Reading: Selection of Master Instrument for Calibration
Inst Tools > Blog > Calibration > Selection of Master Instrument for Calibration
We compare the reading of Unit Under Calibration (UUC) with reference to Master Instrument. Therefore the selection is very important.
Last updated: September 28, 2022 3:26 pm
Saurabh Vaidya
Calibration
3 Min Read
For Calibration, we need Unit Under Calibration (UUC) and Master Instrument. We compare the reading of UUC with reference to Master Instrument.
Therefore the selection of Master Instrument is a very important step in Calibration.
Criteria for Selection of Master Instrument
There are six steps for the master instrument selection. They are as follows.
Step 1
Compare the range of Master Instrument and UUC. Master Instrument should cover the full range of UUC.
 For e.g.- We cannot calibrate the thermometer of range 300 degrees Celsius with Master Instrument having a range of 100 degrees Celsius.
 Another example, we cannot calibrate 10 bar Pressure Gauge with Master Pressure gauge having a range 8 bar.
Step 2
Compare units of Master Instrument and UUC
To compare UUC and master Instrument, both should have the same units.
We can compare two instruments with different units if the unit conversion is possible.
 For example, in Pressure Gauge, we can compare bar and kg/cm2 with proper unit conversion formula.
It is recommended to have the same units of Master Instrument and UUC.
Step 3
Master Instrument should have a better least count than UUC.
Least count is the smallest measurement that can be taken by a measuring instrument.
Step 4
 Accuracy of the Master Instrument should be at least 3 times better than UUC.
Accuracy is the ability of the instrument to measure the accurate value.
Accuracy is different for Precision.
Also, it is technically wrong to use 1000 bar Pressure gauge as Master Instrument to calibrate 10 bar Pressure gauge.
Even it satisfies the 1st condition of the range, it doesn’t satisfy the condition of accuracy.
Step 5
Master Instrument should be calibrated and it is within calibration due date.
Master Instrument should also be calibrated with higher accuracy Instrument before using has Master Instrument.
This is known as a chain of calibration traceable to National/International Standards.
Step 6
The Master instrument should be calibrated at the calibration point of UUC
Consider a case, Master Instrument satisfies all the above conditions of range, Accuracy and calibration due date.
We want to use a master pressure gauge for calibration point as 4.5 bar of UUC, but Master Pressure is calibrated only till 4 bar.
Therefore, we cannot use this as master for calibration of 4.5 bar UUC pressure gauge.
The Master instrument should satisfy all these conditions to use as a Master for Calibration. If it fails in any one condition, it cannot be used as Master Instrument.
  • History of Measurement
  • Pressure Gauge Calibration
  • Field Instruments Selection
  • Instrument Maintenance
  • Turbine Flow Meter Calibration
Calibration of Measuring Instruments – Significance, Costs & Risks
pH Analyzer Calibration and Troubleshooting
Instrument Zero and Span Calibration
Magnetostrictive Level Transmitter Calibration Procedure
Closed tank DP Level Transmitter with wet leg elevation zero direct mount Calibration
Infrared Hydrocarbon Gas Detector Calibration Procedure
Capacitance Level Switch Calibration
Capacitance Level Sensor Principle, Limitations, Installation & Calibration
Motor Operated Valve Functional Testing
DP Level Transmitter with Zero Suppression Calibration
H & B Gas Analyzer Principle and Calibration Procedure
Methods of Measurement
Sample Raw DataSheet for Pressure Calibration
How to Calibrate pH Electrode?
Wireless HART Transmitter
How to Commission WirelessHART Transmitter With Gateway
HART Transmitter Calibration
How are HART instruments Calibrated?
Gas Detectors Bump Testing
What is Bump Testing ?
Error sources creating Uncertainty in calibration
Error sources creating uncertainty in Calibration
Calibration & Preventative Maintenance Procedures
Calibration and Preventative Maintenance Procedures
Difference between Accuracy, Tolerance, Uncertainty, and Error
Electrical and Instrumentation Maintenance Test
Electrical and Instrumentation Test
Power Electronics objective questions and answers
30 Important Power Electronics MCQ
Principle of Elastic diaphragm gauges
Elastic Diaphragm Gauge Principle
Optimal Control Systems
Gas detection system Interview Questions
Interview Questions on Gas detection System
volumetric flow measurement for liquids versus gases
Standardized Volumetric Flow
Solenoid Valve Terminology
How a Solenoid valve works
Installation of a Control Valve
How to Install a Control Valve?
