Reading: Steps to Configure TCP/IP Communication in Siemens S7-1200 PLC
Inst Tools > Blog > PLC Tutorials > Steps to Configure TCP/IP Communication in Siemens S7-1200 PLC
Learn the steps to configure the TCP/IP communication in Siemens S7-1200 PLC using TCON, TSEND, and TRCV instructions.
Last updated: September 28, 2022 2:18 pm
Greesh Maheshwari
In terms of the famous OSI Model (Open Systems Interconnection Model). TCP/IP is a transport-layer protocol.
TCP/IP CommunicationSteps to configure TCP/IP Communication in Siemens S7-1200 PLC.TCP Server ConfigurationTCP Client ConfigurationNetwork 1: Start ConnectionNetwork 2: Send String DataNetwork 3: Receive String DataAdvantagesDisadvantagesApplication Examples
TCP/IP stands for Transmission Control Protocol/ Internet Protocol
TCP/IP protocol is one of the Layer using which data can be transmitted between 2 Physical devices in an Industrial Network.
It is the most basic layer in TCP communication which works in the backend of any famous communication protocol namely Profinet, Modbus TCP/IP, etc.
TCP IP Model
TCP/IP Model
Sometimes it is really a headache when different third-party devices need to communicate with each other and they don’t support any common protocols in between them then this protocol holds to be very helpful.
It can be configured in the following method.
One device acts as a TCP Client and the other device acts as TCP Server.
AT First TCP server opens a single socket port and behaves as a passive device and now this device is ready to share data once the communication handshake is done.
TCP Client requires the following data of the TCP server IP address and Port Number to initiate the connection request. Hence, the client acts as an Active device.
I have used Hercules software as TCP server and PLC as TCP Client
I have opened port 4660 for communication and my Laptop’s IP address is 192.168.0.53. With this server-side configuration is finished.
Make a new DB with the following settings. A DB is a database of Siemens PLC. You can store any sort of data and use it in your program if it is required.
  • Interface id: Hardware ID is of Siemens PLC Ethernet port can be found in the hardware setting.
  • ID: Connection ID
  • Connection Type: 11 = TCP/IP
  • Active Established = True [As PLC is TCP Client]
  • Remote Address = IP address on Server in my case laptop’s IP address.
  • Remote Port = Port of Server
I have taken 2 string data types.
Send_Data String is to send the data to Hercules.
Rcv_Data String is to receive the data from Hercules.
Database in Siemens PLC
To initiate the connection TCON Block is used which will establish the connection.
This block does the necessary handshaking with another device, which is required as per transport layer architecture.
TCON instruction in Siemens PLC
Transport layer connection mechanism
Figure: Transport layer connection mechanism
To send data to the server. TSEND Block is used.
Write values on the DB address “TCP”.SEND_DATA and then Set the value of bit address M2.1 [Send_Data] = True to trigger the message.
Use Same ID as TCON.
TSEND instruction in Siemens PLC
To Receive data TRCV block is used. Enable bit address M2.2 [Recv_Data].
It will be in listening mode whenever new data arrives it will be displayed on the DB address “TCP”.RCV_DATA.
TRCV instruction in Siemens PLC
Advantages
It is an open protocol, unlike profinet which is proprietary.
Many IT professionals don’t have knowledge about industrial software so it is easy if we want to develop a general application that uses PLCs data.
Disadvantages
It is sometimes complex to learn for beginners. As it requires a proper understanding of the fundamentals of the OSI layer.
This protocol can be used to send data from PLC to IT Software such as
  • Recipe Management
  • Reporting Apps
  • Data Logging to SQL
EndNote
Understanding this protocol clears your fundamentals about Modern Communication protocols. Good Luck!
  • Types of Schneider PLC
  • Site Acceptance Test of PLC
  • FIFO Block in Siemens TIA Portal
  • Configure PID in Siemens PLC
  • How to Create DFB in Schneider PLC
What is a PLC? – Programmable Logic Controller
How a PLC do the Scaling for a Sensor ?
PLC Programming Example on LED Control
PLC Practice Questions
Moving Data between PLCs – Siemens Basics – TSEND TRCV
CODESYS HMI Interface
Cybersecurity in PLC
XG5000 Example of Simple Conveyor Control PLC Program
PLC Program with 2 Toggle Switches and 4 Motors
Communication between InTouch Scada and Allen Bradley PLC
How to Check Address Overlapping in Tia Portal?
Siemens HMI Training – Using UDTs with Faceplates
Siemens PLC Force LED
Forcing and Modifying PLC Logic
Faceplates
What are Faceplates? How to Create a Faceplate? HMI Visualization
Watchdog Timer in PLC
What is a Watchdog Timer in PLC?
PLC Sizes and Applications
Allen Bradley SLC 500 PLC Programming
What is a function call in TIA Portal
Difference Between FC and FB in Tia Portal
Allen-Bradley SLC 500
History of Programmable Logic Controllers (PLC)
100+ Quiz on Electrical Circuits and Control
Industrial IoT Job Roles and Responsibilities
IoT Engineer Job Roles and Responsibilities
Types of Sensors used in the Dairy Industry
Open PLC Software
Open Source PLC and SCADA Software
Control Valves Leak Tightness
Control Valves Leak Tightness Restoration Pose Difficulties
temperature_calculator
Thermocouple / RTD Calculator
Manometer Measures Differential Pressure
How Manometer Measures Differential Pressure for Different Fluids?
HART Multidrop Network
HART Communication Tutorial Part 2
