Reading: What is a Solar Pump VFD? – Advantages, Principle
Inst Tools > Blog > Common > What is a Solar Pump VFD? – Advantages, Principle
A solar pump VFD is used in solar-powered pumping systems to regulate the speed and operation of an electric motor with solar panels.
Last updated: January 12, 2024 10:58 am
Common
Everyone knows what a VFD is and why it is used for motors. It helps in varying the frequency of the motor as required to a desired set value. Nowadays, as renewable energy sources are finding a new way in the market due to rising energy-saving concerns, this same technique is also available for a VFD.
Solar Pump VFDHow does a Solar Pump Inverter Work?Advantages of Solar Pump Inverter
One such renewable energy source is solar energy and the VFD employing this technique is called a solar pump VFD. Why pump? Because it is used to drive a water pump used in farms or for other irrigation purposes. It is taking a very great step in business due to its use. In this post, we will see the concept of a solar pump VFD.
Solar Pump VFD
As the name implies, it is an electronic device that provides a variable frequency using solar power. Solar power means it is not applied directly to the VFD. There comes a solar panel first, which takes solar energy and converts it into electrical energy.
But the output is in DC form. This DC power is then fed to the VFD input where an inverter circuit inside converts it into AC power. This variable AC power is then fed to the water pump.
From this, one thing is clear solar energy is responsible for powering the pump and as the solar intensity varies, the DC output will vary and eventually, your VFD speed. The most commonly used pumps are centrifugal pumps, irrigation pumps, and well water pumps.
As discussed earlier, the VFD will take DC power in its input terminals. Based on the DC voltage available, the VFD will vary its frequency to the motor. It works on an algorithm called MPPT (maximum power point tracking). It means it computes the maximum available power from the solar cell continuously and based on the variations, provides one average output voltage to the VFD. This calculation is done on the solar cell side too as well as in the VFD too.
Sunlight will vary and if the output voltage of VFD is varying continuously, then the productivity of VFD will decrease for running the pump. In this case, MPPT will work and decide the best available voltage at its output to give. It is a very complex theory and requires a proper understanding of battery voltage, solar performance as well as mathematical algorithms.
Solar Pump
The VFD can then be programmed according to your needs to give a controlled output to the motor. The only difference that separates itself from other standard VFDs is its ability to generate a controlled output from renewable energy, which other types of VFDs cannot. If there is no MPPT algorithm, then there is no use in running the VFD with an input of solar energy, because solar power is variable.
1. The first and foremost merit is the use of renewable energy for the generation of electricity. This makes this VFD a very special-purpose device for engineering.
2. It is a clean source of energy that contributes less to pollution and saves time and fuel.
3. The operating cost of this VFD is very less due to solar energy and there is no extra resource requirement for electricity generation.
4. MPPT technology ensures that the pump speed is not varied frequently and the efficiency of the system is maintained throughout.
  • What is a Circulating Pump?
  • Real-time PLC Automation Projects
  • Wastewater Treatment Pumping Station
  • Amine Pump Trip Root Cause Analysis
  • Industrial Automation Wireless Technology
What is a Fotonic Sensor? – Working Principle, Advantages, Disadvantages
Encoder Working Principle
Instrumentation documents
Introduction to Embedded Systems – Features, Types, Applications
4-wire Transmitters Current Loops
HVAC Valves
Combustion Control – Series and Parallel Air-Fuel Ratio Control
What is VoIP and How Does it Work? Advantages & applications
HVAC Refrigeration Cycle
Best Online Courses to Learn Electrical Engineering
Introduction to Fluid Power and Pneumatics
What is a Photoelectric Sensor?
Internet of Things Communication Models (IoT)
What can you do with an Engineering Degree
What Can You Do with an Engineering Degree?
Cable Drum Handling
What is Cable Drum Handling? – Transportation & Storage
Career Scope in Electronics Engineering
Types of Equipment Needed to Run a Successful Auto Repair Shop
Introduction to Mechatronics
Pictorial Fluid Power Diagram
Hydraulic and Pneumatic P&ID Diagrams and Schematics
Laser Doppler anemometer
Laser Doppler Anemometer
CNC Milling Machine
CNC Milling Machines: What Are They And How Do They Work?
Electronic Devices & Circuits Quiz – Set 14
Instrument Heat Trace
Electrical Heat Tracing
Siemens PLC Write Protection
How to Protect Siemens PLC using Password?
Earthing Calculations
Electrical Earthing Calculations
dispersive gas analyzer
Dispersive Spectroscopy
Manual Call Point Operating Principle
What is Manual Call Point (MCP) ?
How to Find the Correct Solenoid Valve Size
How to Find the Correct Solenoid Valve Size?
Top 100 Electrical Machines Projects for Electrical Engineers
