Reading: Rotary Encoder Interview Questions and Answers
Inst Tools > Blog > Electrical Basics > Rotary Encoder Interview Questions and Answers
In this post, we will learn some general and tricky questions asked regarding rotary encoders during an interview.
Last updated: October 30, 2023 9:51 am
Electrical Basics Electrical Q & A
In industrial automation, the encoder is a very widely used device for measuring a number of rotations. You must have seen that whenever you work in some simple machine like a rolling mill, which cuts the metal sheet based on the length set, it would not be possible without an encoder.
Rotary Encoder Interview QuestionsWhich type of signal does an encoder convert into an electrical signal?What are the two types of encoders based on the output signal?What is the resolution in the encoder?Which counter is used in PLC for counting encoder pulses?There are a total of how many phases in the encoder for reading motion?What is the standard power supply for an encoder?Name some applications for encodersWhat are the basic selection criteria for an encoder?Are encoders affected by noise?
An encoder will feed binary data to the PLC which shows how much length of sheet has been passed. So, such simple machines to complex machines in industries that require measuring some moving object require the use of an encoder.
Rotary Encoder
Image Courtesy: P&F
An encoder is thus a very integral part of machine automation projects. The programmers who apply for jobs in machine automation must have proper knowledge of encoders. So, it is important to crack questions if arise during interviews.
In this post, we will learn some general and tricky questions asked regarding encoders during an interview.
The encoder converts a mechanical displacement signal into an electrical signal. Basically, an encoder has a shaft that when moved produces the corresponding number of electrical pulses. The more you move the encoder, the more the number of electrical pulses generated. So, the electrical signal is directly proportional to the mechanical displacement signal.
The two main types of encoders are incremental and absolute. Incremental encoders do not store the pulses when power goes off and absolute encoders store the pulses even when power goes off. Due to this, absolute encoders are mostly used in applications where the last hold position is required to be retained for operation.
Resolution is a data length that is used to define how fine an encoder can read pulses in one rotation. The higher the resolution, the higher the number of pulses you get for a single rotation and thus, you get more precise values for the motion. It is also termed as PPR (pulses per revolution)
The PLC programmer should use high-speed counters for configuring an encoder in the system. Without it, it is not possible to read an encoder.
In the encoder, there are a total of 3 phases – A, B, and Z. A phase is used for sensing forward direction, the B phase is used for sensing reverse direction, and the Z phase is used as a start or reset signal. Z phase is generated only once per rotation of the shaft. Thus, it is a rising edge-type signal used for reference or homing.
An encoder uses 5-30V DC for power supply. It does not use AC voltage.
Some of the most used applications of encoders are packaging machines, printers, CNC machines, labeling machines, material handling, cable pulls, conveyors, textiles, assembly machines, robotics, and drilling machines.
The most standard selection criteria for an encoder are shaft size, shaft style for fittings, nearby environment, and resolution.
Yes, like usual electronic devices, an encoder is disturbed by noise, which affects the signal output. Some of the most common noise reasons are mounting issues, crosstalk, signal interpolation, shorted wires, proximity to high power cables, and poor earthing.
In this way, we saw some general and new types of questions asked in interviews regarding rotary encoders.
  • PID Controllers Explained
  • Servo Motor Interview Questions
  • Top Best Practices of PLC Wiring
  • Control Speed of Induction Motor
  • Most Asked Questions on SCADA
Difference between Stepper Motor and Servo Motor
What is an Electrical Drive? Types, Advantages, Disadvantages
Circuit Breaker Interview Questions & Answers
Difference Between MCB and RCBO
Single Phase versus Three Phase Power
Top 100 Power Electronics Questions & Answers
What is Variable Air Volume Controller in HVAC?
Various Control Methods in Servo Motor Drives
How to Identify Phase, Earth, and Neutral Wires?
Understanding Protection Relays – 50, 50N, 51, 51N
What is a Megger? Principle, Advantages, Disadvantages, Applications
Electric Motors Efficiency Classes
Electrical Terminology
Single Line Diagram (SLD) Example
Electrical Drawings
Working of Stepper Motor
Types of Stepper Motors
Basics of Electricity Rates
Types of Industrial Storage Batteries
Worldwide Voltage & Frequency Values
Types of Switches
Electrical Switches Principle & Types
Volume Damper
What is a Damper? Types of Dampers in HVAC
Single Beam and Double Beam Instruments
Laminar Flow Meter Working Principle
What is the thermal effect on zero
What is the thermal effect on Sensors?
Difference Between Modbus TCP IP and Profinet
Typical Purging Installation
Purging of Instruments
Instrument Air Quality
Tube Fittings - 4
Tube and tube fittings
