Reading: Siemens S7-300 CPU Suffix Explanation
Inst Tools > Blog > PLC Tutorials > Siemens S7-300 CPU Suffix Explanation
Last updated: March 4, 2021 12:14 pm
3 Min Read
Siemens S7-300 CPUs suffix explanation
Siemens S7-300 CPUCPU XXXY-Z
If you are in a new project and want to use Siemens S7-300 CPUs you are going to see a wide variety of CPUs under the name of CPU s7-300.
The first step is to open the SIMATIC manager software and choose a new project and go to Hardware configuration you will see the following table:
Siemens S7-300 CPU
  • In the previous table, there is a fixed pattern of CPU title
CPU XXXY-Z
Where
1. XXX is the number of CPU.
The greater the number the more capability the CPU is. Like the CPU scan cycle, memory size and number of IOs can be connected in the PLC.
2. Y is defining the type of CPU and it can be:
  • None: in this case the CPU is an ordinary modular PLC.
  • C: which stands for Compact, i.e. the CPU has a built in number of input output modules in addition to the modules that can be added to the CPU if we need to.
  • IFM: which stands for Integrated Function Module, it’s like the compact CPU but it has internal function module of high speed counters.
  • F: which stands for Fail Safe module, fail safe is a specific module that is used in cases where we need the maximum security of process controlling.
3. Z is defining the communication ports in the CPU and it can be:
  • None: In this case the CPU has only one port for MPI communication.
  • 2 or 2 DP: in this case the CPU ports are
Siemens CPU ports
1 MPI port and 1 DP port for Profibus communication.
C. 2 PTP: this CPU has 2 ports, first port for MPI and a second port for PTP (Point To Point) port
The PTP port can be used to communicate with printers and barcode readers.
D. 2PN/DP: This CPU has 2 ports first port for MPI or DP and 1 or 2 ports for Profinet connection.
Siemens CPU
E. 3PN/DP: This CPU had 1 port for MPI, 1 port for Profibus, and 1 or 2 ports for Profinet.
Siemens CPU MP Port
Author: Karim Ali Anwar
  • Memory Structure of Siemens PLC
  • Connect to the Siemens S7 PLC
  • Upload Siemens PLC Programs
  • InTouch Scada Scripting
  • Programmable Logic Controller
DCS Commissioning Steps
Siemens S7 300 and STEP 7 PLC program using SIMATIC Software
How to Convert Current to Voltage using Resistor ?
PLC Program to Drain Same Products from Two Tanks
Smart Spray System using Wecon PLC
Steps in PLC System Design
How to Update the Firmware Version of your PLC? – TIA Portal
How to Use Encode and Decode Instructions in PLC ?
PLC Energize or De-energize the Outputs based on Events
Communication Processor Module in Siemens PLC
PLC Automatic Irrigation System
Free Mitsubishi PLC Online Training Courses
Free Mitsubishi PLC Online Training Course and Tutorials
PLC Programming for Pumping and Draining System
PLC Automatic Pedal Switch for Speed Control
PLC Program for Selective Execution of the Application
PLC Selective Execution of the Application – Example Program
Burning Oven PLC Program
PLC Program for Ceramic Burning Oven Conveyor System
Classification of Fuses
Step-by-Step Guide to Choose Right Fuse for a Panel
Hydrogen Sulfide Gas Detector Calibration Procedure
Forward Reverse Motor Control with Repeat Cycle Using PLC
Over Pressure cases for Pressure Relief Valve Sizing
simple motor start-stop circuit
Liquid Level Switch Control Logic
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 1
Functions of Instrument Transformers
Functions of Instrument Transformers (CTs and PTs)
Pitot tube
Pitot Tube Flowmeter Calculations
1’s, 2’s, 9’s & 10’s Complements Multiple Choice Questions
