Reading: How to Retrieve PLC Project From Memory Card?
Inst Tools > Blog > PLC Tutorials > How to Retrieve PLC Project From Memory Card?
In case you lost your PLC program then you can retrieve your project backup from the memory card by following these steps.
Last updated: March 4, 2021 11:24 am
2 Min Read
In the previous article, we learned how to save a project to a memory card. Now in this article, we will learn how to retrieve the PLC project which we have saved to micro memory card (MMC).
After saving the project to memory card (MMC), if in case you lost your PLC program then you can retrieve your project by following the below steps.
Step 1:
Open Simatic manager.
Simatic Manager New Project
Step 2:
Close the Simatic manager window and click on an icon as shown in the below window.
Simatic Manager PLC Backup
Step 3:
The following window will pop up.
Chose your project and go to “PLC” and choose “retrieve from memory card”’
Retrieve from memory card
Step 4:
Select a project and hit “ok” to proceed.
Retrieve Files from PLC
Step 5:
A progress bar will pop up to indicate that transfer of the project from MMC is running.
Get PLC Files from Memory Card
Step 6:
The following pop up will open. Hit “ok” to proceed.
PLC Program Backup from Memory Card
Step 7:
A project is retrieved now.
Siemens PLC Project Retrieved
Author: Suhel Patel
  • PLC Momentary Operation
  • VFD Drive Features
  • Motor Push-button Logic
  • Compare PLC Projects
  • Solenoid and PLC Wiring
PLC Programming for 3 Motors control in Ladder logic
How to Solve Electrical Ground Loop Problems?
Which Language is Best for PLC Programming?
Examples of SCADA and PLC Configuration Systems
Automatic Motor Forward and Reverse Control using Timer
  • Aysha says:
    March 22, 2022 at 10:23 am
    My PLC 312 is not working how can I retrieve data from MMC?
PLC Program for Mixing Tank
Product Painting PLC Program using Omron CX-Programmer
Vijeo Designer software – Import and Export
Push button Motor PLC Logic
PLC Program for Star Delta Starter using Functional Block Diagram
21 CFR in SCADA and HMI Systems
What is 21 CFR in SCADA and HMI Systems?
DCS Commissioning Steps
PLC Program for Filling Operation
PLC Program for Continuous Filling Operation
How to Activate the Schneider PLC Software License
How to Download EcoStruxure Machine Expert? Schneider PLC Software
Flip-Flop PLC Program for Lamps Application
Example of Flip-Flop PLC Program for Lamps Application
PLC Automation Memory
What is NOR Flash Memory in PLC?
Allen Bradley PLC to PLC Communication in Studio 5000
Difference Between PNP and NPN Sensors
Top 10 Facts about HART Technology
What is HART, Foundation Fieldbus & Profibus ?
inductance transducer
Inductance Type Pressure Transducers Principle
Special Control Valves
Siemens Simatic HMI
How to Design an Effective HMI? – Human Machine Interface
Type D Chopper Objective Questions
Pole Placement by State Feedback
Solenoid Valve Terminology
How a Solenoid valve works
Stepper Motor Parts
Stepper Motor MCQ
