Reading: Tank Level Control in PLC
Inst Tools > Blog > PLC Tutorials > Tank Level Control in PLC
Last updated: March 4, 2021 2:14 pm
2 Comments
3 Min Read
Design a PLC program to control the liquid level in a tank. A level transmitter is used to measure the tank level into a standard current signal from 4 to 20mA as illustrated in the below process diagram.
Tank Level Control in PLCPLC Program LogicPLC Programming for Tank Level ControlPLC Program DescriptionRung 0000:Rung 0001:Rung 0002:Rung 0003:Rung 0004:Rung 0005 & 0006:Rung 0007 & 0008:Conclusion
PLC Program Logic
  1. The agitator motor is to be started and stopped by a pushbutton station.
  2. The solenoid valves are to be open (Energized) when the agitator is running.
  3. Pump N0.1 starts at the 75% liquid level and stops at the 25% level. The pump will run only if the agitator is running.
  4. On a high-level alarm (Tank 90%), an alarm light will come ON and stay on even if the tank level drops. An operator must press the reset button to turn off the light. On the high-level alarm, both the solenoid valve will also close (de-energize).
  5. A low-level alarm light shall be provided (Tank 10%), similar to the high level, and reset using the same pushbutton.
Scaling Tabular Column:
Level Transmitter Readings in PLC
PLC Interface for Level Transmitter
Rung 0000:
Start/Stop PB latched with memory B3:0/0.
Rung 0001:
B3:0/0 enabled to turn on agitator (O: 0/0), Solenoid valve 1 (O:0/1) and Solenoid valve 2 (O:0/2).
Rung 0002:
Scaling block is used, Level transmitter gives output in mA (N7:0), to convert that into PLC range (N7:1), and scaling block is used.
Refer to the above tabular column for a respective range of values.
Rung 0003:
According to the program logic, we need to turn on the PUMP (O:0/3) at tank reaching 75%
And the pump still is in ON condition up to 25%, so comparator blocks are used to get this condition.
Agitator motor contact also connected in series as mentioned in program logic.
Rung 0004:
Memory coil connected to turn ON pump motor output.
Rung 0005 & 0006:
High-level alarm should turn ON when tank reaching 90% and should not turn off until alarm reset (I:0/2) is pressed.
Greater than or equal block is used to compare the real scaling value(N7:1) and register value.
Rung 0007 & 0008:
Low-level alarm should turn ON when tank reaching 10% and should not turn off until alarm reset (I:0/2) is pressed.
Less than or equal block is used to compare the real scaling value(N7:1) and register value.
Conclusion
We can use this example to understand the programming logic in Allen Bradley Programmable Logic Controller (PLC).
Author: Hema Sundaresan
  • Motor control in Ladder logic
  • Conveyor Ladder Logic Program
  • Function Block Programming
  • Operator Interface for SCADA
  • Control Instructions in PLC
PLC Tag Naming Conventions
How to Connect PLC with SCADA System via OPC UA?
SCADA for Substation Automation
Comparison Instructions in PLC Programming
2 Comments
  • Sunil yadav says:
    June 30, 2022 at 6:13 am
    sir i having level sensor problems in delta AS228R how can i solved this problem plz reply me
  • Mr. unknown says:
    October 26, 2023 at 11:45 am
    Ya you can solve it
PLC Program for Flow Totalizer
PLC Temperature Control using Pulse Width Modulation (PWM)
PLC Ladder Logic for Start-up Control of Boilers
PLC Program for Boolean Expression
What is RS Linx? Types of Software in Rockwell Automation
Ladder Logic Example of Two Motors Interlinked with another Motor
SCADA Engineer
SCADA Engineer Job Responsibilities and Skills
PLC Program using START & STOP Buttons
PLC Program using START and STOP Buttons
PLC Programming in Bottle Filling Process
Applications of PLC Programming in Bottle Filling Process
PLC Programming for Level Switches
PLC Programming using Level Switches
Pneumatic valve operation in sequence mode
Sequential PLC Programming for the Pneumatic Valves
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
PLC Program for Alarm Indication in Process
Online and Diagnostics of Siemens PLC
How to Use Diagnostic Buffer for SIEMENS PLC?
PLC Program
PLC Program to Heat and Bend Glass Tubes
Underground Cable Fault Identification Methods
Technology is Shaping the Future of Education
How Technology is Shaping the Future of Education?
Capacitor and Symbols
Capacitance
Electrical Machines MCQ Series 10
Explosive Limit in Fire and Gas System
What is an Explosive Limit? – Lower Explosive Limit (LEL)
Actuator Sensor Interface (ASi) Protocol in PLC
Diode-testing-with-multimeter
How to Test a Diode using Multimeter
