog Scales
